Old 10-26-2017, 08:22 PM   #15
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by Zer0 View Post
New it's a swap I don't want anything uncertain if I had issues at start up I would suspect the engine if it were used, or the builder if it we're a fully built motor from a shop. I might consider a fully forged unit from a shop but getting it to pass the ref in California would be impossible. At least with stock I have a chance. Your build is sick to @DustinS.
Let's let them have their thread back.
If LT4s come down in price I'd be all about doing it, but I haven't seen them for less than 10k. I can barely get people to do swaps using 2k engines lol. I sent my MoTeC dev an email just to make sure it's not something I can do for you easily. I'll let you know if I hear good news.
Pure Automotive is offline   Reply With Quote
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
ILLSMOQ (10-26-2017), Zer0 (10-26-2017)
Old 10-26-2017, 09:13 PM   #16
Zer0
Drives: 2015 frs
Excellent. It won't need to communicate with the FRS can bus systems as most are eliminated. I just need the AC, power steering, motorsports traction control without the abs unit, and engine. You know the easy stuff lol. Any information helps.
Zer0 is offline   Reply With Quote
Old 10-27-2017, 11:22 AM   #17
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
you still have to have the canbus communication to run the power steering ecu, and that will not work without a working abs module since the wheel speeds are sent to the abs unit then broadcast over canbus
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Pure Automotive (10-28-2017)
Old 10-27-2017, 05:14 PM   #18
Zer0
Drives: 2015 frs
Yeah it will get a false signal to get power steering it won't be variable like stock. Later on I will work on a variable torque output based on the speed sensor in the transmission.
Old 11-15-2017, 05:32 PM   #19
Pure Automotive
Another 2JZ Swap Going Down.... This time is VVTi and CD009 ! I'll probably start a new thread, keep an eye out for Budget Swap 2.0
IMG_3098 by Brady Johnson, on Flickr
ILLSMOQ (11-15-2017), Zer0 (11-15-2017)
Old 11-24-2017, 01:29 PM   #20
Pure Automotive
www.swapyour86.com
Black Friday- Cyber Monday !!!
The Following User Says Thank You to Pure Automotive For This Useful Post:
ILLSMOQ (11-24-2017)
Old 11-25-2017, 10:48 AM   #21
Pure Automotive
[ame]http://youtu.be/GQPAaUAOaSc[/ame]
Old 12-13-2017, 11:02 PM   #22
Stevemode
Stevemode's Avatar
Drives: "Baby Gurl" of FBM
Stopped by Pure Automotive a couple months ago when I was in town. A very cool shop doing awesome things for exactly what I'm building. Brady took the time to give my son and I the tour and I only wished I had the funds to ship one of everything right then and there. In do time it will be done.
Stevemode is offline   Reply With Quote
Old 12-14-2017, 05:06 PM   #23
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by Pure Automotive View Post
Very strange in the video it shows the rear diff with rear mount with OEM bushings and bolts removed, am I missing something here, it doesnt seem like they are working on it....i.e. bolts missing.....and why with all that power OEM bushings? Most guys with this much power have a solid mount.
cf6mech is offline   Reply With Quote
Old 12-15-2017, 09:52 AM   #24
spitfire481
Drives: 2JZ FRS
It has a 9" in it. We don't use the rear mount locations, we have different mounts welded to the rear subframe
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
cf6mech (12-23-2017), DustinS (12-15-2017)
Old 12-15-2017, 09:54 AM   #25
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
You can see the diff mount.
The Following User Says Thank You to DustinS For This Useful Post:
Old 01-09-2018, 12:47 PM   #26
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
you're not going to pass the ref in California with a motec period..
Cali swaps require you to use the stock ecu. No Motec, MS's, etc allowed...
Jaden
Jaden is offline   Reply With Quote
Old 01-09-2018, 09:54 PM   #27
Zer0
Drives: 2015 frs
Jaden
It will run off a stock GM ECU with a stock tune.
Old 01-09-2018, 11:38 PM   #28
Jaden
Road-hole
Then pure automotive isn't your solution
Pure Automotive's PnP option uses a Motec 150, so you'll have to use one of the other solutions.
Jaden
FR-S and BRZ Exhaust Compilation Thread Spd229 Engine, Exhaust, Transmission 665 03-06-2026 07:58 AM
PURE RED BRZ (M7Y) Compilation Vdub BRZ Photos, Videos, Wallpapers, Gallery Forum 60 09-10-2025 02:13 PM
Engine Swap Compilation ichitaka05 Engine Swaps 27 02-19-2024 12:37 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
