Old 09-22-2017, 03:15 PM   #1
Xenov
Drives: 2016 Scion FR-S
OFT help
So I sent OFT a e-mail about my issue and I haven't heard a peep is this normal? I read the forum and tips but cannot get it to work... This is what I sent them:
I received my OFT today and did the ECU read and when it finished both the read and write functions are greyed out. My car is a 2016 scion FRS and had no mods on it when I purchased it though I did buy it used. Also when I clicked the identify ECU function it came back everything unknown. Please help I don’t know what to do and I just spent $499.00 on this tablet.
Any insight would be greatly appreciated!
Thanks in advance...
Xenov is offline   Reply With Quote
Old 09-22-2017, 03:28 PM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
If you didn't do it already, go to the download page of OpenFlash (Link)
Download OpenFlash manager (OFM) (Win only) and Toyota GT86 Off-The-Shelf (OTS) Tune Files
Install OFM and unzip the OTS files (ex: c:\tunes)
Connect the tablet with your pc and open OFM, let it update the tablet.
Go to Upload data, take a look at your calId (1), Click on the folder in (2) and navigate to your tunes folder, open the folder with your calid and select your tune, stage1 for stock vehicle, stage2 for UEL header. Press Start in area (3).
Go to your car and flash it.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
Vin (09-22-2017)
Old 09-22-2017, 03:55 PM   #3
Jasonb
Drives: 17 Series Yellow BRZ
Read and write will be greyed out once you read your ECU and if there are no compatible tunes loaded onto the oft. Your problem is probably just as simple as needing to load the right tune file into it from your computer.
Jasonb is offline   Reply With Quote
Old 09-22-2017, 09:39 PM   #4
Freerider
Drives: 2015 f150 crew cab 4x4 '13 FRSraven
Why are they not preloaded?
Freerider is offline   Reply With Quote
Old 09-22-2017, 10:03 PM   #5
Xenov
I have tunes preloaded but for some reason it won't write.
Old 09-22-2017, 10:04 PM   #6
Xenov
I tried your solution but it says the file is not compliant... thanks for the help...
Old 09-22-2017, 10:07 PM   #7
Jasonb
Tried what solution? If "write" is greyed out then there are no compatible tunes loaded onto the oft.
Old 09-22-2017, 10:11 PM   #8
Xenov
Sorry I tried elbartos solution but it will not let me load any tune files it says selected file not compliant
Old 09-22-2017, 10:35 PM   #9
steve99
Drives: FT86
Download the file\tune calked original this is your stock tune to pc, then post it up here you will need to zip it to upload to forums
Its likly a calid hacked rom but ill loom at it if you post it up
Old 09-22-2017, 10:50 PM   #10
Xenov
ZA1JF40D.zip
Hopefully I did that right thanks for the help steve99
Old 09-23-2017, 12:41 AM   #11
steve99
Drives: FT86
Attachment 158539
Ok its a real F40D rom not calid hacked
so you need to go to openflash site download site and download the tunes unzip and load up the ZA1JF40D tunes you want for your car to OFT
http://www.openflashtablet.com/downloads/
post here from shiv confirms F40D rom is supported
http://www.ft86club.com/forums/showt...36#post2618436
how to upload tunes
[ame="https://www.youtube.com/watch?v=92SV3VpV_1E"]Uploading Files to Tablet - YouTube[/ame]
Old 09-23-2017, 09:31 AM   #12
Freerider
So, how can they say "preloaded with tunes" and "no laptop required" when it's neither of those?... If I knew it was not as advertised, I'd have never bought it. Those are the two huge selling pts. (For me)
Old 09-23-2017, 09:33 AM   #13
Xenov
how to upload tunes
Steve99 thanks for all the help but I cannot get a tune to load I am attaching screen shots of the process hopefully if I'm doing something wrong it will show up here.
I tried every tune file in the zip just in case and not 1 of them will load.
Old 09-23-2017, 09:34 AM   #14
Xenov
It was preloaded with tunes but for some reason my OFT wont load any of them and that's what I cannot figure out. I erased the preloaded tunes and downloaded the new tune Zip but same issue.
