| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3529 |
Drives: F-RS, FJ Cruiser
will a 245/40/18 tire on 18x8.5 +35 square fit stock frs?
#3530 |
Drives: 2013 SWP BRZ Limited
You should be fine. I'm running 235/40 18x9.5+38 OEM suspension and it's tight. You'll have an extra 3mm on offset and roughly another 12mm clearance on wheel width (if my math is right). The thing to look out for is spring perch and rubbing at full lock. You might poke a bit, so if anything you might need camber bolts. Sent from my iPhone using Tapatalk
#3531 |
Super Saiyan
Drives: 9000 HP FRS
im looking at either 1.5 or 1 inch drop on springs, will 17x9 +35 (enkei rpf1) be okay? what about them in 17x9 +45? im also looking at the enkei T6S 17x9 +45 and gram lights 57dr 17x9 +38? what tire size would be ideal for 17x9?
#3532 | |
I'd go 17x9 +35 if I were you. You could have clearance issues with springs at +45. Not sure about 17x9 +38, but that might work okay. I'd go 235/40 or 245/40 for tires depending on your meaty/stretch preference. I'd also flip through this thread...http://www.ft86club.com/forums/showthread.php?t=15160 Sent from my iPhone using Tapatalk
| The Following User Says Thank You to Waffle86 For This Useful Post: | ImAdopted (08-25-2017) |
#3533 | |
Super Saiyan
Drives: 9000 HP FRS
#3535 | |
Agreed^
![]() Quote:
#3536 | |
Super Saiyan
Drives: 9000 HP FRS
i dont plan on getting a bbk since it probably wont see track days but the RPF1s are such a nice wheel for a decent price and light so it caught my eyes. but good to know, i can start looking at other 17x9 +35 and see if anything beats out the RPF1s. thanks for passing some knowledge
#3537 | |
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#3538 |
86 Noob
Drives: 2015 Scion FR-S
Will be coming up on some Gram lights 57DR's that could not be passed up.. my current set up is just stock shocks on Eibach Pro Kit springs. The wheel and tire specs are 18x9 +38 on 255/35/18. Would they fit? What would need to be done?
| GReddy Supreme SP Exhaust | K&N Drop in filter | Eibach Pro-kit Springs | B2autodesigns 20&25MM Spacers | OEM style rear diffuser | CS Style Front Lip & Side Skirts | HT Autos Style Rear Spats | Valenti Tail Lights | |
#3539 | |
I'd be concerned about the front clearance to the spring perch. 255s are probably too wide without coilovers. Check the meaty tire thread. Good stuff in there and someone's probably tried this already. Sent from my iPhone using Tapatalk
#3540 |
Young Blood
Drives: 04 Wrx, 2014 Brz
Noob here... Just wondering if Enkei's TM7 17x9s with a 45mm offset would cause any issues? I have plans on lowering the car on coils max 1 inch.
If they do fit what tire specs would you guys reccomend? |
#3541 |
Drives: 2015 BRZ Limited
17x9 +45 trp c4
255/40r17 nexen sur4 Currently bone stock suspension. I will be upgrading and lowering eventually, but will probably eat through this set of tires long before then. So I am more concerned about wheel fitment than anything. I will probably want to eventually run 245s or 235s though instead of the 255s. I am most concerned with fitment to the suspension being +45 offset. Has anyone run a similar size? Long story short, I have a potential really good deal on the sur4's and have been looking at the c4's for a while. Reasonably priced and strong, even if they are not the lightest wheel in the world. |
#3542 | ||
245/40 is a good choice for tire size. 255's are a little overkill, but it will fit. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
