| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
The PP would add some towards resale... but not the full $1300 or so, maybe half that. Kind of like adding nice wheels to your car, adds $500 ish .
If you don't track, or don't use breaks a lot, I don't see much point in going Brembo's. You could get the PP , then take off the Brembo brakes to sell as new (as I've seen some people do) which would recoupe some of the $1300 cost, then the suspension won't cost you that much. Just an idea. Offset the cost of the Sachs suspension, could be a great way to go. Not sure on how much OE brake calipers/rotors would then be?!
Math is like Love, simple idea at first that quickly gets complicated
#16 |
Drives: '17 BRZ PP, old Legacy SSs and SVXs
One thing that hasn't been mentioned yet but you deal with on every drive......
I have no direct BRZ comparisons, but from prior experience on other cars fixed 4-piston calipers (such as Brembos) give better brake feel and modulation control than the 'stock' sliding calipers. I'm in the 'no-brainer' camp. Upgraded wheels, shocks and brakes for $1200. For me, that $1200 saved me $3000-5000 in mods. |
| The Following 3 Users Say Thank You to PhyrraM For This Useful Post: |
#17 |
Panda Trueno
Drives: No twin now.
Honestly from the sound of your postings you need to be looking at an old Miata or civic or something if you want to get in to a daily with low cost and to learn about cars.
| The Following 3 Users Say Thank You to Summerwolf For This Useful Post: |
#18 | |
Drives: 2017 Subaru BRZ
But yeah this is something to consider, if only replacing brakes once every 30k or more, maybe the Brembos will be worth it. |
#19 | |
I scratched off the Miata completely (old or new) due to this being my only car and the Miata being a very impractical car. Also, by now I personally really didn't like it. I could go for used BRZ but I'm honestly leaning towards a new car for now and most likely keep it for a very long time. |
#20 | |
Panda Trueno
Insert any basic, old, easily repairable, cheap vehicle then. A newer camry / corolla might fit your needs as well if you want something newer. |
| The Following User Says Thank You to Summerwolf For This Useful Post: | rennlistuser3 (10-26-2017) |
#21 |
Senior gif poster
Drives: 2013 Asphalt FRS
A good amount of the miles are freeway but I do regular spirited B road driving also. I also never engine break, these cars are so light it really helps the brakes last.
#22 |
#23 |
Panda Trueno
#24 |
Drives: 2015 Series.Blue
The rest is in the rotor which if you can find a two piece rotor with an aluminum hat it will cut that weight a LOT. DBA, StopTech or some other company will likely come out with them soon.
#25 |
Drives: '17 BRZ Limited w/ PP|'17 Forester
The PP was an absolute no-brainer for me. I track my car, and the brakes, wheels, and Sachs shocks/struts are all great upgrades. Also, I don't believe anyone has mentioned how much faster and easier it is to change pads on the Brembos. No need to remove a caliper, simply pull a pin, retract the pistons, pull the old pads out the top and repeat the process backwards for the new pads. First time you change pads on the Brembos, you'll be thanking yourself for buying the PP.
| The Following 3 Users Say Thank You to Chris S For This Useful Post: |
#26 | |
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
The only real compromises that I see are the increased offset needed to clear the caliper face, increased pad cost from OEM and marginal increased weight. As long as the car (or tS) isn't re-classed in Solo II, it looks like a win/win in my book. |
| The Following User Says Thank You to dowroa For This Useful Post: | rennlistuser3 (10-29-2017) |
#27 |
Persona Non Grata
Drives: '15 BRZ (WRB)
I don't track my car, nor do I autox it. That said, for my $$ it's still a no brainer because it offers an incredible value for the dollar. I have no good reason to put a bbk on the car or to run out and buy higher end shocks and other suspension pieces, but if the factory will not only supply them, but install them for a fraction of the cost of adding them after market, I'm in.
Slow is smooth, and smooth is fast
| The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post: | dowroa (10-29-2017), rennlistuser3 (10-29-2017) |
#28 |
OP here
Thanks everyone for your valuable feedback, I ended up going for the performance pack after learning from people here that Brembo consumables are not that expensive through 3rd party and just as good if not better. Also, I did want that better suspension as well.. |
| Real STI BREMBO package upgrade - DIY | Trap63 | DIY (Do-It-Yourself) Guides | 40 | 06-15-2022 10:25 PM |
| FT86SF's Performance Package Brembo Info Thread | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 08-13-2019 05:11 AM |
| Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue | DaJo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 09-25-2018 06:12 PM |
| Do you think Scion will offer something similar to Miata's Brembo/BBS package? | FRSW12 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 09-17-2015 05:09 PM |
| Aero package Worth It?? | Djen | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 06-14-2013 11:48 PM |
