#10543 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Wrong fuse then! Should be off with the car off. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#10544 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Sent from my Pixel XL using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#10545 | |
I'll check the wires tapping into the ecu Sent from my Pixel XL using Tapatalk
NEW CAR!🚨🏎️⛽
#10546 | |
Wires wouldn't cause it to turn on from the ecu. How do you have the aux Charger connected? Sent from my iPhone using Tapatalk
#10547 | |
The procede and voltage gauge is going into that 10a fuse which is in the right spot. Procede going to the controller box near the passenger headlight. Controller box receives power from battery array and then to the ESC compressor Sent from my Pixel XL using Tapatalk
NEW CAR!🚨🏎️⛽
#10548 |
Controller is connected to the starter battery yes?
#10549 | |
NEW CAR!🚨🏎️⛽
#10550 | |
Dude... No clue now. Doesn't make sense... Curious if you are grounding something in the box. Sent from my iPhone using Tapatalk
#10551 | |
NEW CAR!🚨🏎️⛽
#10552 | |
~ After driving a bit or randomly lol. It will stay right around 28.1v and then it'll work with boost kicking in etc Here is a video of the procede software and the voltage gauge when it happens, thanks to @Waffle86: [ame="https://www.youtube.com/watch?v=KBK4UUEIae4"]Voltage going up under boost (Green tiles) - YouTube[/ame] Help! @Shiv@Openflash
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() Last edited by Aztec; 09-01-2017 at 03:18 PM. |
#10553 | |
Ok based on what I saw... I'm pretty sure it's the procede turning the controller off/on too quickly... Which is causing the charger in the controller to not know what state it's in. As for the 28.7 voltage that's normal don't worry about it. Sent from my iPhone using Tapatalk
#10554 |
Guess you want a solution... We need to either modify the map to be more digital or deal with it.
#10555 |
Quick little update. I Taped some exposed wires in the controller box and tightened some connections in the battery array (when I plugged in ESC something sparked in the array)
Ever since we're back up and running Thanks @Sojhinn for the help troubleshooting
NEW CAR!🚨🏎️⛽
#10556 | |
Time Traveller
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
