Old 10-13-2017, 12:04 AM   #29
Icecreamtruk
Drives: Track preped NA FRS
Dude, how fucked up is your driving that you need to worry about that 100 ms or so that it takes to switch foot. Why are you worried about emergency braking AND downshifting? Are you like, waving thru traffic in your car like you would in a bike? I do not understand the point of this thread at all. Left foot braking main advantage is not the time saved while switching from gas to brake, its to be able to keep accelerating and transfert weight to the front during a turn (so like a small touch on the brakes mid corner) to balance the car out and/or correct understeer. Left foot braking has no place nor utility in city (aka street legal) driving.
Icecreamtruk is offline   Reply With Quote
The Following 8 Users Say Thank You to Icecreamtruk For This Useful Post:
alex.s (10-13-2017), FirstWinter (10-13-2017), justinco (10-15-2017), Jyn (10-13-2017), kch (10-13-2017), mjanmohammad (10-17-2017), strat61caster (10-13-2017), Tcoat (10-13-2017)
Old 10-13-2017, 12:25 AM   #30
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
wow
I had it all typed up, was going to find the specific podcast with Ross Bentley being interviewed (that @justinco also listens to ) to confirm that according to the data it's ~0.02s faster to LFB than RFB. About how I've been LFB most of the year but I'm going to stop now and focus on how I use the brake, being smooth on and off and taking advantage of the time between throttle off and brake on to gauge my speed for the corner, I've got other aspects of my driving to work on, but that's all irrelevant isn't it?
@alex.s don't worry about your left foot braking, give yourself more distance, slow down when you can't see ahead and anticipate potential hazards. That's what will save your car and your life, not 0.02 seconds quicker to the brakes. Traffic on public roads doesn't operate at that time scale, your reaction time is already 0.25 seconds, you're already SOL if you're trying to find 0.02 seconds of safety margin. Let the damn car stall if you have to panic brake and you forget to put it in neutral, who gives a shit, there's nothing you can do to prevent being rear ended or blind sided or dodging the cow in the road other than awareness awareness awareness.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
alex.s (10-13-2017), Icecreamtruk (10-13-2017), TrqlessWonder (10-16-2017)
Old 10-13-2017, 03:09 AM   #31
algs26
Drives: silver frs
Are you running in stock? Are aftermarket pedals even legal in stock class?
I had them on my old car to get the pedals closer and (brake pedal) higher.
algs26 is offline   Reply With Quote
Old 10-13-2017, 05:44 AM   #32
ermax
ermax's Avatar
left foot braking transitions
I didn’t read the whole thread so I may be repeating what others have said. Before I started to LFB I learned to heal toe. When I first learned to heal toe I was using my toe on the gas and my heal on the brake. Then I added in LFB and that is when I learned that I was doing heal toe all wrong. You need to use your toe on the brake and your heal on the gas or else transitions from LFB to RFB are really awkward. It didn’t take long to retrain my brain to do it correctly. I also learned that applying various driving techniques on track but not in my daily drive was tricky. These things only became habit when I decided to apply them to my daily commute.
Old 10-13-2017, 08:17 AM   #33
dattran86
Driver
Drives: 2013 Whiteout FRS
taking it from Ross Bentley, "Its better to be a great right foot braker than a mediocre left foot braker"
it takes lots of practice to get the same sensitivity as your right foot. alot of top tier driver growing up in carting that's why they're so good with their left foot.
if you worry about brake/throttle overlap during initial corner entry to save a few tenth of a sec, just heel toe and get back on throttle as quick as you can. its not like we're Lewis Hamilton here
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
The Following 2 Users Say Thank You to dattran86 For This Useful Post:
CSG Mike (10-13-2017), Icecreamtruk (10-13-2017)
Old 10-13-2017, 09:29 AM   #34
ermax
ermax's Avatar
In autox it's good to be able to so quickly go from brake to gas though when you're in a slalom. On a road course there isn't as much demand for quick transitions from gas to brake so in that case it's not as valuable. But I think it's safe to say that most if not all competitive autoxers LFB. But I'm realizing now that the OP was solely talking about daily commutes which is kind of pointless.
