Old 09-27-2017, 09:23 AM   #15
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Check again every few days. When I installed a set of used ST's with a stripped set screw I used a big hose clamp, and that actually worked great. No movement at all.
JazzleSAURUS is offline   Reply With Quote
bottoming out, bracket lock, coilovers, preload, tein
Showa spring/shock available soon mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 110 01-04-2023 03:03 PM
Coilover VS Spring/Shock ImAdopted Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-24-2017 05:04 PM
Cusco dual adjustable monotube shock mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-24-2017 10:07 AM
SCCA Touring 4 Non-Adjustable Shock absorbers Iwannajag Tracking / Autocross / HPDE / Drifting 20 04-15-2015 03:26 PM
