#127 |
Drives: 2015 FRS - FFR GTM
Finished pulling the motor. Oil pan fits over the cross member, rack and sway bar but with the HP and water pumps hanging off the back of the motor it's too far back. I pulled the sway bar and things look better. It'll still be snug by the firewall. I may still trim the pan to move it forward another inch or so.
The cross member holes for the motor mounts as compared to where my mock up motor mount plates fall look good. Need to get polly isolaters and a digital level (mine crapped out!) this week. As a sidebar, what is everyone setting the angle of the trans at??
2015 FR-S - One Day I'll Finish The Swap |
| The Following 2 Users Say Thank You to gtpvette For This Useful Post: | Cole (08-14-2017), Sportsguy83 (08-14-2017) |
#128 |
Drives: RAVEN
The angle of the trans is relative to the angle of your differential. pull the driveshaft and put an angle finder on the face of the input pinion flange ( or whatever passes for a flange). The corresponding flange on the back of the gearbox needs to be the same but opposite.
The goal is to have the center line of the gearbox output shaft and the center line of the pinion parallel but not in line ( concentric). In line will eat u-joints and non-parallel will cause vibration. Last edited by NOHOME; 08-14-2017 at 11:34 AM. |
| The Following 3 Users Say Thank You to NOHOME For This Useful Post: |
#129 | |
Picking up a digital level this afternoon after work,,,,, will know then.
#130 |
That's some good info. I need to make sure I set the transmission at the correct angle when I do my LS swap.
#131 |
Drives: RAVEN
Cause we all like pictures:
[ame="https://www.youtube.com/watch?v=Idk3BVDVHq4"]Driveshaft Angle and Phasing - YouTube[/ame] |
| The Following 6 Users Say Thank You to NOHOME For This Useful Post: | Cole (08-14-2017), gtpvette (08-14-2017), Icecreamtruk (08-14-2017), ILLSMOQ (08-14-2017), Sportsguy83 (08-14-2017), tirespin782 (08-15-2017) |
#132 |
OK,,,,, measured it tonight the diff is 1.2 degrees up
#133 |
Drives: 2017 WR BLUE BRZ
Whoah...good info, makes sense.
It's easy enough to measure the angle on a flat flange like the one of the diff...but how do you measure the angle on the back of the trans/yoke? |
#134 | |
Kind of the same way,,,, right off the flat yoke.
#135 |
does suspension travel play a difference? Like compressed, full droop, or cruise height
#136 |
#137 | |
The rear end is fixed as it's an IRS,,, trans as well.
#138 |
This trans has a fixed yoke. I'll need to take off the rubber isolator then I can measure
#139 |
#140 |
Only users lose drugs.
Drives: All the time
Unless you're running solid differential bushings, you'll still need a tiny amount of angle offset so the joints are in phase when the diff rotates a bit under load. You always dial in a bit less angle on solid axle cars, especially with leaf springs. I imagine an IRS setup would require less, but there's still going to be some movement..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| Should I have just got a new motor? | SoundsOfTheUniverse | Issues | Warranty | Recalls / TSB | 12 | 07-31-2017 07:51 PM |
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
| K2 Motor? | Ronin Sascha | Engine, Exhaust, Transmission | 8 | 08-16-2014 06:51 PM |
| Does every motor say #1 | sosick | Engine, Exhaust, Transmission | 21 | 05-05-2014 09:28 AM |
| MOTOR UNION | David | Southern California | 0 | 06-22-2013 01:32 PM |
