Old 10-25-2017, 10:45 PM   #1
sid94
Drives: 2013 frs
Car won't hold idle after basemap tune
Hello
I have a full blown stage one that I got off someone from the forums he sent me the base map and gave me the ecutek with the kit. I can't remember what year his was but I'm pretty sure it was a 17. I bought the licence and after I installed the kit and loaded up the base map the car won't hold idle. The have the fbm 270s fuel pump installed as well.
Would the base tune for a 2017 not work on my 2013 because of the different intake manifold?
Trying to drive my car again
sid94 is offline   Reply With Quote
Old 10-26-2017, 03:27 AM   #2
CSG Mike
CSG Mike's Avatar
You need a tune that matches YOUR car.
CSG Mike is online now   Reply With Quote
Old 10-26-2017, 08:45 PM   #3
sid94
Drives: 2013 frs
I was going to purchase a base tune from full blown to be able to drive around for now until I get my clutch and boost controller so that I can tune for 12psi
Or would you say it's better to tune now for 7psi then after do a retune after everything
Old 10-28-2017, 11:53 AM   #4
JoeeStacks
Drives: Brz
Better to tune for 7 psi. Then retune after you have all your parts.
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG
Old: Kraftwerks Supercharged Subaru Brz
JoeeStacks is offline   Reply With Quote
Old 10-28-2017, 06:32 PM   #5
sid94
Drives: 2013 frs
I bought the base map from full blown so I can drive for now. It takes a while to start. At first it didn't hold idle but I took it for a drive around the neighbor hood and it holds it now but it still takes long to start. Now another issue I'm having is that after it's warmed up if I turn it off then back on then my throttle won't respond and it idles for a few then dies out. I emailed full blown but probably won't get a response any time soon.
Any help is appreciated
Old 10-28-2017, 07:39 PM   #6
JoeeStacks
Drives: Brz
I think your ecu needs to “learn” / calibrate for the idle issue. But I’m not sure for the start up. Maybe you have a boost leak somewhere? Did you clamp the hoses under the intake manifold?
Old 10-28-2017, 08:02 PM   #7
sid94
Drives: 2013 frs
Yes I did. I clamped the ones on the evap solenoid and on the manifold along with the pcv hose going into the block. I checked them all and found none were leaking. I think I might be having a fuel pressure issue. I can literally have my pedal on the floor and nothing
Old 10-29-2017, 12:44 PM   #8
sid94
Drives: 2013 frs
So this morning I drove the car and it felt fine. Pretty sure my waste gate is no good. On idle I feel exhaust gasses coming out the dump and slightly sounds like a exhaust leak which would explain why my wideband reads lean
Super High LTFT +36.77% at idle? (E85 with OFT tune) D4FD Software Tuning 11 09-05-2017 02:24 PM
AVO Basemap handsomegirl Forced Induction 3 07-20-2016 08:23 AM
Possible to tune car a bit louder at idle/low rpm? cawith Software Tuning 14 04-18-2016 08:39 AM
Which tune can hold redline? Turbo Den Software Tuning 10 11-12-2013 02:32 PM
Unable to hold idle. CSG Mike Issues | Warranty | Recalls / TSB 22 05-20-2013 06:00 PM
