Old 08-26-2017, 12:24 PM   #393
steve99
Drives: FT86
just be carefull with launch and flat foot shift, this is a rom patch, so the rom is actually different. Stock roms don't have it but some oft roms do, early oft roms may not have patch.
check out the romraider tips link below
Old 08-28-2017, 06:10 AM   #394
Wil
Wil's Avatar
Drives: Drives like a crab.
Originally Posted by elBarto View Post
I see you are from Belgium. Are you a member of the facebook group GT86/BRZ Owners BeNeLux? Post your question there or PM me. I'll help you in Dutch
To answer your question, you need to update your definitions. Use Wayno's or Kodename47 defs, then you have all of those tables. The one's suplied with the OFT are very old.
Hi,
Yes I am.
But help in Dutch would kind of be no help at all, haha! I only speak French and English unfortunately.
Ok, I see, with more recent definitions I will be able to modify those tables.
I'm going to look after these tables. If I still have problem and will come back and bother you, haha.
Have a nice day,
RW
Wil is offline   Reply With Quote
Old 08-28-2017, 06:14 AM   #395
Wil
Wil's Avatar
Hi Steve,
Actually, I do not use these. I tried the LC and didn't quite like it.
That is not, to me, a true launch control feature and the rev limitation can be done manually.
But still, I don't think I do understand all that "patch" thing.
Is there any risk of any kind of me using your latest definitions with the ots bins provided by Openflash?
Have a nice day,
RW
EDIT: after further research, the issue seems to be a little bit more complicated.
I'm only allowed to use OFT definitions with the OFT roms. But, these definitions do not include the tables I need to modify in order to achieve a quieter cold start with a catless header. So, how do people achieve to have this quieter cold start using OFT and RomRaider?
EDIT2: Ok, I downloaded Kodename's definitions and it seems to work. Thanks!
EDIT3:
Took Kodename's definition of the A01G, the OFT .bin of version A01G as well and modified this.
Supposedly, it's right. I don't mind the higher RPM.
Old 08-28-2017, 04:21 PM   #396
steve99
Drives: FT86
Originally Posted by Wil View Post
Hi Steve,
Have a nice day,
RW
EDIT3:
looks ok,
I usually make the max idle rpm 1200 in all idle tables as well.
Definitions are an index into the standard rom code
Each different rom id can have the tables in different positions (due to manufacturer re-compiling code) hence you need matching definitions.
ROM code patches like LC/FFS are additional code written by someone and patched into the standard rom code. the process to hook these patches into the rom code can alter the position of existing standard tables. and add new tables to control the extra features.
hence you need a matching def for code patched roms to access the additional tables
you need
Old 08-29-2017, 02:27 AM   #397
Wil
Wil's Avatar
Funny thing is, I cannot upload via Openflash Manager A01G roms (created with a01g definitions). I can only upload A00G version, so that's what I did.
Old 10-14-2017, 03:05 PM   #398
bababooey
Drives: BRZ SWP Limited -6MT
Originally Posted by FRSBRZGT86FAN View Post
Thanks! I have edited my Values to match Waynos, as well as the injection ratio tables as you suggested, as for the idle stock before the edit it was at 750 RPM so I put it back to that. Also why does waynos car have -6.99 vs the -0.04 post start ignition timing I was supposed to have before? Thanks again for checking these:
kinda late to the party BUT after getting noise complaint @ apartment, I finally took the time to read this WHOLE thread (skimmed a couple parts) toughest part was sorting where to add the code from the romraider def into the OFT def into correct spot to enable maf correction tables to show up. i flubbed that part a couple times getting the tables to show squares instead of numbers along tops/sides. so id trash that file, grab a fresh original from zip file to start all over, until i eventually got it right.
from comments on previous logs, it had been recommended to adjust the maf scaling a little to reduce the knock correction incidents. but that is for another day, im beat
not loaded onto car yet, need time on the calendar where i dont NEED the car in event it gets bricked. but im confident tables are reading correctly, no crazy values & numbers along the top & sides of all tables ive opened. lucky I have B01C which was largely being discussed on pages 13-16 this thread.
Thanks @steve99, @acj47, @Foobar, @troek!!
bababooey is offline   Reply With Quote
The Following 2 Users Say Thank You to bababooey For This Useful Post:
FRSBRZGT86FAN (12-22-2017), troek (12-11-2017)
Old 02-23-2018, 09:53 AM   #399
nickson555
Drives: 2015 Subaru BRZ Limited
I finally did that mod so I can now buy a catback with my UEL catless header without getting killed by my neigbors. What a night and day difference. I was hesitant because of the very cold winter here but I set it to 1400 and kept the MAF correction after start a little higher than the rows bellow .
It was -15 celcius here this morning and it started and idled perfectly fine.
nickson555 is offline   Reply With Quote
Old 03-23-2018, 02:03 PM   #400
xxthrillxx
Perfectly Balanced...
xxthrillxx's Avatar
Drives: '13 FRS & '13 BRZ
Originally Posted by allowe View Post
Omfg that's what I've been looking for for half an hour now!! (The maf correction crap). It's safe though right ? To use another definition?
did you have to purchase this?
I have A00C and cant find the parameters on my Defs... downloaded older versions but keeps giving errors on CELs while loading it up and the maps look way diff than the ones on here.
xxthrillxx is offline   Reply With Quote
Old 03-23-2018, 02:39 PM   #401
xxthrillxx
xxthrillxx's Avatar
Scratch my previous post. looks like v4 tunes already include the cold start disabled
Old 03-27-2022, 01:15 PM   #402
gpvecchi
gpvecchi's Avatar
Sorry to necropost, so to disable annoying cold start noise, correcting ingition retard is enough, or is it better to edit MAF correction and idle, too?
Old 03-27-2022, 01:31 PM   #403
Robotaz
Drives: 2022 GR86 Premium
I’m curious about your comment.
My car since new under certain ambient temps when I start in the morning has a kind of head knock until it gets down to 700 rpm idle and it stops and this different smooth idle sound starts. I’ve of course wondered if such noise is normal as it does not sound reassuring to say the least.
Is this what you’re talking about?
Robotaz is offline   Reply With Quote
Old 03-28-2022, 03:38 AM   #404
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Why TF haven't you taken the car back to the dealership and asked them about it?
Old 03-28-2022, 03:55 AM   #405
tomm.brz
Drives: brz 2017 hksv2
are you guys serious? it s 10 years now and still haven t a clue about wheater is cold start normal or not?
I get that you ve got a new car in 2022 but there are 10 years of informations in here to search
It s not a HEAD KNOCK sound, it's a cold start, so high rpm speed combine with negative ignition timings, and a stratified late fuel injection.. Fuel gets dumped into the exhaust and burns there to produce more heat
gpvecchi (03-28-2022)
Old 03-28-2022, 05:37 AM   #406
x808drifter
LMGTFY
IDK I've never heard a car make "head knock" noises during cold start.
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
