Old 10-10-2017, 02:07 PM   #71
BRZ.Omar
Drives: 2017 BrrrrRz
Hey guys, this is my first post on this blog. I have a 2017 brz in Canada, about 31XX kms on it. I got a CEL the other day, dropped it off to the dealer and they called me today saying its a problem with the air-fuel ratio. The service advisor said they completed a couple tests and it seems that everything is fine. He asked me which octane fuel I use. I use 93-94 octane, he then suggested that I use 91 cause I might be running too rich... does that make sense?
BRZ.Omar is offline   Reply With Quote
Old 10-10-2017, 02:18 PM   #72
No it does not. The octane level of fuel has nothing to do with how rich or lean it runs. All octane means is it has more knock resistance. Other than that all fuel is the same.
Is the car completely stock?
strat61caster (10-16-2017)
Old 10-10-2017, 02:56 PM   #73
BRZ.Omar
Yes, completely stock. I have a tranny mount and a rear shifter bushing.
I am getting it back today and will keep an eye out for anything abnormal really. On another note, does the ethanol content of the fuels have anything to do with this issue? (ex: Shell Nitro ethanol free vs. say Petro-Canada Ultra 94)
Old 10-10-2017, 02:59 PM   #74
Nope they should not affect the mix either. You don't happen to know what the code was do you?
Old 10-10-2017, 03:26 PM   #75
BRZ.Omar
Not yet, I'll find out and post it here when I get the car back today.
Old 10-10-2017, 03:31 PM   #76
Check your air filter. If running rich it could be clogged.
Old 10-11-2017, 07:49 AM   #77
BRZ.Omar
So, same as @Oxyg3n , I got Codes P119F and P219A. They said they cleared them and did a couple of tests. Nothing coming up as an issue. They told me to keep an eye on it and if it comes back up, they will take the car, give me a loner and start a case with subaru's technical department.
Old 10-11-2017, 08:16 AM   #78
So not a rich or lean situation specifically just an imbalance. Could be many things but the "common" causes are leaky intake of exhaust, plugged filter or dirty MAF sensor. None of it earth shattering but if it keeps coming back they will indeed need to dig deeper.
Old 10-11-2017, 12:41 PM   #79
BRZ.Omar
Oh okay, thanks a lot btw! appreciate your quick responses
Old 10-16-2017, 12:55 PM   #80
funpolice
Drives: 2017 brz sportech
same problem here with the same codes
from toronto too brz 2017 brand new with less than 200km and the light come and goes few times.
dealer says will replace ecm
funpolice is offline   Reply With Quote
Old 10-16-2017, 01:17 PM   #81
Originally Posted by funpolice View Post
front toronto too brz 2017 brand new with less than 200km and the light come and goes few times.
That seems a bit extreme. Any idea what the code was?
Old 10-16-2017, 02:11 PM   #82
Jordanwolf
Rice King
Jordanwolf's Avatar
Is it only BRZ's with this issue? besides the one 86 mentioned....
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 10-16-2017, 02:18 PM   #83
They can all have CELs. The question is what caused the CEL. The CEL can mean several thousand different things and just saying "the light came on" is meaningless.
Old 10-16-2017, 02:37 PM   #84
Jordanwolf
Rice King
Jordanwolf's Avatar
I understand that, it's just funny that the few people here speaking up mostly own a BRZ, which are presumably all manual, and are mostly producing the same code. A batch of lemons is more what I was getting at, someone earlier mentioned something about how the build dates would be interesting to trace
Glorious Honda.
The Following User Says Thank You to Jordanwolf For This Useful Post:
22R (10-16-2017)
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
