Software Tuning Discuss all software tuning topics. |
Drives: 2013 FR-S, 2015 TC
Longer OFT Cable
Sorry if this has been answered before, if so delete this.
I didn't find anything in the search but i was wondering if anyone had a solution for the short cable that the oft comes with, also possibly a 90 degree obd connection as the plug is large and in a horrible spot on the 86.
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY KANSAI DORIFTO |
#2 | ||
Proud of BOXER
Drives: Subaru Boxer
I believe you can find them on eBay, some of them even have an inline switch so you can leave the OFT connected at all times and just use the switch as an on/off toggle.
The Following User Says Thank You to Clipdat For This Useful Post: | Takumidesh (09-29-2017) |
#3 |
Drives: Neptune GR86
There's lots on Amazon.
Right angle, flat cable, inline toggle switch... Just search Amazon.
The Following User Says Thank You to Andrew025 For This Useful Post: | Takumidesh (09-29-2017) |
#4 |
Drives: 17 Series Yellow BRZ
Just need an OBD2 extension cable. All over Amazon
The Following User Says Thank You to Jasonb For This Useful Post: | Takumidesh (09-29-2017) |
#5 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Here's the one I have, pretty solid construction.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
The Following User Says Thank You to BirdTRD For This Useful Post: | Takumidesh (09-29-2017) |
#6 |
gotcha, I don't know why an obd extension cable hadn't crossed my mind, for some reason I was thinking I would need a cable with the same pins as the oft. thanks!
#7 |
Just extend it at the odb2 port end, not the oft end. Also a right angle extension should help move the cable out of the way of your legs if you're going to use it while driving.
#8 | |
Gauge install, dash cluster light cable, Tach RPM cable help... | Sportsguy83 | Electronics | Audio | NAV | Infotainment | 99 | 08-07-2016 10:36 PM |
no longer available | AllOutApex | Australia Classifieds | 0 | 01-20-2016 08:08 PM |
No longer for sale | SliverBrz | Engine, Exhaust, Bolt-Ons | 13 | 03-17-2014 11:44 PM |
No longer available | funx | Canada Classifieds | 3 | 10-29-2013 09:10 AM |
Longer brake light cable needed | Basti | Electronics | Audio | NAV | Infotainment | 1 | 02-06-2013 01:39 PM |
