Old 10-31-2017, 02:14 PM   #1
Terruko
Terruko's Avatar
5th gear grinding got worst
Took my FR-S into the dealership a couple months ago because my 5th gear would grind, and they replaced this.
And a few days later after I got the car back the grinding returned, and a month later and the grinding is now worse than before.
Terruko is offline   Reply With Quote
Old 10-31-2017, 02:17 PM   #2
So take it back. What they changed would not affect grind.
Terruko (10-31-2017), Teseo (11-01-2017)
Old 11-01-2017, 01:17 AM   #3
Well, without looking up those parts, I would agree with @Tcoat ....... it looks like they just patched around the problem.
@Ultramaroon , what do you think .. ??
Old 11-01-2017, 02:08 AM   #4
I agree with you guys. Looks like they removed the extension housing, poked around a bit, and replaced a couple parts that didn't look brand new.
Nothing to do with gear grind.
humfrz (11-01-2017), Terruko (11-01-2017)
Old 11-01-2017, 03:44 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Fuckers didn't even changed the tranny oil.
Unless it's not listed to which I say take it back either way.
Old 11-01-2017, 04:07 AM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
just get some motul transmission fluid and tell them to put that in.
How old and what year/how many mile you have on your frs? if it's pretty old and just started doing that then it's a different story.
Old 11-01-2017, 04:17 AM   #7
Terruko
Terruko's Avatar
They did changed the transmission oil.
Old 11-01-2017, 04:18 AM   #8
Terruko
Terruko's Avatar
It’s a 10 series with 65k miles on it.
Old 11-01-2017, 04:24 AM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
send it back to dealer and like tcoat said.
The Following User Says Thank You to chaoskaze For This Useful Post:
Old 11-01-2017, 04:25 AM   #10
Terruko
Terruko's Avatar
What’s funny is that the service rep told me the synchros was replaced until the end, but then I got the papers and noticed that they didn’t replaced it but since the grinding was gone I didn’t even mention it.
Old 11-01-2017, 09:13 AM   #11
bababooey
Drives: BRZ SWP Limited -6MT
could it be they were attempting to fix 5th & not ---> (fifth).
lmao the effort to spell the other numbers
bababooey is offline   Reply With Quote
Old 11-01-2017, 09:58 AM   #12
stevesnj
stevesnj's Avatar
Take it back until it's not worst.
My 2016 Build thread
Old 11-01-2017, 12:10 PM   #13
extrashaky
Drives: 2014 BRZ Limited
Maybe they fixed "secong gear" instead.
The Following User Says Thank You to extrashaky For This Useful Post:
bababooey (11-01-2017)
Old 11-01-2017, 01:06 PM   #14
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Make sure they used the correct oil. I went to a Scion/Toyota dealership for warranty transmission work and they refilled the transmission with Subaru GL5 transaxle lube. Wrong, wrong, wrong.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Tcoat (11-01-2017)
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
5th gear grinding Bernie Issues | Warranty | Recalls / TSB 1 05-15-2015 07:10 AM
6th gear grinding D-VO Issues | Warranty | Recalls / TSB 59 04-07-2015 01:26 PM
Grinding in 3rd gear...what's going on?! hozouria Engine, Exhaust, Transmission 3 08-13-2014 01:31 PM
6th Gear Grinding KpAtch3s Issues | Warranty | Recalls / TSB 0 06-18-2013 07:07 PM
