Old 09-11-2017, 01:39 AM   #1
dostoyevsky
Drives: 2017 BRZ
Catch can recommendation
Hey guys, I need recommendations for a catch can for my 2017 brz thats not too expensive but is also good, best bang for buck. Any suggestions?
dostoyevsky is offline   Reply With Quote
Old 09-11-2017, 01:50 AM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Radium.
Originally Posted by humfrz
I'm old and lazy
Old 09-11-2017, 01:53 AM   #3
DAEMANO
Time Traveller
1) Verus Engineering (formerly Velox)
https://www.verus-engineering.com/pr...-oil-separator
2) Racer-X Fabrication
http://racerxfabrication.com/frs-brz...stem/catch-can
3) Radium Engineering
http://www.radiumauto.com/Catch-Can-...RZ86-P374.aspx
4) Full Blown Motorsports
http://fullblownmotorsports.com/full...attery-tiedown
5) Not recommended - Mishimoto
Old 09-11-2017, 10:49 AM   #4
Jo0
Drives: '17 CWP Limited w/ PP
How necessary is it for the 2017s to have the AOS now? I'm on the fence on the entire velox set (aos, coolant, drainback)
Jo0 is offline   Reply With Quote
Old 09-11-2017, 11:13 AM   #5
Somerandom18
Drives: 2017 manual BRZ
I installed one the same day I brought my 2017 home. Recommend getting one for the PCV. The breather gets a little blowby but not enough to warrant a $200+ can/AOS. The way I drive, PCV catches a good bit. Going to upgrade to radium soon. Don't want anything but fuel and air taking up my combustion chamber space. No blowby allowed. MAXIMUM POWWAAA
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 09-11-2017, 12:33 PM   #6
mindless
Drives: Subaru
Just out of curiosity, why's the Mishimoto not recommended? (wow, first post)...
mindless is offline   Reply With Quote
Old 09-11-2017, 12:52 PM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
The vast majority of their products are pretty low quality, with enough R&D to say they did R&D, not enough to actually have remarkable improvements and performance gains.
Their radiators are often generic-ish fitment to cover an extra face lift or generation they have no business covering, their high performance fans move less air than stock fans, their thermostats stick, they don't even put their logo on silicone products straight.
I have personally experienced and tested their products and removed everything but my FXT radiator, and my BRZ intake tube.
The radiator will be replaced when I do the next motor, and the intake tube looks better than stock so it'll stay...for now.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 09-11-2017, 01:03 PM   #8
ZoLazoa
Drives: 95 miata mx-5
+1 Radium
Sent from my SM-G935V using Tapatalk
ZoLazoa is offline   Reply With Quote
Old 09-11-2017, 01:18 PM   #9
dostoyevsky
Drives: 2017 BRZ
Can easy was the install? I lose quite a bit of oil from the way I drive and I think the best option for me is PCV
Old 09-11-2017, 01:48 PM   #10
Somerandom18
1/10 install hardness. Super easy.
Old 09-11-2017, 03:12 PM   #11
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
A simple PCV valve catch can is such a simple system that really any baffled can will suffice.
That being said, the recommendations above (Radium, RacerX, Veerus) are all good choices.
Jyn is offline   Reply With Quote
Old 09-11-2017, 03:17 PM   #12
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Radium dual catch can.
Alltezza is offline   Reply With Quote
Old 09-11-2017, 03:42 PM   #13
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Forgive me for my ignorance, but as I understand these prevent oil from entering the cylinders with the air right? So If I don't track my car but have a decent daily commute, will a catch can lengthen the life of my engine? Would I see other benefits?
Slammillionaire is offline   Reply With Quote
Old 09-11-2017, 05:13 PM   #14
Jyn
Noob
Jyn's Avatar
When going wide open throttle (WOT), engine oil blow-by may occur. On these cars in NA form, under closed loop (basically, normal everyday driving), you will not see much blow-by.
tl;dr - it will not lengthen the life of your engine in any noticeable amount. Benefits would be you get a shiny item in your engine bay. It won't hurt anything, but wouldn't help much.
Recommendation for GTA PDR? 1Cor10:23 CANADA 12 11-08-2014 09:08 PM
Recommendation on coilovers please Shad0ez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-27-2013 01:17 AM
PDR Recommendation in NoVA soulstice Mid-Atlantic 6 07-09-2013 07:31 PM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 05:34 PM
PDX Recommendation for Detailing JayNutter Northwest 2 12-08-2012 10:26 PM
