Wheels for Brains
Adjustable Coilovers - Loose Shock Assembly and Spring Unloading
Hey all,
I've recently installed coil-overs (Tein Flex A) and have been adjusting ride height. Before I put them on the car, I adjusted all of the coil-over reference dimensions and preload according to the installation manual. I torqued all of the nuts and bolts to specification. The only thing I didn't double check torque on were the spring seat, spring lock, and bracket lock (since they are tightened by the custom spanners). I made them as tight as I could. Everything was kosher for the first few weeks, and I went about my way dialing in the ride height. When I went under the car several times. Nothing appeared to change that much from my original set-up (which I compared and a noted each time I took the wheels off). Fast forward a couple of weeks: I began to notice that I was bottoming out at the front over moderate bumps (which did not occur before). I got back under car and noticed that the spring preload had pretty much come undone. However, the spring seat and spring lock hadn't come undone from each other and were tight as a unit. It appears like the entire spring assembly moved down (either over time or as part of a single incident). EDIT: The cylinder assembly itself didn't appear to spin. The markings I put on the bracket lock and cylinder were still pretty much in-line. However, the distance between the spring lock and bracket lock were greatly reduced; this caused the spring to come down and unload. As a side-effect, it caused me to bottom-out more than usual and spurred my investigation (my ride height was made unideally lower and shock travel was reduced.) Before and after looked something like this (with no intervention from myself): ![]() How can I prevent this from happening again? Do I need to torque down the bracket lock (which holds the ride height adjustability) more? UPDATE: after getting a professional alignment, the mechanic noted that he was able to tighten the spring seat and lock even more. He said I didn't appear to have done anything incorrect, as the two collars were already very snug. He commented that he was able to cinch them down tighter to his satisfaction (though he commented that the process was abnormally difficult for him). We weren't sure exactly why it was difficult, but I speculate the tolerance on the collar faces aren't the greatest. I obtained reference measurements and will continue to monitor them. Thanks! Last edited by EndlessAzure; 09-27-2017 at 04:43 AM. Reason: Changed effect for clarity. Cylinder didn't move; the spring seat and lock moved. Updated with feedback from specialist |
#2 |
Drives: 2005 Toyota Camry
This is a fact of life with coilover ownership, you have to check regularly.
Nothing you can do will truly prevent this. |
| The Following User Says Thank You to mav1178 For This Useful Post: | chaoskaze (09-19-2017) |
#3 | |
Drives: 2013 Satin White Pearl BRZ
I wonder op,how are you tightening the two cm nuts that position the bottom of the spring Sent from my Pixel using Tapatalk |
| The Following User Says Thank You to jbailey8748 For This Useful Post: | 8RZ (09-19-2017) |
#4 |
The Gunshine State
Drives: '14 BRZ Limited
I also disagree, even on my cheap shitty Megans I haven't had to re-tighten anything and I check them once every few months.
![]() Current DD: M235i |
#5 |
Drives: 2013 WRB BRZ
Are you sure you're adjusting ride height and not preload? Not to insult your intelligence if you are, but the 2 rings in the middle are for preload, and the whole assembly actually turns into the bottom to adjust ride height and is locked with the single ring on top of it.
The coilovers on my old car were the kind where these 2 rings did adjust height, and I was confused as well. After playing with them for a bit, I figured it out. Also see this video: [ame="https://www.youtube.com/watch?v=u09hRYVS5o8"]How to Adjust Coilovers - YouTube[/ame]
#6 | ||
Wheels for Brains
I set-up the coilovers according to factory measurements. Using the spanner wrenches, I spin the top nut (spring seat) into the bottom nut (spring lock). They spin in opposite directions (essentially, the spring seat comes down on the spring lock) until they are snug against each other. Quote:
My problem is slightly different. I didn't touch the two middle preload rings, but over time they came down and eventually unloaded the spring while on the car. Last edited by EndlessAzure; 09-19-2017 at 01:25 PM. |
#7 |
Drives: Subaru BRZ
Did you only tighten them with the supplied tools? If so, thats not enough friction to keep them there. In general you'll need to use a screw driver and hammer (rubber mallet) to really get them together to keep them there.
| The Following User Says Thank You to SpectreRT For This Useful Post: | EndlessAzure (09-27-2017) |
#8 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Yep, you need to torque down the perches more. Its a problem on some of the Tein units, use a torque wrench in combo with the spanner wrench. (The Tein spanners have a hole for a torque wrench)
The manual will state what torque values... |
| The Following User Says Thank You to Cockatoo For This Useful Post: | EndlessAzure (09-27-2017) |
#9 | ||
Unless the coilover spring perches have a locking mechanism, it is possible that they will come loose over time. I've owned about ... 50 or so different brands of coilovers over the last 20+ years. The general rule for adjustable coilover ownership is that you have to check them on a regular basis. Some are built more robust than others and have secondary mechanisms for locking. I've also owned coilovers that never needed adjustment, but that doesn't mean I don't check it every month of street driving or so.. If you want an install-and-forget setup, you get nonadjustable springs/shocks. -alex |
#10 | |
Wheels for Brains
By "perch"" do you mean the locks/seats on the coilover cylinder?? |
#11 |
TALLY FT86
#13 |
Drives: Subaru BRZ
#14 |
Wheels for Brains
UPDATE: after getting a professional alignment, the mechanic noted that he was able to tighten the spring seat and lock even more. He said I didn't appear to have done anything incorrect, as the two collars were already very snug. He commented that he was able to cinch them down tighter ti his satisfaction (though he commented that the process was abnormally difficult for him). We weren't sure exactly why it was difficult, but I speculate the tolerance on the collar faces aren't the greatest. I obtained reference measurements and will continue to monitor them.
| Tags |
| bottoming out, bracket lock, coilovers, preload, tein |
| Showa spring/shock available soon | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 110 | 01-04-2023 03:03 PM |
| Coilover VS Spring/Shock | ImAdopted | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 08-24-2017 05:04 PM |
| Cusco dual adjustable monotube shock | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 01-24-2017 10:07 AM |
| SCCA Touring 4 Non-Adjustable Shock absorbers | Iwannajag | Tracking / Autocross / HPDE / Drifting | 20 | 04-15-2015 03:26 PM |
