#15 |
Drives: 2017 manual BRZ
Prevents this shit from getting in your engine/intake manifold. Worth it.
![]() Sent from my Pixel XL using Tapatalk |
#16 |
Drives: 2017 BRZ w/PP
#17 |
Drives: 2017 BRZ
Depends on how you drive, my engine sees redline like 20 times a day and I'm losing quite a bit of oil from blowby
#18 |
Drives: 2017 BRZ
Anyone know how easy installation is?
Should I get pcv or dual? |
#19 |
#20 | |
Drives: Subaru
Ahh thanks. I've been out of the car scene for 12 years, did stand up jetskis and now have a toy car again. Greddy, hks, etc are the names i recall from my turbo mr2 days. |
#21 | |
Drives: 2014 Argento FRS
I've had the dual Radium cans on my SC car for almost a year now and definitely catching some blow-by. Install was super easy and mostly depends on how you route the tubing according to your engine bay mods. I think most concur a single can is enough for NA builds and only FI warrants the use of dual. Sent from my iPhone using Tapatalk |
#22 |
Huge E85 fan!
Drives: 2016 Scion FRS
I don't know why people are dogging Mishimoto- I have a https://www.mishimoto.com/compact-ba...an-2-port.html and it is a very high quality 2 port sealed baffled catch can. It catches a lot of shit in the PCV line. I also installed a ball valve drain on the bottom. It says 2 port (in and out) but there's a 3rd port on the bottom where I installed the drain using brass plumbing supplies from Lowes.
It's not a 86-specific part so you will have to make your own mounting solution, but that's not too hard if you're handy. The suggested price is $155 but 2 years ago I got mine for $100 |
#23 | |
Drives: 15 BRZ LTD, 05 FXT
The big name Japanese tuning houses are definitely still around and kicking, but a lot of lower quality components from companies like Mishimoto, (and lots of suspension brands, think Megan, BC, ISC, etc) have shown up on the scene. Most of these components are a high enough initial quality to work fine, but they are NOT made to last quality components, and won't give you the same high quality experience.
#24 | |
I'm on the THIRD radiator from them. THIRD. Radiators shouldn't just randomly spring pinhole leaks after working fine for a year. Radiator caps? After 4 I gave up and bought an OEM one. How can a company who claims to put in tons of R&D, (hint, they don't...) and create lots of performance cooling components not understand some of the basics, like making a damn radiator cap? Ship the thing with a Stant or just knock $10 off the price and don't include one. The components often times work, but they are FAR from a quality part. Next failure of my radiator, (it's got 15k on it now, so maybe in another 5-10k it will fail again,) I'm keeping the replacement in the box and buying a Koyorad. (FWIW their customer service is always very fast and helpful, but it does not excuse such a ridiculously low quality component.)
#25 |
Drives: none
I can recommend the Velox/Verus AOS mentioned on the first page. I installed one with my Harrop SC since it gave me somewhere to run the coolant lines that would otherwise have to be capped.
https://www.verus-engineering.com/pr...-oil-separator |
#26 |
Drives: '17 CWP Limited w/ PP
Just placed an order for the Velox kit. First mod being done to the car and will install it at the 1k break in oil change.
Little worried about the coolant portion of the install from just looking at the install guide, but I guess things will be self explanatory when I get to it. |
#27 | |
Drives: none
-Matt |
#28 | |
| Recommendation for GTA PDR? | 1Cor10:23 | CANADA | 12 | 11-08-2014 09:08 PM |
| Recommendation on coilovers please | Shad0ez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-27-2013 01:17 AM |
| PDR Recommendation in NoVA | soulstice | Mid-Atlantic | 6 | 07-09-2013 07:31 PM |
| Non LED recommendation for DRL | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2013 05:34 PM |
| PDX Recommendation for Detailing | JayNutter | Northwest | 2 | 12-08-2012 10:26 PM |
