Old 10-16-2017, 08:28 AM   #1
btan219
Drives: DGM 15' BRZ Limited
Doing an oil change with Royal Purple 0w-20. Does it matter if I use an oem filter?
Doing my first oil change using royal purple.
https://www.amazon.com/dp/B005SEK9IQ...=1O1PK1NEBDAY9
Does it matter whether I use an oem Subaru oil filter or the Royal Purple (twice as expensive) one?
oem- https://www.amazon.com/dp/B00ESTFGMQ...=1O1PK1NEBDAY9
rp- https://www.amazon.com/Royal-Purple-...+purple+filter
2015 subaru MT don't track or race
btan219 is offline   Reply With Quote
Old 10-16-2017, 08:59 AM   #2
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Use that OEM filter. There's nothing wrong with it, especially that black Tokyo Roki A130 filter you're looking at there. I has a sort of cult following around here. As far as performance, its probably your best option, considering your application. According to many here who have cut one open, it has good filtration and unlike some aftermarket options, it has the proper pressure valve for boxer engines.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Clipdat (10-16-2017)
Old 10-16-2017, 09:09 AM   #3
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
From the past, when Subaru of America changed from Tokyo Roki JDM oil filters (black) to a cheaper, domestic Honeywell/ Fram fllters (blue). Needless to say, that was a money-saving choice by Subaru, and hence the start of the controversy:
https://forums.nasioc.com/forums/sho....php?t=1623020
https://www.i-club.com/forums/hawaii...eywell-195513/
https://forums.nasioc.com/forums/sho....php?t=2207951
http://www.iwsti.com/forums/2-5-lite...ions-pics.html
dowroa is offline   Reply With Quote
Old 10-16-2017, 12:00 PM   #4
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Blackstone did a big oil test this year and Royal Purple had slightly worse ratings than many other oils. Although the slight variation in metal content will likely never make a difference, you're paying extra for a pretty purple bottle: https://gallery.mailchimp.com/f64139...Aug_17_ENG.pdf
Consider saving money and using different oil, like Castrol Edge: http://amzn.to/2gJfBTV
TofuJoe is offline   Reply With Quote
The Following 2 Users Say Thank You to TofuJoe For This Useful Post:
Darth Khan (10-16-2017), Icecreamtruk (10-16-2017)
Old 10-16-2017, 08:27 PM   #5
Ernest72
Just use a good filter, not the cheapo ones. And Subaru factory oil is a very good choice and readily available at amazon or the dealer. Many other good choices at Walmart as well. Just search.
Old 10-17-2017, 11:02 AM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Black Tokio Roki OEM filter, and a quality 0-20 for the vast majority of owners. If you've already bought the Royal Purple, I suggest returning it. You're paying RP extra money for a purple bottle, and to exchange some of it's content that should be used to lubricate, clean, and protect your engine for your engine's lifeblood to have non-beneficial coloring in it.
The OEM oil is very high quality and is available on Amazon and from your dealer. Napas usually stock Pensotin, Eneos, Idemitsu, Pennzoil and Liquimoly, which are all fantastic choices. Many also stock Amsoil products which are some of the best.
I use Idemitsu in my car, but get free delivery on Motul products so most of my customers opt for Motul fluids throughout the vehicle. (It's a great choice...)
I don't think their oil is the worst, but I can absolutely never recommend it.
Their gear oil is horrendous too. I've removed it 20 or so times from troublesome grinding transmissions, and replaced with a castrol or motul product and watched the issues melt away after 20-30 miles of shifting. Usually the owner is buying what they think is best and trying to just maintain their car, but it ends up biting them in the butt.
JazzleSAURUS is offline   Reply With Quote
Royal purple tran oil review MyNave Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-08-2016 04:25 PM
Any Issues with Royal Purple? akuhei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 46 08-03-2015 05:06 PM
Royal Purple Oil - Possible GB (Vic Only) fuddbutter Australia Classifieds 0 11-14-2012 08:48 PM
Oil Change - Perhaps Royal Purple? RowTarEEE Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 47 11-01-2012 06:47 PM
For sale: New in box Royal Purple oil filter (model #10-2876) zoomzoomers Miscellaneous 0 10-30-2012 04:25 PM
