#827 |
Drives: Black Limited JDM BRZ
Can anyone help with a definition for JDM 2012 MT ZA1J700A?
I did some research and unfortunately there's very little information available on ZA1J700A. From what I found (http://minkara.carview.co.jp/userid/...262/parts.aspx), this ROM is compatible with ZA1JA01A (and possible ZA1JA02A). I managed to read it using ZA1JA01A definition, however not sure how save this solution would be. Any advice is highly appreciated.
#828 | |
Drives: FT86
Reading amd writing is pretty safe as all roms from all countries are same basic size amd flashmethod. However editing is different story defs must match exactly. If you want to tune the car you might want ro try flashing a A01G from australia\europe their is rearly good definitions for that rom series and its highly likely it will run fine in your car. If theirs any dramas jist make sure you keep a copy of your A series rom to flash back. Last edited by steve99; 10-29-2017 at 07:44 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | In1t (10-30-2017) |
#829 |
Drives: Toyota 86 GTS
+1. make your life easy, switch to A01G
| The Following User Says Thank You to Wayno For This Useful Post: | In1t (10-30-2017) |
#830 | |
Do you guys have any experience using OFT roms with OpenPort 2 cable?
#831 |
StreetKart
Drives: 2014 Scion FR-S Monogram
So I've bent my pins in and haven't noticed any connection losses yet I'm still getting a ton of log files during one drive. I have no issues running a Bluetooth odb2 logger with torque but this always has issues. Here's a link to my files from a 30ish minute drive.
https://drive.google.com/folderview?...AsAd-jH69D2O3m
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#832 |
Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging
I had the same problem on mine. Bending pins didn’t help much either. A heavy rubber band seemed to help. I ended up getting a 6ft extension and ran it into the glovebox so it’s easier to access and it has a solid connection.
Here is the exact cable I ordered: https://www.amazon.com/dp/B0716RW33M |
#833 | |
Drives: FT86
#834 |
StreetKart
i only have the trigger for if rpm over 0. I was under the impression that you had to have that otherwise it wouldnt log. the rear defroster trigger is 100% worthless i know that.
#835 | |
Drives: FT86
Just either plug in tactrix, or switch power on to it via switched cable when i want to log If it creates a bunch of log files like that its likely the connection to obd port is intermittent. Try bending both roms of pins inwards, use say an old SD memory card so you keep the pins in straight line, onlt need to bend them vert slightly like 0.5mm or so |
#836 |
Triggers never worked for me either. When no triggers are set it logs at all times. I do however log the defogger switch and use it to tag the parts of the log I am interested. I then use a PowerShell script to extract the parts of the log that have the defogger enabled into individual log files.
#837 | |
Drives: GT86
#838 | |
Drives: GT86
Here you are: Code:
;-------------FREERUNNERS "ZA1JA01G" CONFIG------------ type = obd protocolid = 6 mode23txaddrwidth = 4 mode23txlenwidth = 1 mode23rxaddrwidth = 0 mode23uds = 1 sortpids = 1 calcsampinterval = 1000 ;debug=noout ;-----------DESCRIPTION-------------------- ; Notice that the next 3 parameters have a "sampgroup = X" setting. ; There are 15 sample groups (1 - 15) that you can assign parameters to. ; Any parameters assigned to a sample group will be alternately logged in a single ; timeslot at a lower speed, the speed being 1 / N that of the sampling interval - ; where N is the number of parameters in the sample group. In this example, these ; 3 parameters will be logged at 1/3 the speed, but will also use 1/3 of the communications ; to the ECU, allowing you to log everything else faster. ; Since you can make up multiple sample groups, you can fine tune how fast different kinds of ; parameters are logged. ;-----------LOGGING PARAMETERS------------- paramname = IAM paramid = 0xFFF8119C isfloat = 1 sampgroup = 2 paramname = MAF_V paramid = 0xFFF842AC databits = 16 scalingrpn = x,0.000076293945,* paramname = MAP paramid = 0xFFF87C60 isfloat = 1 ;scalingrpn = x,0.133322368,* scalingrpn = x,0.00133322368,* ;log MRP (psi relative sea level): ;scalingrpn = x,760,-,0.01933677,* paramname = IAT paramid = 0xFFF87C64 isfloat = 1 sampgroup = 2 ;paramname = WaterTemp ;paramid = 0xFFF87C68 ;isfloat = 1 ;sampgroup = 2 ;paramname = BattVolt ;paramid = 0xFFF87C6C ;isfloat = 1 paramname = MAF paramid = 0xFFF87C70 isfloat = 1 ;-------------FREERUNNERS "ZA1JA01G" CONFIG------------ type = obd protocolid = 6 mode23txaddrwidth = 4 mode23txlenwidth = 1 mode23rxaddrwidth = 0 mode23uds = 1 sortpids = 1 calcsampinterval = 1000 ;debug=noout ;-----------DESCRIPTION-------------------- ; Notice that the next 3 parameters have a "sampgroup = X" setting. ; There are 15 sample groups (1 - 15) that you can assign parameters to. ; Any parameters assigned to a sample group will be alternately logged in a single ; timeslot at a lower speed, the speed being 1 / N that of the sampling interval - ; where N is the number of parameters in the sample group. In this example, these ; 3 parameters will be logged at 1/3 the speed, but will also use 1/3 of the communications ; to the ECU, allowing you to log everything else faster. ; Since you can make up multiple sample groups, you can fine tune how fast different kinds of ; parameters are logged. ;-----------LOGGING PARAMETERS------------- paramname = IAM paramid = 0xFFF8119C isfloat = 1 sampgroup = 2 paramname = MAF_V paramid = 0xFFF842AC databits = 16 scalingrpn = x,0.000076293945,* paramname = MAP paramid = 0xFFF87C60 isfloat = 1 ;scalingrpn = x,0.133322368,* scalingrpn = x,0.00133322368,* ;log MRP (psi relative sea level): ;scalingrpn = x,760,-,0.01933677,* paramname = IAT paramid = 0xFFF87C64 isfloat = 1 sampgroup = 2 ;paramname = WaterTemp ;paramid = 0xFFF87C68 ;isfloat = 1 ;sampgroup = 2 ;paramname = BattVolt ;paramid = 0xFFF87C6C ;isfloat = 1 paramname = MAF paramid = 0xFFF87C70 isfloat = 1 paramname = OilTemp paramid = 0xFFF87C74 isfloat = 1 sampgroup = 3 paramname = Port_IPW paramid = 0xFFF887C8 isfloat = 1 scalingrpn = x,0.001,* ;paramname = Direct_IPW_0 ;paramid = 0xFFF887E8 ;isfloat = 1 paramname = Direct_IPW paramid = 0xFFF887F0 isfloat = 1 paramname = Throttle paramid = 0xFFF89030 isfloat = 1 ;paramname = TipIn ;paramid = 0xFFF89038 ;isfloat = 1 paramname = Load paramid = 0xFFF89148 isfloat = 1 paramname = Accelerator paramid = 0xFFF8922C isfloat = 1 paramname = AFR paramid = 0xFFF8932C isfloat = 1 scalingrpn = x,14.7,* ;paramname = FuelPress ;paramid = 0xFFF8936C ;isfloat = 1 paramname = Defogger paramid = 0xFFF89393 databits = 8 isvisible = 1 sampgroup = 2 paramname = Speed paramid = 0xFFF893C4 isfloat = 1 sampgroup = 2 paramname = RPM paramid = 0xFFF893EC isfloat = 1 ;paramname = AF_Corr_3 ;paramid = 0xFFF8A860 ;isfloat = 1 ;scalingrpn = x,100,* ;paramname = AF_Learn_3 ;paramid = 0xFFF8A8A0 ;isfloat = 1 ;paramname = Tip_In_Enrich ;paramid = 0xFFF8AB08 ;isfloat = 1 paramname = TotTiming paramid = 0xFFF8ACF4 isfloat = 1 ;paramname = BaseTiming ;paramid = 0xFFF8AD70 ;isfloat = 1 ;paramname = KCA ;paramid = 0xFFF8AFA8 ;isfloat = 1 paramname = FBKC paramid = 0xFFF8AFAC isfloat = 1 paramname = FLKC paramid = 0xFFF8B048 isfloat = 1 ;paramname = FLKC_Offset ;paramid = 0xFFF8B066 ;databits = 8 ;scalingrpn = x ;paramname = vvt_intake_r ;paramid = 0xFFF8BF80 ;isfloat = 1 ;scalingrpn = x paramname = vvt_intake_l paramid = 0xFFF8BF84 isfloat = 1 scalingrpn = x ;paramname = vvt_exhaust_r ;paramid = 0xFFF8BFC8 ;isfloat = 1 ;scalingrpn = x paramname = vvt_exhaust_l paramid = 0xFFF8BFCC isfloat = 1 scalingrpn = x paramname = STFT paramid = 0xFFF8D250 isfloat = 1 paramname = LTFT paramid = 0xFFF8D254 isfloat = 1 ;paramname = FuelLev ;paramid = 0xFFF8D28C ;isfloat = 1 ;sampgroup = 9 ;paramname = AmbPress ;paramid = 0xFFF8D290 ;scalingrpn = x,0.00133322368,* ;isfloat = 1 ;paramname = Cat_Temp ;paramid = 0xFFF8D298 ;isfloat = 1 ;sampgroup = 9 paramname = AFR_CMD paramid = 0xFFF8D2AC isfloat = 1 scalingrpn = x,14.7,* paramname = CL_OL paramid = 0xFFF8D2E2 databits = 8 scalingrpn = x ;-----------CALCULATIONS------------- type = calc paramname = VVT_overlap scalingrpn = vvt_intake_l,vvt_exhaust_l,+,3.5,- ;type = calc ;paramname = AFR_Error ;scalingrpn = AFR,AFR_CMD,/,100,* ;-------------TRIGGERS--------------- ;---- START LOGGING IF ENGINE RUNNING ;conditionrpn = RPM,0,> ;action = start ;conditionrpn = RPM,0,== ;action = stop ;---- START LOGGING ON DEFOGGER ;conditionrpn = Defogger,1,== ;action = start ;conditionrpn = Defogger,0,== ;action = stop ;---- START LOGGING IF ENGINE WARM conditionrpn = OilTemp,80,> action = start conditionrpn = OilTemp,76,< action = stop |
#839 |
You have your trigger set to OilTemp but the paramid for OilTemp is missing. Maybe it is working for you because it’s dropping the miss-configured trigger and you’re actually logging all the time.
Or maybe you just didn’t post your entire config... or maybe I am blind (reading on my phone) and OilTemp is in there somewhere. Hahaha |
#840 |
Drives: GT86
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
