Old 04-24-2017, 04:11 PM   #15
In my defense it was one of the few vehicles I owned back then where the e brake actually still worked.
wparsons (04-25-2017)
Old 04-25-2017, 09:41 AM   #16
wparsons
wparsons's Avatar
I realize it's a "special" moment... but when you have a habit of making sure the e-brake is fully locked anytime you're lifting the car with a jack, it's something you probably do without thinking.
When I did my rear rotors I definitely locked it, then before I went to pull the rotors realized what I had done when I couldn't rotate them at all.
flickr
timurrrr (08-23-2019)
Old 04-25-2017, 12:45 PM   #17
Right? That's always how it goes. Pull e-brake, loosen lugs, lift car, insert jack stands, get to work....
Excellent reminder. Thanks for thinking of it.
Old 04-25-2017, 12:56 PM   #18
wparsons
wparsons's Avatar
Mine routine has loosen lugs and lift car reversed, but I'm lazy and using air tools to pull the lugs off.
flickr
Ultramaroon (04-25-2017)
Old 10-23-2017, 02:25 PM   #19
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Grave digging but I can't remove the *@&# drums after turning the star gear in the proper direction after letting out the parking brake and hammering away like a blacksmith with a rubber mallet and lightly with my 32 oz hammer. I'm staring at these damn things and cursing up a storm. Is there something that I'm missing?
Trefoil is offline   Reply With Quote
Old 10-23-2017, 02:29 PM   #20
FirstWinter
Drives: Car
More PB Blaster & BFH (Big Fucking Hammer). You can also use some bolts to help loosen it from the front. There should be 2 holes or try this
[ame="https://www.youtube.com/watch?v=t2Ody4WCIWY"]method.[/ame]
All you need is some nuts/washer & a bolt that is smaller than the caliper bracket hole and use it to push out the rotor. You don't need a bolt like the video that is the right size. Way easier than a hammer.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Trefoil (10-23-2017)
Old 10-23-2017, 02:31 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Provided all the other advice in the thread has been followed (caliper removed, parking brake off, etc.) There should be threaded holes in the disc that you can put a screw in to push them off the wheel hub. Like this:
iirc it's a standard 8mm or 10mm screw and you can definitely 100% use one that is fastening the underbody of the car in place. That's how I got mine off.
I don't think the wheel speed sensor has to be removed but it doesn't hurt to check it.
Edit: I would not do what's done in the video @FirstWinter posted, that could cause some dinged up surfaces by putting that much torque on one edge of the rotor. You could potentially fuck up the emergency brake assembly. Start with the two holes in the disc and if that is problematic you can try more extreme measures.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
Icecreamtruk (10-23-2017), Spuds (10-23-2017), timurrrr (08-23-2019), Trefoil (10-23-2017)
Old 10-23-2017, 02:52 PM   #22
jvincent
jvincent's Avatar
Did mine earlier this year, and the wheel speed sensor does NOT need to be removed.
I winter drive my car in the Land of Salt, and got the rotors off after 4 winters using only the bolts in the front as shown in your picture so I'm not sure why @Trefoil is having issues.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
strat61caster (10-23-2017), Trefoil (10-23-2017)
Old 10-23-2017, 02:54 PM   #23
jasonojordan
Drives: 2013 satin white brz limited
The shitter part of doing it this way is depending on where in the county he lives and if its year round daily car its very possible the threaded holes for rotor removal will need to have the threads chased before he will ever get a bolt through them. All the vehicles I have dailed year round here in Minnesota even after only 2 years the threaded holes would no longer take a bolt without being chased.
*read 1st post looks like he is from California. Should be ok then*
Edit: I would not do what's done in the video @FirstWinter posted, that could cause some dinged up surfaces by putting that much torque on one edge of the rotor. Start with the two holes in the disc and if that is problematic you can try more extreme measures.
jasonojordan is offline   Reply With Quote
The Following 2 Users Say Thank You to jasonojordan For This Useful Post:
Old 10-23-2017, 03:05 PM   #24
Trefoil
Trefoil's Avatar
Holy crap! Just needed to put the impact gun on it and there was immediate separation after I did both ports.
The Following 2 Users Say Thank You to Trefoil For This Useful Post:
FirstWinter (10-23-2017), strat61caster (10-23-2017)
Old 10-23-2017, 03:08 PM   #25
strat61caster
Sometimes they just need the right motivation.
ineedyourdiddly
Old 10-23-2017, 03:15 PM   #26
Trefoil
Trefoil's Avatar
For reference: the bolt is a M8x 1.25 pitch. I bought mine at 60 mm length but only 30 is really needed.
The Following 4 Users Say Thank You to Trefoil For This Useful Post:
Icecreamtruk (10-23-2017), Spuds (10-23-2017), strat61caster (10-23-2017), timurrrr (08-23-2019)
Old 10-23-2017, 04:08 PM   #27
jvincent
jvincent's Avatar
I didn't need the impact gun, but definitely the big wrench.
Good that you got it sorted.
Old 08-22-2019, 12:43 AM   #28
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I did the same thing and forgot to release the E brake, I got the rotor off but now I cannot get my new one back on, or the old one. I can't seem to get it over the ebrake. (the Ebrake is off). Any advice how to get it on?
DandoX is offline   Reply With Quote
brake, rear rotor, rotor
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
Lightweight REAR rotor options himbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 10-15-2018 04:59 PM
Rear Rotor Suggestions? iLaw Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-30-2015 03:07 PM
Replacement Rear Tire Stodium Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-01-2015 07:47 AM
Rear quarter panel replacement sero901 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 09-25-2015 12:41 PM