Old 10-13-2017, 09:51 AM   #35
dattran86
Driver
my problem was I started driving older manual cars with a really heavy clutch when I first got my license. so my left foot is absolutely useless when it come to LFB, I tried to practice on the street but I dont think i will get decent at it...at least not for a long while.
the first time i tried to LFB on one of my run, it didnt go that well. I over braked the car because my left foot was so used to the clutch
IG: aimforapex
Old 10-13-2017, 09:57 AM   #36
ermax
ermax's Avatar
Hahaha. Same here. It wasn't until I started doing it on my daily commute (only when it was safe to do so) that it became more natural. After a few days I got better and at the next event I had more success. Once I got a feel for it I no longer needed to do it on a daily basis and at events I just pick it right back up. The next challenge was to train myself not to ride the brake the whole run because it fades the pads quick.
Old 10-13-2017, 10:12 AM   #37
strat61caster
Even that's debatable, depends on the car depends on the slalom and there's very few drivers with the talent to actually take advantage of that. Us average Joe's are probably faster with a consistent speed or gradual Accel or decel as needed.
ineedyourdiddly
Old 10-13-2017, 10:14 AM   #38
STV3
Señor Member
STV3's Avatar
Dear god.... This guy isn't event talking about racing.
Stop left foot braking on public roads! Your left foot resting on the pedal will inevitably lead to you pressing the pedal just enough that your brake lights turn on while you accelerate/coast and people behind you wont know when you are actually braking. There is no reason for this in everyday driving.
STV3 is offline   Reply With Quote
Old 10-13-2017, 10:45 AM   #39
M0nk3y
That's an incorrect statement.
Anyways, if you're braking in the middle of a slalom, well you drove that slalom completely wrong IMO.
I right foot brake, don't have any issues with results.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
Old 10-13-2017, 10:49 AM   #40
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
hey guys, thanks for your feedback. i can tell this is about as hotly contested as religion, and obviously everyone knows that their own answer is the only correct one, so i'll find my own path. thanks.
alex.s is offline   Reply With Quote
Old 10-13-2017, 10:51 AM   #41
alex.s
alex.s's Avatar
Originally Posted by justinco View Post
My bad, thought this was the tracking / autocross forum.
Personally I would be trying avoid putting 2 feet on the same pedal, but that's just me. Hope you find a solution to your problem.
i posted here because it was the closest thing on this website to any kind of "skills" section. which seems to not actually be a thing people study for cars? it sounds more and more like car drivers just go get in a car and fuck around until something happens
Old 10-13-2017, 10:57 AM   #42
Azzudien
Drives: 2017 Series Yellow BRZ
I don't think it is hotly contested issue, you asked a question in a track/autocross thread about a driving technique that is used by drivers that are at top of this type of driving.
Then you state you use this technique on the street.
I am new to driving on the track, but even in my short time tracking my car there is countless things I do on the track that I would never consider attempting on the street. There is a reason people go to the track, and that is to have fun, learn, and do it in a SAFE CONTROLLED environment.
Going out on a public street and practicing a braking technique is careless and unsafe no matter how much you tell me you are a great driver. Ask the person behind you on the street how great a driver you are when you accidentally put to much pressure on the brake pedal using your left foot learning this.
Azzudien is offline   Reply With Quote
The Following User Says Thank You to Azzudien For This Useful Post:
left-foot braking with AT mdm Scion FR-S / Toyota 86 GT86 General Forum 169 06-05-2016 11:25 AM
That left-side vertical streak of residue left by windshield wipers tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 20 07-15-2015 12:23 AM
Foot pain while braking hard? daiheadjai Other Vehicles & General Automotive Discussions 19 04-05-2015 08:46 PM
WTB Red Bumper, Left Fender, Left head light, Clear side markers carlossanchez89 Want-To-Buy Requests 0 09-01-2014 03:43 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
