Old 01-27-2013, 12:06 PM   #1
Basti
Basti's Avatar
Longer brake light cable needed
So I'm doing some trunk cleaning and I've realized that the OEM cable is too short for that. Now at this stage I make it a principle not to cut, splice and solder around (warranty reasons).
The cable running from the brake light to the harness fixed to the trunk is connected via a simple 2-pin plug which can be dismantled and put together again.
That said, what I need are a few male and female pins of the same type as OEM in order to maintain compatibility and a generic male/female plug to fix to the 15-20cm extra cable I have to add. What'd be even better would be to have the very same type of plug as is already used so I won't have do dis-and reassemble the factory plugs at all.
Can anyone with the knowledge have a look at the plugs and pins from his middle tail light and tell me the specs of the pins and preferrably source to buy from? If there's no way of getting new ones maybe I may salvage from other models?! (the Toyobaru still being to rare for that)
All help appreciated. When and if it works I'll show you what I did.
Basti is offline   Reply With Quote
Old 02-06-2013, 01:39 PM   #2
Basti
Basti's Avatar
noone at least got an idea on what type of pins are used?
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 03:23 PM
ECUTEK Cable needed in SW USA gmookher Southeast 0 08-28-2012 12:57 PM
