Old 09-14-2017, 07:04 PM   #57
Scourge
Agent 86
Drives: 2017 Toyota 86
I'm getting the same problem too. The dealership has already cleared these twice. And I have as well. Exact same codes. P117F and P219A. I really hope it's the O2 sensor like wrh3 said earlier. My car is new as well. Just hit the 16,000km (don't use miles in Canada) mark on my 86.
Scourge is offline   Reply With Quote
Old 09-14-2017, 07:12 PM   #58
All stock?
Old 09-19-2017, 07:19 PM   #59
funpolice
Drives: 2017 brz sportech
P119F P219A CEL
Just got the car last week brand new 2017 brz sport tech MANUAL
2nd day at around 100Km engine light came on with P119F P219A
the light went away before by itself after a day
it came back on again the second week. went to the dealership and they scanned it with the same code i got from my obdII scanner.
They still don't know what the cause is yet. Need to bring it back in for another appointment.
The 1st time it came on temperature is around 30 c degree and a bit humid.
2nd time it came on temperature is around 30 c degrees and humid as well.
I think the heat has to do with it. and i don't know if it's only an 6 speed model issue only. Anyone who has this problem, is your car 6 speed?
I know the 6 speed's air filter is different than the automatic.
funpolice is offline   Reply With Quote
Old 10-03-2017, 11:22 PM   #60
Scourge
Agent 86
All stock?
It started happening when it was stock. All that I've changed is suspension though. No engine/power related mods.
The Following User Says Thank You to Scourge For This Useful Post:
Tcoat (10-04-2017)
Old 10-04-2017, 03:59 AM   #61
steve99
Drives: FT86
Those codes indicate fueling issue
Could be a number of things 02 sensor and air leak in in intake or exhaust maf sensor fuel pressire or pump problem.
Dealer needs to do some diagnostics not just clear the codes
http://ft86tech.com/frs-brz-error-codes/
How to diagnose their are two videos we have air fuel sensors.thar read actual afr not just richer or leaner than 14.7 but concept is same., Maybe the dealer should watch these :-)
[ame]https://m.youtube.com/watch?v=5WnM_NsOtd8[/ame]
Tcoat (10-04-2017)
Old 10-04-2017, 12:27 PM   #62
sirsol66
Drives: 2013 FRS- Hot Lava
Had a very similar issue on a brand new 2015. Ended up being a bad wiring connection to one of the port injectors. Took 2 dealers ~3 months to figure it out. Im hoping this isnt indicative of a bad batch of wiring harnesses on the 2017's.
sirsol66 is offline   Reply With Quote
Old 10-04-2017, 12:37 PM   #63
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
Could be fun to compare build date from the affected cars.
mrderp is offline   Reply With Quote
Old 10-04-2017, 12:39 PM   #64
sirsol66
One thing to note: P119F is not just an imbalance, but "Bank 1 Air-Fuel Ratio Imbalance for Direct Injection". Toyota says to check:
Fuel injector assembly (for direct injection)
Intake system
Gas leaks from exhaust system
Ignition system
Compression pressure
Air fuel ratio sensor
ECM
The Following User Says Thank You to sirsol66 For This Useful Post:
strat61caster (10-04-2017)
Old 10-04-2017, 12:47 PM   #65
funpolice
p119 + P219A
from canada.
see my previous post about the car spec.
dealer will replace the ECU or ECM(computer unit). Not sure if this will fix the issue.
Old 10-04-2017, 01:47 PM   #66
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Hey sorry if this is off topic but what obd2 reader/device do you guys recommend. I've been shopping around but and recommendations would be helpful. I need one that I is its own device or plays well with iphone
DandoX is offline   Reply With Quote
Old 10-04-2017, 01:47 PM   #67
sirsol66
from canada.
Do you know what other diagnostics they did? I just went through TQCN to see what the fix for this is, and ECU/ECM replacement is not even in the solution tree. Basically it entails identifying the problem cylinder, checking its compression, checking its fuel injectors, and then checking the wiring to the injectors.
Old 10-04-2017, 04:20 PM   #68
funpolice
just came back from the dealer. they are not 100% certain ecu replacement will fix the issue. but it's the 1st step. and they know the ecu is sending 'faulty signals'
Old 10-08-2017, 02:10 PM   #69
femaledog
Drives: 2017 BRZ Perf. Pkg.
I just wanted to add that I have a 17 BRZ. 2,000 miles, throwing both P117F and P219A. These just popped up this week, I haven't had time to investigate further.
femaledog is offline   Reply With Quote
Old 10-09-2017, 12:31 PM   #70
sirsol66
Check the DI seals & oxygen sensor. The two confirmed fixse I've seen for these two CEL's on a 17+ 86 involved replacing the lower teflon seal on one of the DI injectors, or tightening a loose 02 sensor. You may be able to check by spraying water directly on the base of the DI seal and see if bubbles form or not.
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
