Old 10-18-2017, 10:51 PM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by jasonojordan View Post
This is very tire dependent. Some run wider then others. What tires are you running on your 9"
RS-3 V1, RSR, and now RSRR. I suppose both these brands run a bit wide.
Intent > Content
Old 10-19-2017, 08:16 AM   #16
jasonojordan
Drives: 2013 satin white brz limited
Yep they do thats why I was curious. Thanks!
jasonojordan is offline   Reply With Quote
Old 10-19-2017, 08:54 AM   #17
Reamer
Drives: 2015 FRS
I ran MPSS 245/40/17 on 17x8 wheels and they fit perfect. I wouldn't go anywhere below 245 on 9" wheels unless a specific tire is well known for running wide.
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
Old 10-19-2017, 09:56 AM   #18
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
It really depends on the tire. These are 235/45/17 Federal FZ201s on 17x9 57CRs. They run really large and measure out to almost a 250.
GirlRepellent is offline   Reply With Quote
The Following 2 Users Say Thank You to GirlRepellent For This Useful Post:
Clipdat (10-19-2017), DuMa (10-25-2017)
Old 10-19-2017, 11:36 AM   #19
zberz
Drives: 2015 Lightning Red BRZ
I have 17x9s with mpss 245/40/r17s. Tire fit the rims well, but I did need spacers up front to prevent rubbing on the suspension. Love the setup, noticeably better grip.
Sent from my SM-J700T using Tapatalk
zberz is offline   Reply With Quote
Old 10-20-2017, 12:18 AM   #20
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
What rims & suspension are you running?
I pick up my MPSS 245/40/17 on Saturday on the Rota Titan 17/9 E42 and hope I don't need my 5mm spacers? Guess I find out soon enough
Jmonty is offline   Reply With Quote
Old 10-20-2017, 12:19 AM   #21
Jmonty
Originally Posted by sachu View Post
am in the same boat. planning on going with Continental ExtremeContact Sport in 255/40.
Are you on 17 × 9 rims now?
Old 10-20-2017, 12:21 AM   #22
Jmonty
Originally Posted by sam69 View Post
I've just been through the same exercise and finished up with 245 40's as I was sold on the Michelin PS4 and they only make them in 245 and not 255.
The PS4 has ever so slight stretch to the sidewall but not much but I'm more than happy and very impressed with these tyres (tires ).
PS4 's are currently available in 18, 19 or 20" here in the states
Old 10-20-2017, 01:15 AM   #23
sachu
Drives: rocketship
Naa.. still on the stockies.. running federal 595 in 225/45 17. These are my fall /winter tires.
the 17x9 setup will be for summer, most likely with the continental ECS.
sachu is offline   Reply With Quote
Old 10-21-2017, 06:32 PM   #24
Jmonty
That ended up being a waste of time, Costco would not install the tires as I would have needed my spacer to clear the front strut. They did refund my purchase in full
Old 10-24-2017, 05:43 PM   #25
sachu
Drives: rocketship
Trying to decide on the Continental extreme contact sports.
which would work better on a 17x9 wheel?
245/40 or 255/40?
Old 10-24-2017, 06:00 PM   #26
FirstWinter
Drives: Car
245/40 or 255/40?
245. Don't see a point in running 255 unless you're trying to maximize grip in competition.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
sachu (10-24-2017)
Old 10-24-2017, 06:50 PM   #27
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
That's bs because I ran 17x9 +42 et up front with 245/40/17 for several years without any rubbing.
Maybe you already have negative camber up front via camber bolts though, that would cause the tire to be closer to the spring perch.
Originally Posted by humfrz
I'm old and lazy
Old 10-24-2017, 07:17 PM   #28
jmark
Drives: '97 NSX-T, '18 Type R
Michelin run wider than some tires. I know the AS3+ was almost an inch wider than the Pirelli P Zero AS tires my son just put on his 17 x 9 Apex rims. Both tires were 245/40R17. He isn't rubbing either even lowered on RCE Yellows and with -.8 chamber in front.
jmark is offline   Reply With Quote
Best tire size for 17x9 wheels Elliotw Tracking / Autocross / HPDE / Drifting 3 09-30-2017 01:22 AM
Good Tire size for 17x9? J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-05-2016 08:30 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Nubby wheel/tire/fitment guy in need of advice 17x9+35 KevinK121 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2015 07:34 AM
The rite tire size? rpf1 17x9 +45 Gillams Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 04-22-2015 12:37 PM
