Old 07-13-2017, 04:52 PM   #799
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Originally Posted by Overdrive View Post
It's possible I missed it, but I did look through this thread just about completely. So is there a way of getting the oil temp PID to read in Fahrenheit? I already had Torque set to display things in °F, but the way the PID is detailed in this thread is for display in Celsius, so that's what gets displayed for that one gauge.
In the app set-up menus are a set of options to select units.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-13-2017, 09:36 PM   #800
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
As I said, I already had that setting in place, but the way the PID math is presented in this thread its output is in Celsius.
@lazyluka nailed it, so thanks for the math fix, my friend. Wanted to smack myself for the way I set it up at first, it sent the temps in the complete opposite direction. Parentheses are powerful little things.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
lazyluka (07-13-2017), SPCorBUST (04-21-2018)
Old 07-14-2017, 06:49 PM   #801
Overdrive
Sittin' Sideways
Overdrive's Avatar
So yet another interesting thing. I had to pair my OBD2 dongle all over again, and when I did everything reverted back to Celsius. When I set it back to Fahrenheit, the reading for the oil temp was all crazy again. Went back to the AC-40 format and now the app converts it to Fahrenheit like it does with all the other built in gauges.
Also glad I did this because now I see just how long it takes, even on a mild summer day, for oil temp to get to 200 degrees. I had to have been halfway through my work commute (about 10 of 20 miles) before it was finally up there. Have to make sure I'm nicer to the car longer before I start pushing it now that I know it can take a while to heat the oil. Winter is going to be interesting.
-O/D
2016 FR-S, Hot Lava
Old 07-23-2017, 01:27 AM   #802
canon_spec
Drives: FT86 GTS
Anyone able to point me in the right direction to getting torque to display boost. I tried the default boost and vacuum reading but it only seems to display vacuum. I can see others have got it working just not sure how.
canon_spec is offline   Reply With Quote
Old 07-27-2017, 01:57 AM   #803
adjusts
adjusts's Avatar
Drives: 86
Originally Posted by cebul View Post
But I'm connected with the car with no problem, all.other parameters are fine example. Revs, coolant temp, exc.
Just can not get oil.temp Pid displayed on the real time data screen.
Sent from SG Smartphone.
how did you end up fixing this? I'm having this same issue
adjusts is offline   Reply With Quote
Old 09-28-2017, 10:27 PM   #804
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
I bought the BAFX OBD adapter on Amazon and tested it on both ends of my OBD splitter and it works perfectly. But I also have insurance from Metromile and they require me to plug a device in the OBD to read my mileage each month. Once they're both plugged into the splitter I get problems with the OBD adapter and some functions not working on Torque app. Any solutions?
Sent from my iDroid
Jajanken86 is offline   Reply With Quote
Old 09-29-2017, 04:08 PM   #805
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
new insurance company
IceFyre13th is offline   Reply With Quote
The Following 2 Users Say Thank You to IceFyre13th For This Useful Post:
Chimera (12-06-2017), Jajanken86 (09-30-2017)
Old 09-29-2017, 04:21 PM   #806
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Sent from my iDroid
Sounds like you can't use both devices at the same time.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-29-2017, 04:22 PM   #807
redhalo
Drives: MY20 Hakone Toyota 86
Sent from my iDroid
I've run into a similar situation between my ODB adapter and my Verizon network adapter. My research came to that the second device may be interrupting the handshake with the ODB device. I've gotten both to work at the same time through some fluke of repairing bluetooths, but then the ODB fails after next car start. I haven't found a solution yet either.
redhalo is offline   Reply With Quote
The Following User Says Thank You to redhalo For This Useful Post:
Old 09-30-2017, 10:00 PM   #808
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Yes after more testing I've learned the moment I unplug Metromile, everything works just fine. Once I plug Metromile back in things fail instantaneously. Metromile never seems to have problems though. I wouldn't really mind if the problem was the other way around haha
Sent from my iDroid
Old 11-19-2017, 01:57 PM   #809
q335r49
Drives: 2013 scion fr-s
Just wanted to share this in case anyone needed a daylight readable setting, since it took me awhile to figure out:
I picked one of the transparent themes, navigated to .torque/themeDir in the sd sd card and changed the following values in properties.txt
#make axes white
displayTickColour=#FFFFFF
#make value text red
displayTextValueColour=#FF0000
#Make all text light light gray
displayTextTitleColour=#DDDDDD
#Make RPM's Red
graphLineColour_0c=#FF0000
#make boost black
graphLineColour_ff1202=#000000
#make afr black
graphLineColour_ff1249=#000000
q335r49 is offline   Reply With Quote
Old 12-03-2017, 09:54 PM   #810
rob 2fast4u
rob 2fast4u's Avatar
Drives: 2JZ BRZ
Can anyone help me out on how to get torque to display information quicker? There's about a second lag. I'm using obd link mx for a Bluetooth output and Samsung 7" tablet with torque pro.
rob 2fast4u is offline   Reply With Quote
Old 12-04-2017, 10:54 AM   #811
8RZ
The Gunshine State
8RZ's Avatar
From using Torque on the past few cars I've owned, that's pretty normal when it comes to Bluetooth adapters, it's just not as fast as a wired connection.
Current DD: M235i
Old 12-18-2017, 08:17 AM   #812
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I was gonna go through the whole thread but it felt like I was reading a review about the Nexus 7.
Does this app work on most devices? I got a old Galaxy A3... Wondering if itll work..
Also, did anyone have trouble reading anything from a device while driving?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
