Wheels for Brains
Rear Brake Caliper damage; worth worrying about/replacing?
I was doing some routine maintenance the other day on the car and noticed that my rear passenger brake caliper appeared to have some damage on it.
It's a continuous gouge on the outer edge of the caliper with the deepest part at the forward corner, though I'm not sure what caused it. I can't identify any obvious damage on the inside of my wheels, though they are quite dirty and may obscure detail. Is this cause for concern/replacement? I'm planning on partaking in a trackday in under 2 months, so I'd appreciate any feedback so I can get moving on corrective actions. Thanks!
#2 |
Drives: 2017 86 6-Speed
If it's a crack I'd replace it because it'll spread. If it's just a gouge I wouldn't worry about it.
Brake clean that caliper really well, and look at the ends of the gouge with a magnifying glass (or take a zoomed in pic with your phone if you have a good phone), you should be able to see a crack if it's there.
2017 86 set up for CS STX autocross
#3 |
[insert cool phrase here]
Drives: BRZ Premium
It's totaled. Sell car by a Honda.
Jk. Nothing to worry about. I'll question the last person who every worked on your car though.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#5 |
Drives: '13 FRS - STX
As long as it's not cracked and the caliper is still functional (it slides freely and it's not twisted or bent into the wrong position) then it's probably fine.
Watch for uneven pad wear, that'll be the telltale sign if it needs replacing. Luckily many people dump their OE parts for chump change in SoCal, watch the classifieds. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (09-12-2017) |
#6 |
Should be fine but I would really, REALLY want to know what caused it. OK this time around but if it happens again the results may be worse.
#7 |
Wheels for Brains
Thanks! Appreciate all the feedback.
I'll monitor it for now and update if anything happens. |
| Tags |
| brakes, caliper, damage |
| Stoptech S/S brake lines: same between stock caliper vs big brake kit? | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-10-2016 08:14 PM |
| Rear brake caliper banjo bolt size? | ChrisD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-22-2016 07:51 PM |
| F1 brake testing. Brake caliper porn! | Captain Snooze | Other Vehicles & General Automotive Discussions | 11 | 10-16-2015 01:55 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
