Old 10-23-2017, 01:43 PM   #29
Icecreamtruk
Drives: Track preped NA FRS
Can a technically savvy person explain why having light pulleys and flywheel is bad for the engine? What, does it slow down too fast?
You cant lump the flywheel and crank pulley in the same boat. The crank pulley is used (aside from feeding the other pulleys like the alternator and AC compressor) to balance out the engine vibrations. So there is weight, distributed in such a way that the engine will vibrate less, or at least in a more stable way. Making it lighter lets the engine rev faster, but not by a whole lot, and usually has more negatives than it has positives (when you consider the main positive is "it looks pretty cuz its colored" thing.
Lighter flywheel do nothing in regards to vibration, all the flywheel does is smooth out the engine output by storing energy. The engine doesnt produce a stable constant output, its rather in pulses, each explosion in a cylinder is a pulse of energythat goes down your drivetrain. A lighter flywheel will let your engine rev faster as well, but this time with a much more dramatic inpact than the pulley. While you may save 1 or 2 lbs on the crank pulley, you can save over 10lbs on the flywheel. I have a ACT flywheel which is around 11lbs lighter than stock (I think), and the engine does rev up and down much faster than before. It doesnt make the car any quicker, it makes hill starts a bit harder, but it also makes rev-matching a lot easier, which is what I wanted out of it (as well as a few lbs of the car's curb weight). There isnt any real danger that I know of to get a lightweight flywheel for this car (cannot confirm or deny the same for the crank pulley).
Icecreamtruk is offline   Reply With Quote
The Following 7 Users Say Thank You to Icecreamtruk For This Useful Post:
Cole (10-23-2017), CSG Mike (10-23-2017), mrg666 (10-23-2017), Spawn_Of_Creation (10-24-2017), StraightOuttaCanadaEh (10-23-2017), strat61caster (10-23-2017), Teseo (10-23-2017)
Old 10-23-2017, 05:33 PM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Lakitu View Post
Correct me if I'm wrong, but this mod is more for racing and not for daily driving while trying to also stay under warranty, correct?
This mod is purely for creating endless posts on forums. Do the search.
Cole (10-23-2017)
Old 10-23-2017, 05:41 PM   #31
CSG Mike
CSG Mike's Avatar
Best crank pulley is a fluidampr, which is heavier than stock.
http://counterspacegarage.com/fluida...a20-4usge.html
The Following 8 Users Say Thank You to CSG Mike For This Useful Post:
Cole (10-23-2017), Hawk77FT (10-23-2017), JazzleSAURUS (10-25-2017), Jonsey (10-24-2017), mrg666 (10-23-2017), Somerandom18 (10-23-2017), Spawn_Of_Creation (10-24-2017), Yoniyama (10-28-2017)
Old 10-23-2017, 05:48 PM   #32
empower-auto
Kouki-Monster
empower-auto's Avatar
My god, thank you.
I was reading page one of this thread and ready to headbutt my monitor.
Fluidampr 100%
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
pgranberg11 (10-23-2017)
Old 10-23-2017, 06:15 PM   #33
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Fluid Dampr... done.
pgranberg11 is offline   Reply With Quote
Old 10-23-2017, 06:50 PM   #34
Hawk77FT
Drives: GTS 86
Had Perrin, then raceseng..then Fluidampr! So far so good!
Hawk77FT is offline   Reply With Quote
Old 10-23-2017, 08:06 PM   #35
Somerandom18
Drives: 2017 manual BRZ
Same. Had the Perrin for 500 miles then went Fluidampr. Way better.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 10-23-2017, 09:08 PM   #36
mrg666
pessimistic skeptic
mrg666's Avatar
I would put back those OEM pulleys if not the Fluidampr
[ame]http://youtu.be/G6qrJPQw0Cs[/ame]
The Following User Says Thank You to mrg666 For This Useful Post:
Old 10-23-2017, 09:09 PM   #37
churchx
churchx's Avatar
Drives: 2014 GT86
How about 10% underdrive ATI one?
Old 10-23-2017, 09:11 PM   #38
Somerandom18
I hear underdrive damages the alternator. Could just be a rumor though.
Old 10-23-2017, 10:05 PM   #39
Captain Snooze
Drives: Red Herring
In what way?
Old 10-23-2017, 10:07 PM   #40
Somerandom18
In what way?
Engine felt smoother. Shifting was different/easier. Oddly enough the car felt more responsive high in the power band.
Old 10-23-2017, 11:44 PM   #41
NRXRaptor
In subarus (and for a particular toyota as well) the crank pulley does not act as a harmonic dampener
NRXRaptor is offline   Reply With Quote
Old 10-23-2017, 11:47 PM   #42
NRXRaptor
Obviously there are greater gains to be made with a lighter flywheel, but obviously the crankshaft pulley is much easier to remove in your driveway than a flywheel
Crank Pulley - How do they work? Ray_32 Engine, Exhaust, Transmission 34 05-10-2015 12:55 AM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 11:12 AM
Kartboy crank pulley Turn in Concepts Engine, Exhaust, Bolt-Ons 5 05-22-2013 11:51 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 08:45 PM
