Old 10-27-2013, 12:47 AM   #1
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Recommendation on coilovers please
Hello suspension gurus! Just got my FR-S 3 days ago and I've got the itch... no not the one down there, but the modding itch
Anyway, as most of you I'm on a bit of a budget and would like a set of coilovers that meet my needs without paying for more than what I would use it for.
Enough ranting. So I'm looking for a coilover setup with adjustable camber (I know a few setups come with camber plates for the front, but any setups come with rear ones too?) and a not too far from stock ride. Doesn't need to have adjustable dampers.
Suggestions are appreciated and if you are actually running the setup, I would love to hear your experience. TIA!
Shad0ez is offline   Reply With Quote
Old 10-27-2013, 01:06 AM   #2
rainmonkey
Drives: BRZ - Dark Grey
well... what IS your budget?
rainmonkey is offline   Reply With Quote
Old 10-27-2013, 01:12 AM   #3
Shad0ez
Shad0ez's Avatar
Budget is roughly $1,000. The FR-S is my daily, so no need for a hardcore track setup.
Old 10-27-2013, 01:17 AM   #4
cnk
Drives: '13 DGM BRZ Limited
So it sounds like you're going more for looks than for adjustability since this is your daily? If so, I would just go with some RCE Yellow springs. Use them on the stock struts until they blow and then replace with some Koni yellows. You can use camber bolts in the front and get some LCA's or UCA bushings in the rear.
cnk is offline   Reply With Quote
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
Recommendation for red out tails Overland'n'5thGEN Northern California 119 01-23-2014 04:20 PM
Recommendation for coilovers? Naikon210 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-14-2013 09:10 AM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 05:34 PM
