| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2014 BRZ
Small spacer vs big spacer
Assuming I end up with the same offset in the end, is there any advantage/disadvantage of going with
a +48 wheel with a 28mm spacer, or a +35 wheel with a 15mm spacer They both result in a +20 offset. What else is there to consider? I'm wondering if going with the larger spacer (in general) would actually be the safer choice to make sure that the car's lugs clear the wheel. Or, is that problem simply a non issue unless there's extended studs involved? |
#2 |
Drives: 2014 Scion FRS (Asphalt)
In general you want to go with the smallest spacer possible.
1) Go too thick of a spacer and you're not going to have enough threads to hold your lug nuts on 2) Less weight
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#3 |
Drives: 2014 BRZ
Ok, I was thinking only about bolt on spacers so that threads wouldn't be an issue, but good point.
#4 |
Drives: 2017 BRZ
I don't see that it matters much with spacers that large. I would use the smaller spacer unless the other one allows for rotating tires. Weight should be similar as the wheel with smaller spacer will have more material in the hub.
#5 |
Drives: 1980 corvette, 2014 Subaru BRZ
why not get a wheel with the offset you want?
#6 |
BoostedBRZ
Drives: Turbo BRZ
offset will affect concave. typically the lower the offset, the more concave the wheel looks, but that also depends on the spoke pattern.
#7 | |
Time Traveller
I'm currently using 12mm of modular spacers from Parts Shop Max as they also stress test these in drift applications. https://store.partsshopmax.com/shop/.../WheelFitment/ The cost of the above are higher than many "billet" custom spacers. They're load bearing items that need to work every time. I'm sure there are other brands that offer various degrees of engineering and testing. I'm referring to those I have first hand knowledge of that worked flawlessly. I've had a few bad experiences all due to poor construction. I'd recommend staying away from all "white labeled" bolt-on spacers from a multitude of vendors as many result in failures of the stud, lug nut or warping of the material itself. gl/hf |
#8 |
Drives: 2014 Scion FR-S Monogram
This completely relies on the manufacturing process for the wheels. Some companies cast the wheel with a low offset and then just shave the hub mating surface to raise it. Which is essentially just running a spacer from the factory for the lower ones. Others actually change the spoke concave or push the spokes back into the wheel resulting in a dish appearance which is better as it does not alter scrub radius like the previous method or spacers.
Whether the scrub radius being altered is a problem will depend on you and how you use the car. From my understanding if you want the best handling the closest to a 0 scrub radius is the best. I believe a positive scrub radius will increase steering angle and could be beneficial for drifting.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#9 | |
Scrub radius is simply the distance between the center of the wheel and an imaginary line drawn down the steering axis to the pavement.
#10 | |
#11 |
#12 |
Drives: 2014 BRZ
#13 |
Oh it was spread across hundreds of threads and was the stuff legends are made of. They say that if you stand in front of a mirror and repeat his name three times all your tires will go flat and your car's suspension will just fall apart.
Many were deleted but here are an example from each of his incarnations. If you ever feel really ambitious you can search threads started by him. Those of course are a small fraction of the total works since they would of course not show his activity in other threads. http://www.ft86club.com/forums/showthread.php?t=56887 http://www.ft86club.com/forums/showthread.php?t=71770 http://www.ft86club.com/forums/showthread.php?t=118334
| WTB: 5mm Spacer | FujiwaraTofu86 | Canada Classifieds | 1 | 03-10-2017 04:47 PM |
| UEL 02 spacer | Project N64 | Engine, Exhaust, Transmission | 0 | 03-26-2015 10:24 PM |
| Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? | Khorne | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-03-2014 12:53 PM |
| Spacer HELP?! | Husker BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 03-22-2014 10:25 AM |
| 25mm conversion spacer with 5mm spacer = safe or unsafe? | deedz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2013 11:59 AM |
