Old 11-03-2017, 12:07 PM   #1
exE36M3
Head Gasket Oil Leak - this is what one might look like
UPDATE 12/30/2017
After going back and forth with the Subaru Dealer, I ended up selling the car back to them.
I had THE Subaru factory CPO warranty (gold) and they inspected the oil leak 3x across a span of 3 months, keeping the car for a week each time. After the final inspection, where I placed a paper towel over the head gasket seam, showed the SA on Monday the issue (towel wet with oil). I picked up the car on a Friday - they told me they couldn't find the leak. I popped the hood and there was the original paper towel I had put there on Monday, still there.
Which tells me they never bothered looking at the towel, let alone under the hood where I told the SA the issue was.
My 2013 BRZ leaked 1 quart for every 200 miles. It sprayed the underside of the intake runners and leaked onto the headers. NO OIL ever appeared under the car. The leak was entirely on the top of the motor under the intake runners on the passenger side.
I'm a 50yo guy who's been turning a wrench since I was 16. I've installed transmissions, motors, pulled suspensions, done electric work, so I know when somethings not quite right.
This isn't a slight to you GT86 guys or our cars. I just had a motor that leaked A LOT of oil and couldn't get the people who could fix it, to want to.
Summary - I've got all the oil leaks, that are common on our FA20 cars, repaired by the dealer. They did that job fine. But, there's another one, right under the intake runners that is pooling oil.
The dealer refuses to acknowledge the leak after multiple visits citing "we can't find it".
The car is under the Subaru GOLD extended-warranty.
In sheer frustration, I took the car to an independent Subaru shop in NorCal (Racersline). I paid for 1 hour of diagnostic work. The result?
Oil may be coming from:
1. head gasket seam
2. injector
The oil is leaking as a spray under pressure - as it's coating the electricals too.
The PCV is not the culprit.
I asked the shop owner if he thinks Subaru would repair it. His take is that the dealer won't fix anything unless the car is seriously losing A LOT of oil AND is easy to spot/diagnose.
As much as this drives my OCD nuts... The bright side is that the car runs fine and just needs a quart about every few weeks or after a long-road trip. I've got another 3 years on the extended warranty so if it does blow-up, I've got a paper trail of dealer visits.
Hey guys, I'm starting a new thread on this so Google search picks this up.
I've been hunting down oil leaks on my 2013 Subaru BRZ with 29k miles. The car is NOT raced. And the engine is bone stock. I also consider myself a decent mechanic - think engine swaps, turbo and supercharger installs, 5 foot high craftsman tool chest.
What's been fixed:
1. Cam cover seals
2. Valve cover seals
3. Cam plate
Symptoms - even with these fixes, I've been getting a bad oil smell... even under normal, easy driving to work. It's to the point where I can't even drive with the heater on because it pulls in outside air and the oil makes my eye watery.
So after a looking under the hood several nights this week with a flash light and dentist mirror... I found signs of oil under the intake plenum/runners. It looks like it's been pooling there for a while and the tint to yellow shows the oil dye the dealer put into the oil from last Feb 2017.
The leak looked to be coming from the head gasket - where the heads meet the cylinder block (and you can see the metal gasket too). The oil is pooling and spraying coating the wiring around it and attracting dirt and grime.
To test this theory, I put a paper towel in the area before my drive into work.
When I arrived, the towel shows fresh oil. The kicker... my drive is only 2.5 miles.
Here's a Google photos link to give an idea of where. You REALLY have to get on top of the motor to see it. Passenger side, under the intake bridge/plenum/runner.
If you guys have similar issues or experiences. Would love to know about them in this post. Heck, if your car has the same oil burning smell, take a look and see if you got a similar issue in the same spot.
Thanks!
I couldn't find an FRS/BRZ with a similar leak, but the spot is pretty much the same as the outback image below.
My leak runs the same line as the head gasket in this photo.
exE36M3 is offline   Reply With Quote
Old 11-03-2017, 12:19 PM   #2
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
I wouldn't jump to the conclusion that your headgasket is blown just yet. If your headgasket was blown, you would have loss of compression, your engine would run very poorly, you would lose coolant, your engine would overheat, and oil and coolant would mix etc.
Si_Chris is offline   Reply With Quote
Old 11-03-2017, 01:29 PM   #3
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Could well be a head gasket leak/heavy seepage. I'd take it back to the dealer that did the previous plumbing work on it and put it to them. If you asked them to fix the oil leak earlier, it appears they didn't finish the job.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 11-03-2017, 02:34 PM   #4
exE36M3
Um... I didn't say "blown"
And actually not all true. Head gasket failures can involve a number of things and the car can still be running.
