Old 09-14-2017, 10:32 AM   #2899
M0nk3y
Originally Posted by Simmons View Post
That would require you to be faster then me
Simmons
Be careful not to make the car another s2k
Kyle H. - #89 STX
Old 09-14-2017, 12:25 PM   #2900
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I own this one......so it will good.
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 09-14-2017, 03:58 PM   #2901
gshumaker
Drives: 2014 BRZ
Congrats to Lugod on his championship! Fantastic first run Day 1 and way to deliver what you needed on the last run of Day 2 with your back against the wall. Congrats to all the others in the trophies.
I had to leave early due to the hurricane looming in Florida thus didn't run Day 2. I was sitting 28th after Day 1, so it didn't matter much other than not getting to run the West course. Ended up being the first time I hadn't trophied at nationals since my first appearance (5 trophies in a row at nats until this year)--a testament to how tough the competition in this class is, methinks.
My car during the Pro was an abomination. All the turns after the slalom it would just plow on exit. Turned out I had accidentally reversed my front-end shock settings--the compression set almost full stiff in the front and the rebound almost full soft. Also had a ton of toe-out and almost zero camber in the right-rear according to an alignment rack I took it to. Car was way way better for the championship after addressing these issues...but the driver wasn't. Our camera flew off the car during my co-drivers first run and was destroyed so I have no videos but pretty sure most of my time was probably because I just drove like a total wimp in the offsets before the showcase and didn't execute the finish that well on any of my runs.
Now for decisions for me for next year. Run STX again and work on my driving/setup? Or drive my SS 1LE as an underdog in AS. I'm very lucky to have two super fun to drive cars at the moment--albeit in completely different ways. It is going to be a tough decision.
gshumaker is offline   Reply With Quote
Old 09-14-2017, 04:32 PM   #2902
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Greg, run the 1LE in CAM
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 09-18-2017, 08:17 AM   #2903
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
What are all my STX guys running for sway bar end links? I'm currently using the Perrin rigid end links in the front and I'm getting that lower control arm contact after lowering the car
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
Bimble Bamble (11-04-2017)
Old 09-18-2017, 02:35 PM   #2904
cjd
cjd's Avatar
Drives: 2017 BRZ
The (probably too long) Whiteline parts listed for this chassis.
Old 09-18-2017, 09:03 PM   #2905
M0nk3y
McCaster Carr custom
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
Silver Ignition (09-22-2017)
Old 09-18-2017, 09:04 PM   #2906
e1_griego
e1_griego's Avatar
Drives: Many
Whiteline KLC180-195.
e1_griego is online now   Reply With Quote
Old 09-18-2017, 10:29 PM   #2907
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Got part numbers on that? The white line I've got is awful to keep tight and adjust in any reasonable amount of time. I've been meaning to do a 'custom' on the front.
Did OSH hardware out of the bins on the rear for $60-$80 iirc but the front will see a bit more stress...
ineedyourdiddly
Old 09-18-2017, 10:36 PM   #2908
renfield90
The Stig's German cousin
These look short enough to do the job (maybe too short, I haven't tried them yet): https://raceland.com/end-links/scion-frs-end-links.html
These also maybe are short enough, and have the added benefit of being very slim on the far side so you can get more camber without the endlink smacking the inside wall: http://racerxfabrication.com/frs-brz...ront-end-links
I haven't tried messing with this, but if you have caster adjustability, try reducing caster. I have a hunch that more caster makes the problem worse.
Old 09-18-2017, 11:15 PM   #2909
M0nk3y
Yea. I’ll get them for you tomorrow.
I mostly did it to provide inner clearance to my fender well cause of MCS shocks
Kyle H. - #89 STX
strat61caster (09-19-2017)
Old 09-18-2017, 11:33 PM   #2910
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I ran the Whiteline links. They're too long (easy to fix, cut them shorter, like 1") and a huge PITA to adjust when changing positions on the bar because they're so big. That said, I much prefer the balljoint design to a heim joint, but realistically... It's not a huge deal.
Pimpin' ain't easy
The Following User Says Thank You to DocWalt For This Useful Post:
Old 09-18-2017, 11:36 PM   #2911
e1_griego
e1_griego's Avatar
Drives: Many
The part number I posted is of the shorter whiteline endlink.
They've clearly rubbed the car because I have MCS shocks, too, but I couldn't keep the heims tight when I tried to make my own endlinks.
The Following 3 Users Say Thank You to e1_griego For This Useful Post:
DocWalt (09-19-2017), strat61caster (09-19-2017), tigermack (09-20-2017)
Old 09-19-2017, 11:01 AM   #2912
MoarTorqs
***** Lurker
Drives: 2015 BRZ
I just picked up the Racer X front endlinks. I haven't installed them yet, but I can get you some pics/measurements if that would be helpful.
MoarTorqs is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
