Old 10-12-2017, 03:37 PM   #1
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
left foot braking transitions
hey yall. i'm new to left foot braking.
i know people say don't use it on a corner you'll have to downshift on, but i've started left-foot-braking 100% of the time because it makes more sense in my head... the problem comes when i need to emergency brake past a gear when i start braking from the left foot... what winds up happening is the brake pedal is not wide enough to have both my feet on it so i have to actually keep both my feet rotated at 45* angles in order to fit both of them on the brake pedal. which works out for the right foot since that's how i heel-toe, but it's pretty awkard getting the left foot back to the clutch from having my left heel all the way against my right heel... does anyone else actually do this mid-brake foot transition? do you just get a wider brake pedal? do you need to move the other pedals at all? any suggestions for wider brake pedals?
alex.s is offline   Reply With Quote
Old 10-12-2017, 03:40 PM   #2
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
I would probably try to stop using 2 feet to brake and learn how to heel-toe properly.
Slammillionaire is offline   Reply With Quote
The Following User Says Thank You to Slammillionaire For This Useful Post:
Jyn (10-13-2017)
Old 10-12-2017, 03:41 PM   #3
alex.s
alex.s's Avatar
if i don't try to left foot brake, i heel-toe just fine.
Old 10-12-2017, 03:42 PM   #4
Slammillionaire
I think you've just solved your own problem!
Jyn (10-13-2017)
Old 10-12-2017, 03:44 PM   #5
alex.s
alex.s's Avatar
the answer to my problem regarding left-foot-braking is to not left-foot-brake?
Old 10-12-2017, 03:47 PM   #6
Slammillionaire
Unless your car is automatic, yeah I'd say so.
Old 10-12-2017, 03:51 PM   #7
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Not sure what emergency brake means.. but I don't LFB when I need to heel-toe. But from what I am reading, you are using your left foot for braking and at the same time the right foot on the brakes (when you need to heel-toe)?
iLuveKetchup is offline   Reply With Quote
Old 10-12-2017, 03:51 PM   #8
alex.s
alex.s's Avatar
why
Old 10-12-2017, 03:51 PM   #9
alex.s
alex.s's Avatar
something unexpected happens and you're about to hit someone so you need to brake.
i start with the left foot. and as the revs get down at some point i need to downshift. so while im still braking i change which foot i'm using which means both feet need to be on the pedal at one point, then i can use the clutch and heel-toe to get the throttle blip
Old 10-12-2017, 03:57 PM   #10
alex.s
alex.s's Avatar
even if it's not an unexpected emergency. if you can smoothly do the braking-foot transition, why not LFB on every corner entry?
Old 10-12-2017, 04:06 PM   #11
Slammillionaire
Because if you are heel-toeing correctly you'll still have a foot on the brake, heel on the gas and left foot available for the clutch to downshift. Also I think trying to use the left foot on brake as well as heel toeing you is causing confusion (hence your need for a wider brake pedal). No idea why you would want to have 2 feet on one pedal when you have 3 pedals that need attention.
justinco (10-12-2017)
Old 10-12-2017, 04:07 PM   #12
iLuveKetchup
Drives: EFF JAY
So if it's an emergency, shouldn't you come to a complete stop? Rev matching to the lower gear is the least of my worry when it's an emergency.
If you can somehow get on/off the brakes smoothly with both feet, then more power to you. I've never seen or heard anyone doing this.
Here's my LFB with heel-toe at an autox.
[ame]http://youtu.be/Ru3biKSUhXw?t=7s[/ame]
The Following User Says Thank You to iLuveKetchup For This Useful Post:
Takumi788 (10-13-2017)
Old 10-12-2017, 04:16 PM   #13
alex.s
alex.s's Avatar
are you implying that you are able to do overlapped throttle->brake transitions with only your right foot?
Old 10-12-2017, 04:17 PM   #14
alex.s
alex.s's Avatar
wow, awesome. thanks for posting this. this is pretty much exactly how my feet wind up being. you dont have any issue having to lift/shift the left foot to get at the clutch?
left-foot braking with AT mdm Scion FR-S / Toyota 86 GT86 General Forum 169 06-05-2016 11:25 AM
That left-side vertical streak of residue left by windshield wipers tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 20 07-15-2015 12:23 AM
Foot pain while braking hard? daiheadjai Other Vehicles & General Automotive Discussions 19 04-05-2015 08:46 PM
WTB Red Bumper, Left Fender, Left head light, Clear side markers carlossanchez89 Want-To-Buy Requests 0 09-01-2014 03:43 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
