Old 11-04-2017, 09:34 AM   #1
allowe
allowe's Avatar
Tpms light on
Today, When I hopped into my car and started it, I found that my tpms light is on. My car was sitting outside all night. The day before, I went for a really long drive but there was no tpms light on.
I checked the pressure and all my tires are at 32 psi. I checked for nails etc and there was nothing. My rear tires are bald they’re holding pressure just fine.
Is there any other cause for that light to come on?
Oem tires and rims. It’s a 2013.
allowe is offline   Reply With Quote
Old 11-04-2017, 11:33 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Try 36 psi?
Other than that, it could just be a failed sensor. Uncommon but shit happens. You might need to take a trip to the dealer or a tire shop.
Old 11-04-2017, 11:44 AM   #3
If at 32 PSI one of them may be right at the edge of being low. When the tempurature drops overnight they can go just below the trigger point even though a guage still reads OK. Put a little air in the.
STOP driving around in temperatures under 7 degrees with bald rear tires. Even with tread they are bad at low temperatures. You next thread could be "Is this totaled?"
Old 11-04-2017, 06:44 PM   #4
RedZaku
Drives: 2013 brz
At the start of winter when its cold outside my tpms light comes on because its cold outside
RedZaku is offline   Reply With Quote
Old 11-04-2017, 06:52 PM   #5
D_Thissen
D_Thissen's Avatar
"black ice"
Old 11-04-2017, 07:15 PM   #6
allowe
allowe's Avatar
Lol I’m trying to burn out the tires till they’re absolutely done then throw them out.
Is your car manual or auto? I was thinking about that the other day.... as weird as it sounds haha
Old 11-04-2017, 07:17 PM   #7
allowe
allowe's Avatar
Yesterday it got really really cold at night so I was thinking the same thing too, do u just deal with it?
Old 11-04-2017, 10:49 PM   #8
Originally Posted by allowe View Post
Today, When I hopped into my car and started it, I found that my tpms light is on. ........... My rear tires are bald they’re holding pressure just fine.
......... now, go to a tire shop and have them mount four new tires ....... that will make everything all better ..........
Old 11-05-2017, 12:17 AM   #9
As I said above it comes on because your tire pressure is right on the edge of the trigger and when the air cools it drops just enough to set off the TPMS. It isn't just the cold it is a combination of pressure and the cold.
Old 11-05-2017, 12:19 AM   #10
Doing so when it is cold out could mean a totaled car get some proper cold weather tires on there soon. It doesn't take snow or ice to lose traction with summer tires.
My car is a MT.
Old 11-05-2017, 12:22 AM   #11
No you put another PSI or two of air in them so you don't hit the trigger.
And...
You get the right tires for the weather conditions put on the car (I will keep repeating that)
Old 11-05-2017, 12:23 AM   #12
Originally Posted by D_Thissen View Post
"black ice"
"It wasn't my fault"
Old 11-05-2017, 12:24 AM   #13
allowe
allowe's Avatar
“The car lost control”
Old 11-05-2017, 12:42 AM   #14
Exactly!
Blocking Your TPMS Light DarrenDriven DIY (Do-It-Yourself) Guides 77 03-29-2017 11:18 PM
Tpms light on Kravos Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-11-2017 04:48 PM
TPMS light michael317 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 08-05-2014 04:12 PM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
TPMS warning light FRSowner Scion FR-S / Toyota 86 GT86 General Forum 6 12-30-2012 08:24 PM
