Old 10-19-2017, 03:49 AM   #281
MileMonger
MileMonger's Avatar
Drives: 2015 Subaru BRZ
Originally Posted by BRZyJ View Post
Ugh...I bookmarked this thread like a year ago knowing it'd come in handy...of course now it's been photobucket-ed.
Douchebags
Same here! TrojanSC, is there any way we can get them to show again? :/
Sent from my SM-G930T using Tapatalk
MileMonger is offline   Reply With Quote
Old 10-19-2017, 11:07 AM   #282
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Here's a pretty good guide I came across:
https://howtune.com/articles/95-repl...n-a-scion-fr-s
The little tray trim piece (by the USB/AUX) might be a pain...I broke a tab taking it out, but it went back in okay
BRZyJ is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZyJ For This Useful Post:
MileMonger (10-19-2017), notout86 (10-05-2018)
Old 10-19-2017, 09:03 PM   #283
MileMonger
MileMonger's Avatar
Thanks! I had seen that one too a while back but forgot about it. I think there's a post in this thread somewhere about the push start button. Will use all three and try to install mine tomorrow.
Old 12-31-2017, 09:35 AM   #284
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Originally Posted by tonystewart View Post
Thank you for the DIY, and a special thank you to JPM Coachworks for the parking brake boot and the Kneepads.
What's the trick to removing those small plastic pieces under the knee pads? Seriously having a problem.pulling them.off in my '15 frs. No amt of force is getting them off or away from.the underneath of the pads.
Edit: They require a bit more force than "just pull" But yeah, break away from center console 1st than pull from closest to seat towards front of car.
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 12-31-2017, 02:12 PM   #285
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
For me, I find it easier to pull out the front most part first. And by ‘just pull’, I think that just means no tools, not ‘be gentle and pull.’ Lol. It’s more of a quick yank when I do mine. Same as the radio surround trim, grab firmly and yank to get it out of its clips. My friends who see me do it are always like ‘whoa, not too rough, huh.’
Pointmutation is offline   Reply With Quote
Old 12-31-2017, 07:01 PM   #286
Imp
Bring out your dead
Yeah, figured it out. Broke the last tab on the drivers side. I'm used to being rather forceful and gentle, but ... this required a bit more force than many other cars I've worked on. Not a bad thing, keeps the rattles to a minimum.
--kC
Old 10-05-2018, 08:43 PM   #287
notout86
Drives: GTS 86 auto
Originally Posted by 2pt5RS View Post
just pull towards the door.
To remove the panel below the kneepad with minimal distortion and chance of damage:
There are three "locators" along the top of that panel on the back, plus a clip at the end furthest from the engine end. The clip is about half-way up. ALSO, at the top of the panel at the engine end, about 20mm back towards the rear of the car, there is a finger hole.
You can slip fingers up behind the panel then starting from the engine end, pull towards the door to release the first "locator". Then, stick a finger in the finger hole and pull towards the door to release the next locator, then the next one.
Then, while pressing the console close to where the clip is, fingers under the panel close to the clip, pull the panel straight towards the door.
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
jcw99 (10-06-2018)
Old 06-06-2019, 07:27 PM   #288
rixter145
Sleep Chomper
rixter145's Avatar
All the photos expired
rixter145 is offline   Reply With Quote
Old 07-31-2019, 09:43 AM   #289
Bowflex
Drives: Scion FR-S
Bowflex is offline   Reply With Quote
The Following 2 Users Say Thank You to Bowflex For This Useful Post:
MileMonger (11-16-2019), rixter145 (07-31-2019)
Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR nigel-jdmparts Interior Parts (Incl. Lighting) 89 02-01-2013 04:00 PM
HID Retrofit Kit install Jidonsu NY / NJ / CT / PA 1 08-04-2012 01:24 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-27-2012 11:13 PM
FS: console knee foam pads 86_ZN6 Interior Parts (Incl. Lighting) 9 07-21-2012 09:46 AM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
