#29 |
Drives: for the sake of driving
After being a tech at a dealership for 3 years, I can say that the most common phrase I've come to hear is: "it's not my car, why should I care?". That is the reason why I do everything myself, unless I ABSOLUTELY have to take it elsewhere.
'13 Argento FR-S
#30 | |
Drives: 2013 Scion FR-S Firestorm Red MT
I would think with a heat gun the bumper could be warmed up and set back in place, the crack super-glued, perhaps given a little Bondo putty to any existing cracks, sanded down a bit, primed, and painted relatively easily. You'd only have to get about a couple inches on both sides of the crack to 'blend' it and that's so low on the bumper where it'd probably be unnoticeable. The only question I have is how whiteout's pearl-esque property factors in when painting. But really, if you get the paint code it's a spot-on match if you spray it.
#31 |
Drives: Ducati R Corse
OP should have them order in from Japan a factory painted bumper. So much easier. Be present to watch them install it, and free breakfast for his time.
#32 | |
Drives: Limited WRB AT6 BRZ
#33 | |
Wiring Nerd
Drives: 1994 Supra
Doesn't the factory offer pre-painted components?
Looking for BRZ FR-S in Wake County NC for testing. PM me. |
#34 | ||
#35 |
Drives: truck and old car
#36 |
True, if they are going to already order you a new bumper, I'm pretty sure it comes pre-painted from the OEM. The cost of it that way surely would be cheaper than it unpainted and then having to pay for a paint job afterwards.
#37 |
Drives: accord
#38 |
Drives: accord
but a new bumber wont have the same number as rest of the car. this is a tall tail sign that the car have body damage. some area can actually find this out, and it will drop the value of the car.
#39 |
Drives: G35
^ I had a 94 Sentra SE-R that got smacked in the rear bumper by some lame driver making a turn and didn't see me GOING STRAIGHT. Since it was on her dime, I took it to a Nissan dealer and they said they can repaint the bumper but the quality wouldn't be like factory because "the factory must have some special method of getting the paint to really adhere to the bumper because we can never quite match the quality of an OEM painted bumper." Of course this was 2004 so things may have improved. I personally would hold out for a factory-painted bumper. |
#40 |
Just because it gets painted at the factory doesn't mean it's going to match perfectly. Durability may be better than a body shop paint job, but the replacement bumper cover certainly won't be painted with the same 'batch' of paint your car was originally painted with. As a matter of fact, some of the pictures I've seen on here of the white pearl paint appear that the bumper covers (front & rear) don't match the body perfectly right from the factory and part of that is because the flexible bumpers have an additive in the paint to allow flexibility and they are prepped for paint differently and are not painted while installed on the car.
#41 |
Drives: VW R32
Usually the best method when feasible is to have the panel repaired as opposed to replaced if it is a numbered part and can be done adequately. The second best thing is have panel swapped out if the factory can do the finish work(ie. prepainted part from Gunma). Thirdly, would be to select a body shop of YOUR CHOOSING and have it repaired. Lastly, is to have the dealer use their "pet body shop" or have the in house guys do it. I would suggest having your insurance Co. get involved also. I have had this type damage happen more than once (new 1986 Saab Turbo, new 2007 Lotus Elise). The dealer should get some kudos for pointing out the damage as opposed to letting you think it was your fault (if they did in fact). A thank you here will go a long way.
Don't be attitudinal with the dealer. Be firm direct and to the point but not an ass. They may owe you something but nobody likes to loose face, money or feel belittled, not you, not them. Sorry if this all seems disjointed, I'm on my third double shot of esspresso and i can a thread a sewing machine while it's still running... |
#42 |
Drives: Toyota Tacoma
Take it to pro repair shop. Its still a new car so it should be near 100% quality fix. Then get free service or parts from the dealer. Dont stress, sucks but life happens. Maybe aftermarket kit?
| Service Manual Availability | RYU | BRZ First-Gen (2012+) — General Topics | 33 | 06-11-2012 05:00 PM |
| Service needed after the second day | Carlsbad | BRZ First-Gen (2012+) — General Topics | 15 | 06-04-2012 03:34 AM |
| A Public Service Announcement. | Guff | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 04-21-2012 02:26 AM |
