Old 10-20-2017, 11:01 AM   #4215
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
It is! I'd recommend a 6500 RPM redline with it on a C30.
Point of clarification: Same belt is specified for use with 110/100/90 pulleys?
I assume the included bracket positions the head unit slightly lower to maintain the same tension with the smaller pulley?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 10-20-2017, 11:41 AM   #4216
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Sorry if I missed it, what is the maximum expected PSI with this pulley?
SpectreRT is offline   Reply With Quote
Old 10-20-2017, 05:28 PM   #4217
CSG Mike
CSG Mike's Avatar
It depends on your setup. A built engine is mandatory unless you have a highly unusual need.
Old 10-21-2017, 12:26 PM   #4218
ExpertZero
Drives: FR-S 2015 Halo
any updates on this ? jw
Originally Posted by mrg666 View Post
I still hear boost is released at idle and when accelerator is released. But it sounds and feels a more gradual (not sudden) boost release. The engine feels smoother to me. Would you be interested checking this out over there?
I think this is what you are pointing out. I am quoting from the Rotrex manual:
"If you choose to position the throttle body downstream, a re-circulation valve is
recommended. If the valve is omitted the supercharger will create noise under deceleration caused by surge.
Surge occurs when the supercharger keeps making pressure at low airflow forcing the compressor to work
outside the intended operation area. This will be most noticeable on high boost applications under high
engine rpm with the throttle closed (deceleration). The re-circulation valve will prevent surge by allowing air
to circulate from the pressure side of the supercharger to the inlet side of the supercharger under manifold
vacuum conditions."
The supercharger was making more noise under sudden deceleration with the stock valve.
ExpertZero is offline   Reply With Quote
The Following User Says Thank You to ExpertZero For This Useful Post:
mrg666 (10-21-2017)
Old 10-21-2017, 01:50 PM   #4219
mrg666
pessimistic skeptic
mrg666's Avatar
I am still using the stiffest spring (yellow) in the recirculation valve.
- With the stiff spring, recirculation valve closes earlier at lower vacuum level when I want to accelerate. This boosts the engine at lower rpm, gives better throttle response, and noticeably higher power at lower rpm.
- Recirculation valve opens later (at higher vacuum) when I release throttle in deceleration. I feel that the compressor is making less noise on sudden release of throttle. Take this with a grain of salt since this is my interpretation: I think the surge is less on the compressor during deceleration and compressor is happier.
I went back to softer spring for a day to make sure this is not all placebo. Nope, I have installed the stiffest spring back and I am definitely not making all these up.
CSGMike said that he is going to test what I posted here. But it is not an expensive piece to test if you want to see yourself. I think RKX valve is higher quality than the plastic valve anyway.
The Following User Says Thank You to mrg666 For This Useful Post:
ExpertZero (10-21-2017)
Old 10-21-2017, 04:02 PM   #4220
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
I’m curious to hear not only what Mike has to say but also if the JR folks have thoughts on this.
keithr is offline   Reply With Quote
Old 10-21-2017, 04:17 PM   #4221
mrg666
pessimistic skeptic
mrg666's Avatar
Me too. I don't know a nearby tuning shop to go for a dyno test. Anybody knows one in the Capital District?
Old 10-23-2017, 10:36 AM   #4222
RFB
RFB's Avatar
Drives: FRS
JRSC at max boost, high boost pulley, built engine, what compression ratio pistons would you recommend ?
RFB is offline   Reply With Quote
Old 10-23-2017, 12:02 PM   #4223
SPCorBUST
SPCorBUST's Avatar
12.5, but I might be biased.
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 10-23-2017, 12:57 PM   #4224
CSG Mike
CSG Mike's Avatar
Short answer: the highest your fuel will allow
Long answer: It depends. How much other work are you doing to your "built engine"? Rods and pistons do not really check the boxes for me for a "built engine".
Old 10-24-2017, 02:00 AM   #4225
ExpertZero
Hmmm interesting.
Can you PM me links to everything you're using?
I'm curious to try.
By any chance, did you purchase the bpv & tested it? jw
keithr (11-01-2017)
Old 10-25-2017, 10:27 AM   #4226
RFB
RFB's Avatar
Drives: FRS
"Built engine"
- new cp rods, manley pistons or similar, new bearings, new crank shaft, machined and assembled heads hot tank, crack checked, decked, new valve seals, custom angle seat and grind, ferrea intake and exhaust valve, dual valve springs, titanium retainers.
High flow fuel pump 1000c.c. injectors.
Jackson supercharger, hi-boost pulley-
Which compression ratio would you recommend for max h.p. and max reliability?
Old 10-25-2017, 03:14 PM   #4227
CSG Mike
CSG Mike's Avatar
"Built engine"
What fuel will you be using?
I recommend going as high as you can. Your question is best answered by your tuner and engine builder. In my case, I can run full time E85 with E98 and Q116 available to me readily. I would run 13.5+.
Old 10-25-2017, 03:16 PM   #4228
RFB
RFB's Avatar
Drives: FRS
How high with 94 ?
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
