#239 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
4 in total is needed for the JDM grille. 2 for each side. I just finished installing mine today.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#240 |
Thule Dude
Drives: Scion FR-S
Installed JPM Coachworks
Bought the JPM Coachworks OEM pads with alcantara wrapping and some padding. Thanks Trojan for the good tips on installation. Took me a while but with the guidance I got it done without any mishaps.
The fit of the JPM Coachworks is good since they are based on OEM parts. The padding is maybe a bit less than I had hoped for but it helps and the alcantara material is much gripper that the slippery OEM. One track day on them so far and it definitely decreased the scuffing I usually get since I'm still using stock seat belts. |
#241 | |
Drives: Subaru BRZ Limited
#243 |
Drives: 86
#244 |
Drives: 13 BRZ Limited 6MT GBS
Are the grille rings necessary? I saw them posted in the original thread, but when I contacted Carson Toyota for a quote for the whole shebang, they told me the rings are Subaru-only, and quoted me a price without the rings.
I ordered from Amayama because I didn't want to get it and not be able to put it together, plus I needed a replacement seat bolt that was 4x as expensive at the dealership as Amayama, so it all worked out. I don't really like the way the silver ring looks, so if it turns out that I can assemble them without the ring, I'll try it. I contacted JPM but they're not offering the speaker trim panels in sim leather, just in Alcantara. I guess it works if you're going to get alcantara shift boots and go for a lot of alcantara in the interior, but I'm not, and I think it looks out of place to just have the kneepads in alcantara when the two other leather pads on the door (the armrest and the windowsill) are leather, and my center console armrest is leather. They have the center console ones in sim leather, just not the speaker ones. I was kinda bummed. JPM is more expensive than JDM for the center console kneepads, but cheaper for the doors, so it works out about even, and it sounds like they have better build quality. The JDM kneepads themselves are only around $40/each, but the rings and grilles add on another $80 or so. So I imagine that JPM's able to cut out that cost by using the original USDM kneepads with the integrated grilles. Makes sense, and I'd rather be getting a $75 kneepad with a $5 grille than a $40 kneepad with a $40 grille. Part of me said "Why don't I just buy the pad, and stretch some speaker grille cloth behind it, or dremel the grille out of my old kneepad, and save $80", but then another part of me slapped that first part and said "This is a $27k car, don't you dare do something ghetto". My Amayama order should be in soon and I'll let you guys know if they'll work without the rings.
#245 |
Drives: 13' brz limited
Got knee pads done today, super easy thanks for the diy ,was slightly different for a auto but nothing hard at all.
#246 |
I forgot to let you guys know.
It'd be possible to assemble them without the rings using the JDM parts, but it'd look bad. The grille is smaller than the opening and it needs the ring to fill the gap. Do 2014 FR-Ses come with rings?
#247 |
Yes the 2014's come with the rings.
#248 |
Drives: 2013 Black BRZ Premium
A big thank you for taking the time to post this!
#249 |
RWD forever !
Drives: Toyota GT86 SWP
Can someone please explain to me how you're supposed to remove the 2 pieces below the knee pads (step 1 od the DIY
) ? The pics are not very explaining, do you have to pull it down, or towards the front of the car, or something else ? Thanks for any advice.
#250 |
Berz
just pull towards the door.
| The Following 2 Users Say Thank You to 2pt5RS For This Useful Post: | chanomatik (03-11-2014), NSV (03-11-2014) |
#251 |
RWD forever !
Thanks 2pt5RS for the tip.
One last question, what about the BRZ or those equiped with a push-start button ? Do you have to push/pull out the down tray first, and then disconnect the pushstart button and the USB ? Or first disconnect then push out ? |
#252 | |
Snow Don't Hurt!
| The Following User Says Thank You to chanomatik For This Useful Post: | NSV (03-11-2014) |
| Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR | nigel-jdmparts | Interior Parts (Incl. Lighting) | 89 | 02-01-2013 04:00 PM |
| HID Retrofit Kit install | Jidonsu | NY / NJ / CT / PA | 1 | 08-04-2012 01:24 AM |
| How do you install the mud guards? | Moshpit37 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-27-2012 11:13 PM |
| FS: console knee foam pads | 86_ZN6 | Interior Parts (Incl. Lighting) | 9 | 07-21-2012 09:46 AM |
| Spoiler Install | CharlieChaos | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-07-2012 10:43 AM |
