Drives: FRS
Turn signal stuck on
So i have a 2015 FRS and changed bumper to a BRZ bumper and that's kind of when my issues started (before bumper changed i placed my side markers and all that would happen is my turn signal would be fast) I am having issues with my turn signal, my left turn indicator inside my dash stays on/lit and also my actual outside tail light stays on.
I do have Side markers and after market taillights. What could be the problem? So before on FRS bumper I had turn indicators and now with brz I don't since I placed cleib canards on. A shop did the install and was working fine and the about a week later this happen. Any help would be great. Last edited by Evil Rocky; 10-09-2017 at 12:16 AM. |
#2 |
Drives: Black 86 GTS
Are the blinkers on and stay on as soon as you start the car? Cause it sounds like it's wired incorrectly and the have used the headlights park/drl wire to power the indicators
#3 |
Drives: FRS
Only when turn lights on or hit my brakes. If don’t hit brakes or tune lights on it functions fine
#4 |
I would check the after market tails.
#5 |
Oh you mean you tail lights indicator? It sounds like you need to repin the tail lights as you brake/indicator wires are switched around. I think, bit hard to understand.
| The Following User Says Thank You to LED86 For This Useful Post: | Tcoat (10-06-2017) |
#6 |
Drives: FR-S 10 Series
I agree with Tcoat and LED86, check the aftermarket tail lights. Search Youtube for DIY/Installation videos of whichever you have as some installs require splicing certain wires or moving them to different pins.
#7 |
Not a troll
I dunno how any of you guys have even begun to be able to interpret what this guy's saying.
Some friendly advice, take the time to make sure your post is at least 90% understandable before asking for help. |
| The Following User Says Thank You to Cole For This Useful Post: | Impureclient (10-07-2017) |
#8 | |
![]() humfrz |
#9 |
#10 |
| The Following User Says Thank You to humfrz For This Useful Post: | Beachin86 (10-07-2017) |
#11 |
Drives: 2015 FR-S
#12 |
Drives: Whiteout FR-S
Shortly after installing my TOM's tail lights one of them would randomly get stuck on, even after turning off the car. I would have to pull the fuse to get them to turn off.
Like this To fix it I bought a Tapturn relay and haven't had an issue in the last few years. |
| The Following User Says Thank You to Nsot For This Useful Post: | Evil Rocky (10-09-2017) |
#13 |
Huge E85 fan!
Drives: 2016 Scion FRS
Did you check the blinker fluid? If the blinker fluid is low, it causes all kinds of issues.
| The Following User Says Thank You to guybo For This Useful Post: | Beachin86 (10-07-2017) |
#14 |
| The Following User Says Thank You to humfrz For This Useful Post: | guybo (10-08-2017) |
| Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! | Diode Dynamics | Exterior Parts - Lighting | 192 | 10-04-2017 12:51 PM |
| FS:GCS V.1 Turn signal | Vesalera | Exterior Parts (Aero, Lighting, Etc.) | 1 | 01-07-2017 08:14 AM |
| Right Turn signal DOES NOTHING ??? | JR Whiter | Issues | Warranty | Recalls / TSB | 5 | 10-29-2016 03:40 AM |
| Anyone seen these turn signal/drl less? | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-15-2012 04:32 AM |
