| Software Tuning Discuss all software tuning topics. |
The Stripes Add HP
Drives: 2017 Toyota 86 860
RomRaider help? ECU definition cannot be found even when present?
Hi guys!
As the title says I'm currently having issues with RomRaider not detecting or having incompatibility issues with my definition. I have added the .xml for my tune provided by Shiv into the definition manager, applied and saved, so all should be good in that regard, correct? Well, when trying to open my .bin image, it brings up the error "ECU definition not found". I'm not sure if I'm just missing something stupid, or if my .xml and .bin are incompatible for whatever reason, but I need some assistance regardless. Any ideas as to what may be causing my problem? Here are some screen grabs of my RomRaider to show that I'm doing everything hopefully correct. Thanks! ![]() ![]()
#2 |
Drives: GT86 AT 2013
i got this message when the Cal ID's are not matching.
Open the Xml with a notepad and look for the vehicle Data and check if it has the same Cal ID as your Rom
#3 |
Drives: Toyota 86 GTS
Rom is K00D and definition is F00D, therefore you don't have a definition for K00D.
#4 | ||
The Stripes Add HP
#5 |
The Stripes Add HP
Seems to be working okay I think? I'm still able to load a lot of tables, but maybe some (or a majority) are excluded due to this data mismatch error?
#6 |
The Stripes Add HP
Alright final post regarding this issue which seems to have been resolved in a much easier fashion than I expected. So my main goal with all of this was to modify my ROM to allow my car to backfire, which it pops once when shifting at high RPM but that's about it. More pops when releasing the accelerator would be nice. Any idea how to accomplish this given this table? I don't think the numbers on the left side are supposed to be that high, but hell do I know? What numbers should I change to accomplish this?
#7 |
Do not use this Def file, its a wrong one.
For sure you can open it editing the Cal ID. But the storage adresses are not matching your rom, and thats why it doesn't display the correct values Look for a "real" K00D Definition and do not edit something with this one
#8 |
Rom is K00D and definition is F00D, therefore you DO NOT have a definition for K00D.
#9 | |
Drives: FT86
Every rom calid has tables in differnt locations, you cannot just change the calid in a def and expect it to work. This is an easy way to brick your ecu. Please read the Romraider tips link below. Only use the KOOD def that came with your tune from shiv, if you did not get a def from shiv then you will need to ask him for the correct def |
#10 | |||
The Stripes Add HP
Thanks guys! |
| The Following User Says Thank You to Xaftos For This Useful Post: | steve99 (09-27-2017) |
| Tags |
| 2017, oft, romraider, tune, tuning |
| Edit OFT Definition for RomRaider | blackspike | Software Tuning | 7 | 02-13-2016 03:18 AM |
| Definition of rice? | Hot Lava | Off-Topic Lounge [WARNING: NO POLITICS] | 42 | 05-30-2014 03:41 AM |
| ECU table functions and definition of tables | brn12345 | Software Tuning | 7 | 11-14-2013 08:45 AM |
| E46 M3 photo/video shoot by Project Definition | DTMAUTOBODY | Other Vehicles & General Automotive Discussions | 0 | 06-18-2013 07:00 PM |
| AS1 Definition? | nixeighty6 | Scion FR-S / Toyota 86 GT86 General Forum | 93 | 01-12-2012 01:56 AM |
