Old 09-14-2017, 03:04 PM   #1
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
CTSV Brake Swap Kit
Recently bought this and have decided to go in a different direction.
All the parts are brand new!
Cadillac Brembos
DBA Slotted STI Rotors
CTSV Brake Swap Kit
Brembo Caliper Pins
Everything is included EXCEPT for the brake pads.
600 Shipped
Located in SF, California
Check out my racing adventures on
@omi_racing on Instagram!!
2013 Scion FR-S//2015 Aluminos CRF 250R Kart//2009 CRG Briggs and Stratton Kart
http://www.ft86club.com/forums/showthread.php?t=119147
Tofurky is offline
Old 09-15-2017, 08:18 AM   #2
15limited
15limited's Avatar
Cadillac Brembos
CTSV Brake Swap Kit
Brembo Caliper Pins
600 Shipped
Wish I would've held out for this... paid nearly the same price for a used kit a month ago :/ killer deal!!
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline
Old 09-15-2017, 06:52 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Wheel size/offset requisite for these?
DarkPira7e is offline
Old 09-16-2017, 01:10 AM   #4
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
Not sure, I never got a chance to install them. I remember seeing a thread about offsets somewhere on the forum though.
Tofurky is offline
Old 09-16-2017, 09:13 AM   #5
15limited
15limited's Avatar
Minimum of +35 offset on a 17X9, you also have to consider J Factor, the curvature of the spokes from hub to rim. Enkei Rpf1s won't work in that size but Wrappers TC105Ns will. 18s generally give you more room to work with.
Old 09-16-2017, 09:58 AM   #6
azynneo
What about work meister 18x9.5 29 offsets in a disk
azynneo is offline
Old 09-16-2017, 02:21 PM   #7
ErikMurrow
Drives: 2013 frs
this is a good deal! fingers crossed it makes it to next week!
ErikMurrow is offline
Old 09-19-2017, 10:20 AM   #8
porsche550s
Drives: 2015 Subaru BRZ
Like stated above it all depends on the specific wheel I run a 17x9 42, a 17x8 45, and a set of 18x8.5 35 all of which fit with good clearance. only issue i've run into is on the 17x8 I had to place the wheel weights in a different location for clearance just for caliper edge.
porsche550s is offline
Old 09-19-2017, 11:48 AM   #9
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
For those asking questions, there is no set minimum offset or wheel width for these, or diameter for that matter, at least not within reason. It has everything to do with the specific design of the wheel, and how much clearance the spokes have from the hub. This is not codified in wheel offset but some wheels like Works have different disc types that can give you a pretty good idea.
Your best bet other than finding someone online who has already fit the exact model/size/offset that you want is doing what I did when I put SRT/benz brembos on the Z. Work with the wheel retailer. Sometimes they will send you a template that you can put on the car that will tell you if their wheel will clear. In my case, I just ordered one wheel after discussing some measurements with them over the phone and they guaranteed I could return it free of charge if it didn't clear. Once I was able to successfully test fit the wheel, I ordered the rest of the set.
OP, good luck with sale. I don't yet have my car back from the body shop so I don't know if it has been fixed well enough for me to keep it yet or not. If I did, I probably would have already bought these.
Yardjass is offline
Old 09-21-2017, 05:27 PM   #10
TheLowlyThird
Drives: '17 Toyota 86
Are these still for sale? If so, shipping to Hawaii?
TheLowlyThird is offline
Old 09-26-2017, 10:13 AM   #11
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
SOLD
Tofurky is offline
Brake Fluid Swap (How Many Quarts) Apex_BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 07-01-2019 04:41 PM
Wheel for 300zx brake swap wootwoot Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-14-2014 06:56 PM
E brake boot swap? Hardrock4445 NY / NJ / CT / PA 18 01-11-2014 12:10 AM
E-brake handle/boot swap Hanakuso DIY (Do-It-Yourself) Guides 1 08-26-2012 03:02 AM
