| Software Tuning Discuss all software tuning topics. |
#15 | |
It is possible to flash OFT ROMs with Tactrix. It also makes more sense because Tactrix is wide open. It's not at all idiot proof. The user has to double-triple check everything to make sure to use the right definition file and rom for the Calibration ID. I'm even more convinced your buddy fucked up. No offense. That being said. I'm getting out of my element. @steve99 is active here. Be nice to him and the other experts. You're in for a project.
#16 |
Huge E85 fan!
Drives: 2016 Scion FRS
#17 |
Drives: Scion FR-S
Yeah man I think he did fucked up and he said "No, it's just that it will think the tune I put on is the cars stock tune." Meaning the tune he put on it will be the one that gets married to the oft
#18 |
Drives: Scion FR-S
#19 |
Drives: 2014 GT86
Ultramaroon: IIRC one can also do open tunes with ecutek. Though of course it's not in best interests of tuning shops & in majority of cases they'll choose to encrypt tune.
| The Following User Says Thank You to churchx For This Useful Post: | Ultramaroon (09-04-2017) |
#20 |
The tablet is but not the ROM files.
#21 | |
edit: I'm pretty sure there's no action between an ECUtek ROM and a Tactrix dongle but, again, I'm admittedly at the edge of my knowledge. I have a Tactrix but I still haven't had the balls to flash with it.
#22 | |
Drives: FT86
Fuel level sensor and air temp sensor. Guy woukd have used tactrix and ecuflash not ecutek, it requires special cabke and an ecutek licience. Its possibke those codes tripp due fkash process interrupting can buss communications. Remove a battery termibal fow a few minutes to reset ecu and control modules in car. See if codes return, if so check above circuits fuses and diagnose and replace as necessary |
| The Following User Says Thank You to steve99 For This Useful Post: | Ultramaroon (09-04-2017) |
#23 |
Drives: Scion FR-S
![]() Sent from my iPhone using Tapatalk |
#24 |
Drives: Scion FR-S
This is what he told me
#25 |
Drives: FT86
| Check Engine light and Traction Control Light | JeRM | Issues | Warranty | Recalls / TSB | 25 | 06-02-2023 09:00 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
