#4215 |
Drives: 2013 FRS / 2013 427 Vert
Point of clarification: Same belt is specified for use with 110/100/90 pulleys? I assume the included bracket positions the head unit slightly lower to maintain the same tension with the smaller pulley?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned Last edited by Deep Six; 10-20-2017 at 06:29 PM. |
#4216 | |
Drives: Subaru BRZ
#4217 |
#4218 | |
Drives: FR-S 2015 Halo
any updates on this ? jw
#4219 |
pessimistic skeptic
I am still using the stiffest spring (yellow) in the recirculation valve.
- With the stiff spring, recirculation valve closes earlier at lower vacuum level when I want to accelerate. This boosts the engine at lower rpm, gives better throttle response, and noticeably higher power at lower rpm. - Recirculation valve opens later (at higher vacuum) when I release throttle in deceleration. I feel that the compressor is making less noise on sudden release of throttle. Take this with a grain of salt since this is my interpretation: I think the surge is less on the compressor during deceleration and compressor is happier. I went back to softer spring for a day to make sure this is not all placebo. Nope, I have installed the stiffest spring back and I am definitely not making all these up. CSGMike said that he is going to test what I posted here. But it is not an expensive piece to test if you want to see yourself. I think RKX valve is higher quality than the plastic valve anyway. |
#4220 | |
Drives: 2014 BRZ Limited (DGM)
I’m curious to hear not only what Mike has to say but also if the JR folks have thoughts on this. |
#4221 |
pessimistic skeptic
#4222 |
Drives: FRS
#4223 | |
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#4224 | |
Long answer: It depends. How much other work are you doing to your "built engine"? Rods and pistons do not really check the boxes for me for a "built engine". |
#4225 |
#4226 | |
Drives: FRS
- new cp rods, manley pistons or similar, new bearings, new crank shaft, machined and assembled heads hot tank, crack checked, decked, new valve seals, custom angle seat and grind, ferrea intake and exhaust valve, dual valve springs, titanium retainers. High flow fuel pump 1000c.c. injectors. Jackson supercharger, hi-boost pulley- Which compression ratio would you recommend for max h.p. and max reliability?
#4227 | |
I recommend going as high as you can. Your question is best answered by your tuner and engine builder. In my case, I can run full time E85 with E98 and Q116 available to me readily. I would run 13.5+. |
#4228 |
Drives: FRS
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
