Old 09-17-2017, 12:26 PM   #1
H214M
Drives: Scion FR-S
Check engine light
I got a check engine light and idk how to get rid of it or what it is ? Has anyone had the same problem and how did you fix it ! Thank you
H214M is offline   Reply With Quote
Old 09-17-2017, 12:38 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Google says it's your ambient air temp sensor malfunctioning. This isn't going to affect anything other than climate controls.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
H214M (09-17-2017)
Old 09-17-2017, 12:39 PM   #3
H214M
Drives: Scion FR-S
Is there a way to fix this ? Like what do I have to do
Old 09-17-2017, 12:58 PM   #4
Well, to state the obvious, replace the sensor.
Since this doesn't really impact anything of consequence you could also clear the code and see if it comes back in case its a transient thing.
humfrz (09-17-2017)
Old 09-17-2017, 11:12 PM   #5
Yep, just disconnect the car battery for a few minutes, connect it back up ...... and see if you are lucky .......
Sometimes when you clear a code with a OBD tool, it will come back, but by unhooking the battery, it will stay away ......
Dadhawk (09-18-2017)
Old 09-18-2017, 07:18 AM   #6
Sometimes when you clear a code with a OBD tool, it will come back, but by unhooking the battery, it will stay away ...... humfrz
Disconnecting the battery will reset the sensor (basically rebooting it) if it retains key off power. Just resetting the code wouldn't do that.
Not sure an ambient temp sensor would have constant power, but certainly couldn't hurt.
humfrz (09-18-2017)
Old 09-18-2017, 07:43 AM   #7
steve99
Drives: FT86
If it the sensor is bad the dash display of outside temperature should not work.
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 09:00 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
