Old 07-20-2017, 10:27 PM   #3515
dylandrivesacar
Drives: 2014 Scion FR-S
Originally Posted by 15limited View Post
Is your vehicle lowered. If so, how much. Any added camber? Your tire size is also important to determine clearance.
Sent from my 2PQ93 using Tapatalk
I'm on stock suspension and figured I'd get 245/35 for the rears
dylandrivesacar is offline   Reply With Quote
Old 07-22-2017, 08:55 PM   #3516
whitelightninn
Drives: 2013 Subaru BRZ
Will I have any clearance issues mounting an 18x9 +20 wheel? I'm prepared to run -2.5 camber at least..
225/40/18
Car is on FA500's
Camber bolts
Rear LCAs in the mail
whitelightninn is offline   Reply With Quote
Old 08-12-2017, 08:18 PM   #3517
PDXsuperfly
Drives: 2013 FRS
I've tried to search with little success but does any one know if a 225/50R17 tires will fit the stock FRS wheels and suspension without rubbing? Bonus point if you have pictures. Looking to get a tame rally look.
PDXsuperfly is offline   Reply With Quote
Old 08-12-2017, 09:44 PM   #3518
churchx
churchx's Avatar
Drives: 2014 GT86
PDXsuperfly: From one thread about winter tires i recall, that 215/55/R17 rubbed slightly on full lock (so i guess 215/50/R17 should be ok). Are 225/50/R17 same or slightly smaller or slightly larger? Check with some online tire calc. Also there is 'meaty tires' thread in tires section. While from time to time people misunderstood and posted big diameter wheels and wide tires there, originally it was about 'meaty', about 'high sidewall', so i guess if you page through that thread, you may find examples of bigger wheels there.
P.S.
If you want more ground clearance, you may consider & google for "lift spacers brz". Then one can get more ground clearance even with normal sized wheels. You may also consider "rally-ish" wheel designs, eg. sparco terra. And rallyarmor mudflaps . But if you'll go after big diameter wheels/tires route, you may consider installing also other FD, to counter overall gearing ratio changes due bigger wheels, to not worsen acceleration. Of course for actual more bad-roads/rally capability best bet would be installing more capable/higher travel coilovers, but it may get a bit costly/too specialised. Though i'd consider of something like TRD rally coilovers (+10mm. Unfortunately haven't seen any real review of them), or KW V1/V3/RCE T0/T2 + lift spacers (even while KWs and based on them RCEs have more travel then stock, their overall height is a bit lower, hence - spacers)
Old 08-13-2017, 12:41 AM   #3519
PDXsuperfly
Drives: 2013 FRS
churchx: I'll keep going though those threads to see what I can find. The plan for now is to try to get the highest sidewall tires and see how I feel about this rally inspired look. Then if it is something that I like; I am thinking of getting some 16s with aggressive tires and the TRD rally suspension. I've always loved the look of turbo fanish wheels but have not seen too many that would fit the frs.
I believe I saw some spacers with stock suspension and didn't really like the look. The other benefit I had in my mind is that I can find a set of stock wheels around here for pretty cheap. I figure I could then switch from "street" to "rally" pretty easily once I clone the tpms sensors (I assume this is the route I would have to go with swapping wheels at home).
Also I figured my OFT tune OFH & over pipe with Perrin exhaust and drop in K&N would help alleviate any issues with lack of oomph. Not to mention the red rally flaps on a white car should add like a dozen HP...
I also read the a higher sidewall will flex a little more and that perhaps some run flats could help stiffen the tire...? The thread was pretty old and not too many specifics but is this still the case?
Old 08-17-2017, 08:26 AM   #3520
Riseuporfall
Riseuporfall's Avatar
Drives: 2016 scion frs
I was looking at a squared setup of 18x9.5 et25 and wanted to put 235/40 18 in the fronts and 265/35 18 in the rear, but I'm not really sure if it would work. I don't mind a little poke nor do I mind a little sunken look. I'm putting in tein coils next week. And most likely won't have the rims and tires for a couple of months but I want to know if it will work
Riseuporfall is offline   Reply With Quote
Old 08-22-2017, 09:50 PM   #3521
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
Hypothetically, if I had 3mm of clearance on an 18x9.5 +40 wheel on 245/35 tire..
Would it be correct to say I have 5mm of clearance on an 18x9.5 +43 wheel on a 235/40 tire? (Approx -1 degree camber)
________________________________
instagram - @FL4TBXR
chermo12 is offline   Reply With Quote
Old 08-22-2017, 11:32 PM   #3522
swarb
Yes, rim clearance +3mm.
Tire clearance, 10mm difference, so half that(half inside/half outside), so another 5mm added to the 3mm offset difference, for a total of 8mm. (plus a tiny bit more sidewall clearance from the tire stretch)
Old 08-23-2017, 10:59 AM   #3523
chermo12
chermo12's Avatar
Ah, but wouldn't I lose the initial 3mm of rim clearance by going from +40 to +43 offset? (Since +43 brings the rim closer the hub/coil).
Old 08-23-2017, 11:12 AM   #3524
Zee2413
Drives: Scion FR-S 10 Series
Will it fit: 18x10" +40 with 275/35 R18 Michelin Pilot Super Sport tires.
Coilovers, LCA, Rear toe-correction arms
Zee2413 is offline   Reply With Quote
Old 08-23-2017, 11:23 AM   #3525
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
@Sportsguy83 was running that exact setup ZE40s on his twin. Should work with rolled fenders and some negative camber.
Kami Speed is offline   Reply With Quote
Old 08-23-2017, 11:54 AM   #3526
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Correct @Kami Speed I did run that setup with no major issues. Coilovers, between -1 and -2 camber. Rear LCAs, front camber plates. The most important factor here is the car drop. I was on a mild drop. If this fits or not, depends greatly on how low is your car. The lower, the more difficult it is.
I now run TE37 SL 18x9.5 +40 and the same MPSS and they also fit nicely.
Old 08-23-2017, 12:03 PM   #3527
Zee2413
Thank you for the info. I am hoping to go for the KW V3 and the minimum drop is 0.8" which I am fine with. Hopefully those coilovers are ok with Canadian winters
Old 08-23-2017, 12:42 PM   #3528
swarb
Yes, strut clearance. If you are running stock style struts you will have clearance issues up front. If you are on aftermarket coilovers, you will be ok.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
