Drives: 13 Scion FR-S
Sparco Evo - Which size is right for me?
Hi guys,
I don't have much of a choice where I live to try out the Sparco Evo seat sizes to see which suits me best. I'm 5'8" tall, 131 lbs' and about a 30 waist. Small guy you can say. I'm looking into a regular Evo Medium seat as I believe the Evo II US or Evo III would be too large. Can anyone guide me in the right direction? Thanks Mike Sent from my SM-G930W8 using Tapatalk
Check out my build: Instagram @kawallito
#2 |
Drives: 15 BRZ LTD, 05 FXT
5'11" 200lbs, 34" waist and the Sparco Evo 2 is just right for me. I would say for a DD it would be too snug, but for a race car it's perfect. (It's not in my 86.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | FutureFT86 (11-01-2017) |
#3 |
Drives: Many
OP: The normal Evo is probably the one you want.
| The Following User Says Thank You to e1_griego For This Useful Post: | FutureFT86 (11-01-2017) |
#4 |
Drives: 2013 Ultramarine FRS
I run the Standard EVO in my car. I'm 5'11 with a 34 waist and the seat is snug for me. But it has been perfect for track use when I remove the cushion.
| The Following User Says Thank You to ChiTownFrs For This Useful Post: | FutureFT86 (11-01-2017) |
#5 |
I would recommend the Sparco REV if you're a smaller frame.
| The Following User Says Thank You to ryoma For This Useful Post: | FutureFT86 (11-01-2017) |
#6 |
Oh thanks never considered that one
| Sparco seat mount and Sparco sliders for FRS/BRZ | justinco | Interior Parts (Incl. Lighting) | 8 | 07-13-2016 07:35 PM |
| Sparco wheels | F3dzo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 05-19-2014 12:23 AM |
| sparco wheel help | ft86me | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-07-2013 11:24 PM |
| Think all tires of the same size ARE the same size? | Draco-REX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-26-2012 08:41 PM |
