Old 10-11-2017, 05:10 AM   #1
Hags86
Drives: Toyota GTS 86
Dual-mode track and street pipes
Thought someone might be interested in my custom exhaust.
It is a turbo with a 3" all the way through (including dump pipe and overpipe) with just a high-flow cat and no mufflers. An exhaust bypass cuts this out for 'street' mode and exits via the other exhaust tip which is 2.5" and has a muffler.
An aftermarket ECU allows one dash switch to both open the valve and set a new ECU map. It goes in for dyno tuning next week - we think we'll get a few more degrees of ignition timing with the open pipes. Let's test the theory and see if it actually makes more power.
Cat is installed such that it can be removed relatively easily.
Video of the bypass valve testing
Hags86 is offline   Reply With Quote
The Following 6 Users Say Thank You to Hags86 For This Useful Post:
B T (10-23-2017), Boomerang (10-11-2017), humfrz (10-12-2017), nav (10-19-2017), Tcoat (10-11-2017), Teseo (10-12-2017)
Old 10-11-2017, 07:09 AM   #2
Boomerang
86
Boomerang's Avatar
Take my money and sell me one...
Old 10-11-2017, 07:15 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder how did you made ecu tune also actuate straight exit exhaust valve?
Old 10-11-2017, 07:38 AM   #4
Very nicely done. In for the test results.
Old 10-11-2017, 08:51 AM   #5
femaledog
Drives: 2017 BRZ Perf. Pkg.
Nice man. I wish there were more valved options for this car. I may need to have something made as well.
femaledog is offline   Reply With Quote
Old 10-11-2017, 09:14 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
There are several valve options, if one searches, that can be welded in. Electric or mechanical wire actuated. IIRC i've seen here another one or two similar setups on this forum. But actuated by ECU tune sounds something new.
Old 10-12-2017, 12:18 PM   #7
cbryant514
Drives: 2016 Scion FR-S
Thoughtful solution and it appears to be well executed! I'd like to hear the difference via a test video...
cbryant514 is offline   Reply With Quote
Old 10-12-2017, 03:34 PM   #8
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
I’ll be second in line!
Barefootdan is offline   Reply With Quote
Old 10-12-2017, 03:42 PM   #9
Clean!
Old 10-12-2017, 04:19 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
Looks pretty cool. Why does the valve open past 90 degrees? It seems like 90 would be best.
Old 10-12-2017, 04:42 PM   #11
Hags86
It does open to 90 degrees. The camera angle makes it look weird.
It makes a large difference in volume but i haven't rev’d it past 3500 yet - still has a NA map. Goes for dyno next week - I'll report back then together with any differences in HP a video with the valve open and closed.
Old 10-12-2017, 05:24 PM   #12
Hags86
That is the easy part. The MoTeC ECU is very configurable. A 10 position Driver Rotary Switch enables Auxiliary Output to switch to ground which then then operates a relay to drive the servo motor of the valve.
That one Driver Rotary Switch can operate several software options at once. for example:
Switch Pos Ex Valve Rev Limit Timing
Pos 1 - Valet Closed 3500 Map 1
Pos 2 - Daily Closed 7000 Map 1
Pos 3 - Track Open 7500 Map 2
I can even operate outputs based on GPS position. One track I got to has a restrictive noise limit. I'm thinking of programming the ECU to close the valve as the car approaches the Decibel meter and then opening it back up when I'm further away.
It's only really limited by your imagination - it could open based on engine RPM, throttle position etc etc.
Old 10-12-2017, 06:08 PM   #13
imnotsureaboutbrz
Drives: between cars...
I would love to have a dual mode exhaust for everyday driving and track/autox days... most options are too expensive or custom. And here's the perfect spot for that switch...
I can't wait to hear how yours turns out!
imnotsureaboutbrz is offline   Reply With Quote
Old 10-12-2017, 06:17 PM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Impressive! Interested to see the vid & result as well
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
FS: C Street MCS Dual Adjustable Remotes TRev Brakes, Suspension, Chassis 7 11-21-2014 06:26 PM
WTB berk test pipe and track pipes OR Inexpensive mufflers dmitri93 Want-To-Buy Requests 2 07-25-2014 01:19 AM
