Old 10-13-2017, 03:49 AM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Fujitsubo makes one currently:
http://www.ft86club.com/forums/showthread.php?t=122637
chaoskaze (10-13-2017)
Old 10-20-2017, 09:25 AM   #16
Hags86
Drives: Toyota GTS 86
So, results are in.
The muffler removes 10kW power by itself with the same ignition timing, but used the safety margin before knock. Needed to remove 2 degrees of timing on 98 Octane and a smaller amount on e85 which dropped another 5-15kW depending. Upshot is the muffler drops 15-25 kW.
Based on a small turbo. 210 kW on 98 octane, 240kW on e85.
All numbers measured at the wheel on a Mainline dyno.
Hags86 is offline   Reply With Quote
The Following User Says Thank You to Hags86 For This Useful Post:
Icecreamtruk (10-20-2017)
Old 10-20-2017, 09:48 AM   #17
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by Hags86 View Post
So, results are in.
Thanks for the info, I did not expect it to make such a difference, I guess in a turbo setup you really want as little restriction as possible at all costs (for power).
Icecreamtruk is offline   Reply With Quote
Old 10-20-2017, 05:19 PM   #18
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Originally Posted by imnotsureaboutbrz View Post
I would love to have a dual mode exhaust for everyday driving and track/autox days... most options are too expensive or custom. And here's the perfect spot for that switch...
Works Motorsports makes an axleback cutout that can be mixed and match with any exhaust that matches up with the factory axleback flange and flange location. It's cool to see these things becoming more available for our cars.
Here is the guys set up and a video can be found on his instagram
TachyonBomb is offline   Reply With Quote
The Following User Says Thank You to TachyonBomb For This Useful Post:
kevaughan (09-04-2020)
Old 10-20-2017, 06:17 PM   #19
Hags86
Is the valve vacuum operated or electrically?
Old 10-20-2017, 06:39 PM   #20
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Vacuum
Jrdad is offline   Reply With Quote
Old 10-20-2017, 07:14 PM   #21
TachyonBomb
Yup vacuum. One option for NA motors and another for boosted motors.
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
FS: C Street MCS Dual Adjustable Remotes TRev Brakes, Suspension, Chassis 7 11-21-2014 06:26 PM
WTB berk test pipe and track pipes OR Inexpensive mufflers dmitri93 Want-To-Buy Requests 2 07-25-2014 01:19 AM