For example, my E36 M3... the head gasket toward the back of the motor went and let out coolant. Car ran fine, never over heated. No oil lost or mixed. But obviously the coolant level went down.
Where this one is on the BRZ, looks like an oil passage one.
When you think of typical head gasket failures - it's the catastrophic cylinder ones - where oil or coolant or both end up in the combustion chamber.
Did you see the photos? The paper towel oil marks line right up with the head gasket on top of the heads. This leads to me to believe that under pressure, oil is escaping from the top.
Old 11-03-2017, 03:48 PM   #5
reebis
reebis's Avatar
Drives: 2020 STI Limited
I can confirm you can have a blown HG and still have the motor operate fine. Had a similar situation on my 2001 RS. The drivers side head had an external HG leak. Basically it had oil seeping from one of the block to head galleries. It was an extremely slow leak, and I never fixed it before I sold it. I did run it for close to 3 years that way though and all I needed to do was top the oil off every now and then. Compression test, while not stellar, did not show the typical close to zero compression of a blown HG in the cylinder itself (internal HG leak) and the car drove fine.
reebis is offline   Reply With Quote
Old 11-03-2017, 04:08 PM   #6
Si_Chris
Well, I guess I interpret a head gasket leak to be similar to a blown head gasket.
The FA20's PCV valve coming out of the block is right near the location of your oil seepage. Perhaps this is causing this issue? Your PCV hose doesn't look to be fully seated.
Old 11-03-2017, 04:31 PM   #7
exE36M3
Thanks Chris - I hope I didn't come across as adversarial. Sometimes it's hard to disagree or offer opinions in a forum (via text) without coming across as a know-it all jerk.
But that PCV valve - I'll give that a look! I want to get all the bases covered before I show up to the dealer complaining about an oil leak.
Old 11-03-2017, 05:12 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Don't assume it's the head gasket, because the head gasket is not under the intake plenum. If anything, head gasket leaks should be closer to the intake runners or cylinder heads.
http://www.ft86club.com/forums/showp...2&postcount=47
Old 11-03-2017, 06:27 PM   #9
Capt Spaulding
Persona Non Grata
The PCV explanation might be a winner.
Old 11-04-2017, 02:56 PM   #10
exE36M3
Yeah, not the PCV valve. No oil trace along the edges, not even damp, and the fitting is screwed in there pretty good.
Assuming you guys saw the photos - the oil trace still follows the line of the head gasket.
If it was the PCV valve, it would have soaked the paper towel differently.
Old 11-04-2017, 02:58 PM   #11
exE36M3
Sorry, my terminology could be more specific, in this case one can also say, intake runners.
The oil leak runs along the seam between the block and cylinder heads. I can see the edges of the metal head gasket.
Here's a photo from a legacy boxer motor. My leak runs the seam of the head gasket.
Thanks for the thread link too. His issue sound VERY similar, but from the front side of the motor.
Old 11-04-2017, 03:23 PM   #12
hmmmm.........I'm wondering if you sprayed some soapy water in the suspect area and fired up the engine, if bubbles would appear .......
Old 11-04-2017, 03:58 PM   #13
dutchman1
Drives: 2017 86 6-Speed
Pressure wash/steam clean the top of your engine, get it all shiny clean. Put some dye in your oil. Fire it up and stare at it with a good flashlight for however long it takes for oil to appear. Tada, you now know the source of your leak.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 11-06-2017, 11:54 AM   #14
exE36M3
Thanks guys for the ideas. I'm making an appointment with the master/lead tech this week. I put another paper towel on top of the head gasket seam. I'm going to drive with it this week so when I pull up, the lead tech can see the oil. As far as confirmation, Subaru already put a UV dye in it. That yellow-ish tint is the dye. I am sure between the oil soaked paper towel and dye, they should have enough to go on.
I hope anyway. I'll post again how this goes.
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 12:52 AM
Blown head gasket?? sachu Issues | Warranty | Recalls / TSB 14 07-15-2016 01:08 PM
Finally fixed the oil leak - Warning for those still using OEM drain plug/gasket. lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 02-25-2016 07:47 PM
Overpipe gasket exhaust leak THEWAKLER Engine, Exhaust, Transmission 19 11-29-2015 01:38 AM
Head Gasket leak? Carlsson Issues | Warranty | Recalls / TSB 8 10-23-2015 12:49 AM
