Old 09-22-2017, 01:14 AM   #15
CortJester24
CortJester24's Avatar
Drives: 2017
Are you guys going to be testing more wheels? I'd personally like to see some Enkei wheels tested, preferably 18x9.5 in any of the wheels they make for our cars.
CortJester24 is offline
Old 09-22-2017, 10:22 AM   #16
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by jamal View Post
Did you happen to measure the piston sizes?
32mm on all pistons according to our digital caliper. Pistons are not tapered.
So ft86speedfactory, where were you able to get hands on the PP calipers? I would be greatly interested if we can convert nonPP cars to these
Yes, the calipers you see are the OEM PP calipers that we purchased from our local Subaru dealer. The tie bar and bolts were also purchased from the dealer.
Otherwise, we've added the DBA rotors we sell on our Subispeed side for STI application as well as STI application pads to complete the kit. OE lines can be used on these calipers, so any SS line that is offered for the twins should work as well.
Originally Posted by airindia33 View Post
What about ss brake lines?
Any aftermarket SS line kit currently available should work.
Yes, once time permits!
FT-86 SpeedFactory is offline
The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
SkAsphalt (09-22-2017), TachyonBomb (09-22-2017), Tristor (02-28-2018)
Old 09-22-2017, 11:59 AM   #17
Code Monkey
Drives: Subaru BRZ
So the pad shape for the front is FMSI D1001 / D1016 / D1050. What is the FMSI for the rear?
Code Monkey is offline
Old 09-22-2017, 02:19 PM   #18
jamal
jamal's Avatar
Drives: Legacy GT
Probably 961.
That doesn't sound right; those numbers would result in only 55% of the piston area of the stock front calipers and a very different bias.
Did you take off the boots and measure the piston where it sits in the bore, or just the face of it? Pistons look like this usually
jamal is offline
The Following 2 Users Say Thank You to jamal For This Useful Post:
chaoskaze (09-25-2017), Tristor (02-28-2018)
Old 09-22-2017, 10:56 PM   #19
ryann.mendoza
Drives: 2017 Subaru BRZ limited PP
Any chance you'll try the te37v sl 17x9 +36 / 17x9.5 +40 for clearance? Really interested in picking up a set from you guys. Thanks!
ryann.mendoza is offline
The Following User Says Thank You to ryann.mendoza For This Useful Post:
cjd (09-28-2017)
Old 09-28-2017, 02:16 AM   #20
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Otherwise, we've added the DBA rotors we sell on our Subispeed side for STI application as well as STI application pads to complete the kit. OE lines can be used on these calipers, so any SS line that is offered for the twins should work!
Do you have the part numbers needed for the pp upgrade? Highly interested in doing the swap and calling up a local subaru dealer to get pricing
Instagram: trevor.parque
MisterSheep is offline
Old 09-28-2017, 02:56 AM   #21
imnotsureaboutbrz
Drives: between cars...
Well... you can put the RPF1s 17x9 +35 on the no fly list. It took 8mm worth of spacers to get this clearance (and poke). Learn from my mistake.
imnotsureaboutbrz is offline
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post:
orz (10-30-2017)
Old 09-28-2017, 06:02 PM   #22
FT-86 SpeedFactory
Those will not work.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
ryann.mendoza (09-28-2017)
Old 10-03-2017, 02:27 AM   #23
Daemonomics
Drives: 2017 WRB BRZ Limited PP 6MT
Hello!
Man, the combination of the PP Brembos plus this bolt pattern make it so hard to find good wheels that fit without spacers... I've been trying to find the right wheels for awhile and I've basically narrowed my search down but may have to go back to the drawing board if this won't work. Would this fit at all?
TE37 Saga 17x7.5 +44
Thanks for your time, hope to hear back from you soon!
Daemonomics is offline
Old 10-03-2017, 02:36 PM   #24
empower-auto
Kouki-Monster
empower-auto's Avatar
There's a lot of wheels that fit
All Enkei RR wheels in 18"
Advan RZII 18x9.5 +45
Rich Anderson
EMPOWER AUTO
empower-auto is offline
Old 10-04-2017, 11:44 AM   #25
TRBO FRK
Drives: 2017 BRZ series yellow
What is the weight on the GRAM LIGHTS 57DR WHEELS 17X9 +38MM? Also were guys able to fit any other wheel options for the 2017 BRZ w/ performance package?
TRBO FRK is offline
The Following User Says Thank You to TRBO FRK For This Useful Post:
Old 10-04-2017, 04:56 PM   #26
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
HAWK CERAMICS for your Performance Brembos
These are the HAWK CERAMICS that fit the Performance Brembos on my 2017 Yellow BRZ
Enkei RaiJins 18X8.5/9.5 +45
245/35 18 Michelein PSS
I LOVE these pads, very little dust, Great stopping power for the street. Rotors smooth as glass.
Had Hawk Ceramics on my 2013 BRZ Limited for 52,000 miles and they were half way worn.
Those are 2011 STI center caps, had polycarbonate spacer rings made in Hungry for $5. shop here wanted
$180. The lugs are from FT-86 SpeedFactory.....the frosting on the cake!
007BRZ is offline
The Following User Says Thank You to 007BRZ For This Useful Post:
Old 10-05-2017, 01:39 AM   #27
MisterSheep
Killed Scion
Anyone think they Wedssport TC105n in 17x9+35 would clear these brakes?
G_Ride (02-01-2019)
Old 10-15-2017, 06:50 PM   #28
86ZCA
Drives: Crystal White Pearl BRZ Limited
Anyone know if the series blue sti wheels 17x7 +48 will clear the OE brembos?
Sent from my SM-G935T using Tapatalk
86ZCA is offline
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 10:36 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 10:25 PM
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue DaJo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-25-2018 06:12 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 11:04 PM
Someone tested the Performance Package... small but SOME info at least ~el~jefe~ BRZ First-Gen (2012+) — General Topics 13 11-29-2016 05:21 PM
