Old 08-20-2017, 07:45 PM   #1
LudwigMiles
Drives: '13 BRZ
Do I have brake pad left?
I took off the wheel, and tried to inspect the brake pad.
Never owned a car where the entire pad was so hidden.
I couldn't see anything.
So, I looked at the peep hole, but can only see one side.
I don't know if that is the pad, or the backing metal.
Also, I can't even see the other pad on the right.
Are we to assume both pads wear at the exact same rate?
This is what I saw. Is this pad or metal plate?
I can't imagine so much pad left after 30k miles.
LudwigMiles is offline   Reply With Quote
Old 08-20-2017, 07:54 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
from left to right
brown stuff is pad, orange stuff is rust on the edge of the rotor, then the hollow center vanes of the rotor then you can see the edge of the right half the rotor
Yes, OE pads are very much long life pads if you don't beat 'em up, I wouldn't be surprised if most people could get >60k out of OE pads.
Removing the caliper to get a good look at the pads is extremely easy if you already have the wheel off, two bolts. (provided the bolts aren't seized to hell)
http://www.ft86club.com/forums/showthread.php?t=24614
(you can see photobucket clicks by right clicking and getting the image url and then pasting that into your browser bar to see it)
((hey @PMok update your pictures on your DIY))
ineedyourdiddly
The Following 6 Users Say Thank You to strat61caster For This Useful Post:
humfrz (08-20-2017), Impureclient (08-20-2017), new2subaru (08-20-2017), notout86 (09-09-2017), Teseo (08-20-2017), Ultramaroon (08-21-2017)
Old 08-20-2017, 07:56 PM   #3
LudwigMiles
Drives: '13 BRZ
That pad is thick as hell, it almost looks new.
I can't believe it. I guess a light car does not use pads.
Esp. when driven conservatively.
Old 08-20-2017, 09:03 PM   #4
How many miles on your car .. ?? Mainly city or highway driving..??
Old 08-20-2017, 11:53 PM   #5
Decep
Drives: 2013 FR-S Series 10
Driving style matters too. Manual transmissions tend to engine brake better as well. The OE pads are long life/low dust too..
Old 08-21-2017, 12:45 AM   #6
extrashaky
Drives: 2014 BRZ Limited
Yes, OE pads are very much long life pads if you don't beat 'em up, I wouldn't be surprised if most people could get 60k out of OE pads.)
I'm at 72K miles and still have plenty of pad left.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
humfrz (08-21-2017), strat61caster (08-21-2017)
Old 08-21-2017, 06:53 AM   #7
WNDSRFR
Drives: FR-S,GTI
I just changed my front pads at 110,000 miles and had plenty left too. Probably could have gone another 100,000.
The Following User Says Thank You to WNDSRFR For This Useful Post:
humfrz (08-21-2017)
Old 08-21-2017, 08:08 AM   #8
gravitylover
from left to right
I just did my rear pads and rotors at 84k. The dealer wanted to turn the rotors but Tire Rack has a deal on Centric pads and rotors for $95 so it made sense to just do it all. The fronts have a couple of thousand miles left.
Old 08-21-2017, 11:41 AM   #9
LudwigMiles
Drives: '13 BRZ
Ok, it looks like I won't be needing to replace the pads anytime soon.
Next time I have the car jacked up, I will learn how to remove the pad anyways.
Old 08-29-2017, 08:04 AM   #10
paulca
Drives: Toyota GT86 Coupe Red (UK)
Wow. I got 20k out of my pads and one track day mangled them. Plenty of meat left on the bone (about 50%) but it was cooked. Grating/grinding until I changed them.
Discs lasted another 10k and where already 5k driven beyond their 22mm limit.
So, without the track day I would estimate, 50k on a set of pads and 50k on a set of discs.
Do the US models get the same pads? Over here they are high friction Pagid pads (and discs) I believe, which squeal frequently under light braking.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Brake rotor temperature right/left and front/rear comparison questions HappyMonkey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 07-07-2017 02:29 PM
OEM Brake Pads, 50% Life Left Keenercarguy Brakes, Suspension, Chassis 4 02-14-2017 03:11 AM
BLACK FRIDAY SPL - StopTech Big Brake Kit 2PC - 1 kit left 328mm, red slotted Gruppe-s Brakes, Suspension, Chassis 35 11-04-2015 09:39 PM
STOP TECH BRAKE KIT SPECIAL!!!!!!!!! (2 Left) vividracing Brakes, Suspension, Chassis 6 10-15-2014 06:43 PM
3rd brake light idea ravenblackfrs Electronics | Audio | NAV | Infotainment 4 09-28-2013 01:30 AM
