Old 07-04-2012, 03:29 PM   #15
xcelir8brz
Drives: 2013 BRZ Limited
Easy. Pin 17 on 28 pin stereo harness. vss
Sent from my Galaxy Nexus using Tapatalk 2
xcelir8brz is offline   Reply With Quote
Old 07-04-2012, 06:24 PM   #16
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
That is a tach signal, and not a speed signal? And do you know what color it is? If that's the right one, I'd be VERY happy!
Edit: My wiring shows that pin 17 is "speed sense" and is pink/green. So to me, that's for vehicle speed, and not the tach.
Lil Abner is offline   Reply With Quote
Old 07-04-2012, 06:28 PM   #17
Lil Abner
Originally Posted by Jeff Lange View Post
Looking into it further, it looks like the ECU has a dedicated "TACH" output signal, pin A35-15 on the ECU. This is the 35-pin connector.
It probably heads over to the DLC2 connector or something, because it isn't heading to any other systems in any of the wiring diagrams which is where I initially checked. Every other ECU, etc. uses the CAN-BUS to get the tach signal, but as I said there is an output dedicated to it on the ECU. It's not shown in any wiring diagrams, but it is mentioned in the RM.
Nice of them to do that.
Jeff
Jeff, you seem to know your $hit! My wiring charts show I can grab a tach signal from the large 54 pin connector on the passenger side, rear of the engine. Looks like pin 54, 53, 52, & 51 (white, black/yellow, black/red, black/blue). These are larger diameter than most wires on the harness, so can you confirm I can grab a tach signal from one of these? Or even is you can be more specific on which ECU you are referring to, and wire color. I don't have the wiring schematics for the car yet. Thanks!
Old 07-04-2012, 06:30 PM   #18
xcelir8brz
vss is speed. Sorry. Yeah need tach rev.
Old 07-05-2012, 01:43 AM   #19
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
54 = Port Injector No.1, White
53 = Port Injector No.2, Black/Yellow
52 = Port Injector No.3, Black/Red
51 = Port Injector No.4, Black/Blue
I don't think trying to get some sort of tach signal from the injectors is going to work for you, especially on a D4-S system when they aren't on during all conditions, and on top of that you have duration, etc. to deal with. There is no tach signal to be found on those wires.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
Lil Abner (07-05-2012)
Old 07-05-2012, 03:01 AM   #20
cruzinbill
Drives: Argento 6spd FR-S
He def knows his shit... I remember him from supramania. always seem to have the answer. Also Im curious... and may have missed it, but what are you grabbing the tach signal for? remote start I assume?
cruzinbill is offline   Reply With Quote
Old 07-05-2012, 06:40 AM   #21
Lil Abner
Jeff
Thanks again for your response Jeff. I seem to be striking out on this! Any suggestions on a good tach signal under the hood?
I do apologize for questioning you on the tach signal inside the car. I'm use to all the Toyotas I've owned that have tach inside the car. This Subaru thing is new to me.
Old 07-05-2012, 06:43 AM   #22
Lil Abner
I actually need the tach for two things: remote start and push button start. I've got everything installed (minus the push button trim paint). Just need to get a tach signal and program it.
Old 07-05-2012, 02:21 PM   #23
cruzinbill
which pushbutton start are you going with?
Old 07-05-2012, 02:28 PM   #24
Lil Abner
I purchased the Advanced Keys module a few years back and installed it in my Toyota. Obviously I'm not going to sell the car with the module installed! I got a steal of a deal, the push button start AND the proximity module for $150 shipped.
Old 07-05-2012, 02:45 PM   #25
cruzinbill
can you link the part number or anything for what you got. would be nice to find a push button start... although I guess I could find a way to use the BRZ one im sure. Thats one thing I wish was an option for the FR-s
Old 07-05-2012, 02:52 PM   #26
Lil Abner
LINK
I have the AK-104B, which is both modules together. Or if you scroll down, you can purchase the modules separately. The button used should be the same as the OEM button.
I don't think swapping the BRZ push button in will be easy. The OEM setup requires a new steering column for the lock out, as well as a different ECU for the key/transponder. I think aftermarket is going to be the cheapest route!
The Following 2 Users Say Thank You to Lil Abner For This Useful Post:
cruzinbill (07-05-2012), SirBrass (01-20-2014)
Old 07-10-2012, 11:54 PM   #27
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Hows the install going? Was it tricky? I was planning on buying the AK-104B off of a friend who never used it. =)
EDIT: Follow up question, how did you deal with the steering column lock? Did you manually place a key into the key hole to forgo the steering column lock, or is it actually an electrical switch?
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 01-10-2014, 08:54 PM   #28
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
I'm installing the Defi Advance ZD but had trouble trying to locate the wiring diagram to tap the speed and rpm. So basically it's not functional at all except readings on the oil n water temperature and oil pressure. Anyone figured it out yet?
Sent from my GT-N7105 using Tapatalk
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
BRZ NAV system GPS signal issues? DigDloppyFonkeyBick Electronics | Audio | NAV | Infotainment 73 06-07-2016 02:14 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
BRZ signal light bulb ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 8 06-20-2012 01:26 AM
Scion FR-S Tach Sweep Video F1point4 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 06-15-2012 03:53 PM
plastic in front of tach feldy Cosmetic Modification (Interior/Exterior/Lighting) 8 06-10-2012 12:03 AM
