Old 11-09-2017, 02:49 PM   #1
David L
Drives: 2013 BRZ Ltd
Brake Choice to fit +45 offset?
I’m about to get some RPF1’s in a 17x8 +45 offset and I know there are some Brembo limitations there but to be honest that doesn’t mean much to me without first knowing which brakes would be great for my needs!
Just starting our mods finally and wheels / tires are first but before I pull the trigger I need help on the brake options. This is a dd car that will see everything, autox / HPDE, and will have over 250 rwhp. This is all just for pure fun, so I don’t need to spend $5k for slight performance here and there but I would like to spend decent money to get what I can out of it. I’m assuming $1-2k for breaks all around but I don’t really know?!
So any recommendations on brakes and whether they’d work with the +45 offset vs +35 or +45 w/ adding spacers?
I can get the +45 offset wheels much much cheaper and just prefer the spacing / look but I’m not sure if I’d be shooting myself in the foot?
Any help greatly appreciated!! Thanks!
David L is offline   Reply With Quote
Old 11-09-2017, 03:07 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
If you are getting wheels first, before brakes/forced induction and such, how about printing out some brake fitment templates from this thread and checking fit?
As for more performance per buck .. i suggest investing in some suspension tune up. For example - camberbolts for front, and maybe lca for rear. And tires. That will allow to drive much faster and for less. For beginning stock brakes may serve well enough if you get better pads & brake fluid. And laptimes will be improved most by more seat time & some HPDE instructions. After some experience behind belt you may change your mind as to what will seem worthy to invest in upgrading of.
Old 11-09-2017, 04:15 PM   #3
David L
Thanks for the link! My hope was to get any insight I could before purchasing the wheels / tires here very shortly though. Just wondering if I’ll be severely limited by the +45 offset or if I’ll still have great options available without using spacers. If I end up needing spacers I’m sure it won’t be the end of the world but would rather not. I don’t need the biggest baddest brake kit, but I still want something pretty good!
The plan is to throw a lot of money at this car fairly quickly. $15k in the next 6 months is very possible if that helps give an overall idea of the build.
Thanks again!
Old 11-09-2017, 04:28 PM   #4
DAEMANO
Time Traveller
If you're about to spend that much cash. Get the +35 version. They fit brakes better and look more flush and less sunken in (personal preference I know, but generally people like flush and I'd agree).
http://www.rawbrokerage.com/enkei-rp...17x8-35-5x100/
Old 11-09-2017, 04:50 PM   #5
David L
Well I’ll be running them with 245/40/17 (Michelin Pilot Sport A/S 3+) so the +45 is more flush whereas the +35 pokes out which I really don’t like the looks of. Plus I’d be getting the +45 for about $500 cheaper than the link you gave for the +35. I’m really hoping there are some good brakes that will fit the +45 but if I really had to do spacers at least it would be cheaper and poke less since I could likely do 6mm or some such instead of all 10.
Old 11-09-2017, 04:55 PM   #6
NeedsBoostt
NeedsBoostt's Avatar
Drives: '19 WRX STi; Ex. '17 BRZ owner
From what I have been seeing/hearing is the RPF1 18x8 +45 work with the performance package BRZ Brembos... If the aftermarket brembos are the same then my guess it would fit.
NeedsBoostt is offline   Reply With Quote
Old 11-10-2017, 11:56 AM   #7
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
you posted in the RPF1 17x9+35 page, then come here and talk about 17x8. yes, 17x8+45 is a good fit for many brake applications. the wheel face is different.
here is the AP racing sprint kit list for RPF1
Enkei RPF1 17x7.5 +48
Enkei RPF1 17x8 +35
Enkei RPF1 17x8 +42
Enkei RPF1 17x8 45
Enkei RPF1 (very tight fit, but works) 17x9 +35
Enkei RPF1 18x9.5 +38
G-Man is offline   Reply With Quote
Old 11-10-2017, 12:49 PM   #8
wparsons
wparsons's Avatar
17x8 +35 doesn't really poke at all. The 9" +35 pokes a bit with 0* front camber, but with some functional camber it doesn't really poke at all. The 8" +45's definitely have at least 10mm of space before they start poking.
flickr
Old 11-10-2017, 02:03 PM   #9
mkivsoopra
Stock brakes work just fine for track with some good pads and fluid. You'll only need BBK if you're tracking a lot, or want to look flashy. If you're going to be tracking a lot, then I'd suggest NOT randomly throwing $15k at the car, and take it to the track first, as stock as possible. You'll quickly learn how/where to spend that $15k as you get to know the car better. Also, with 250+ whp, you'll probably want wider wheels than 8". Many of us run the RPF1 17x9 +35 with no poke.
mkivsoopra is offline   Reply With Quote
Old 11-10-2017, 09:55 PM   #10
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
I'm kind of in the same spot as you. My new wheel setup is a +45 upfront, but I have brembos. Currently I am running a 5mm spacer upfront and I BARELY clear the caliper.
I did my own poking around and found that the AP Racing Endurance kit would fit, but not the Sprint Kit. You can download templates and test the fit from their website.
kuczynskika is offline   Reply With Quote
Old 11-11-2017, 02:18 AM   #11
CSG Mike
CSG Mike's Avatar
Are you tracking your car? Have you used race pads before?
Old 11-11-2017, 12:09 PM   #12
David L
Wow, I did a google search for RPF1 17x8 +45 and it got me to that thread. There were so many posts of all different sizes I didn't realize it was supposed to be specific to a certain size and not just the overall brand of wheel! Thanks. After all the advice and more research since I really want the 245/40/17 tire I think I'm gonna go with 9" wheel width (and only 0.3 lbs extra!). I will likely go with +45 just because of availability and huge cost savings for me with the deal I get from TireRack (who doesn't carry the +35). If it won't fit with stock suspension then I'll just have to pick out the suspension mod asap
Sounds like I'll definitely have decent brake options even if somewhat limited. Thanks for all the help guys, I appreciate it!
Old 11-11-2017, 12:12 PM   #13
David L
We will be doing some HPDE / AutoX, but it's mostly a dd and all just for fun. Not worried about shaving 1/10 a sec or anything, just a damn fun car to drive! I've had slotted / drilled rotors with upgraded pads before on a diff car. I can't remember for sure, but I think that was just race pads, not calipers.
Old 11-11-2017, 04:28 PM   #14
gtengr
Drives: 2017 BRZ
I'm in the same boat. Looking at +45 range that will clear AP's. I would rather get a +45 and spend extra for 5 mm spacers than get a +35.
If he knows he's going to be tracking a lot, then it makes more sense to go ahead with a BBK.
That has to poke. Maybe the top of the tire fits under the fender but that is still poke imo.
The AP Sprint kit should pay for itself after ~30 track days. ~15 days after you consider the resale value.
gtengr is offline   Reply With Quote
brake fit, offset, rpf1
XXR's? Maybe not right the choice... dem00n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 12-20-2013 02:32 AM
Rim choice Karl07 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-19-2013 07:31 PM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
What is your first mod choice? genometuning Scion FR-S / Toyota 86 GT86 General Forum 43 08-31-2012 12:53 PM
