Old 08-13-2017, 05:10 PM   #127
gtpvette
Drives: 2015 FRS - FFR GTM
Finished pulling the motor. Oil pan fits over the cross member, rack and sway bar but with the HP and water pumps hanging off the back of the motor it's too far back. I pulled the sway bar and things look better. It'll still be snug by the firewall. I may still trim the pan to move it forward another inch or so.
The cross member holes for the motor mounts as compared to where my mock up motor mount plates fall look good. Need to get polly isolaters and a digital level (mine crapped out!) this week.
As a sidebar, what is everyone setting the angle of the trans at??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following 2 Users Say Thank You to gtpvette For This Useful Post:
Cole (08-14-2017), Sportsguy83 (08-14-2017)
Old 08-14-2017, 12:07 PM   #128
NOHOME
Drives: RAVEN
The angle of the trans is relative to the angle of your differential. pull the driveshaft and put an angle finder on the face of the input pinion flange ( or whatever passes for a flange). The corresponding flange on the back of the gearbox needs to be the same but opposite.
The goal is to have the center line of the gearbox output shaft and the center line of the pinion parallel but not in line ( concentric). In line will eat u-joints and non-parallel will cause vibration.
NOHOME is offline   Reply With Quote
The Following 3 Users Say Thank You to NOHOME For This Useful Post:
Cole (08-14-2017), ILLSMOQ (08-14-2017), Sportsguy83 (08-14-2017)
Old 08-14-2017, 02:12 PM   #129
gtpvette
Picking up a digital level this afternoon after work,,,,, will know then.
Old 08-14-2017, 02:36 PM   #130
all4spl
That's some good info. I need to make sure I set the transmission at the correct angle when I do my LS swap.
all4spl is offline   Reply With Quote
Old 08-14-2017, 02:47 PM   #131
NOHOME
Drives: RAVEN
Cause we all like pictures:
[ame="https://www.youtube.com/watch?v=Idk3BVDVHq4"]Driveshaft Angle and Phasing - YouTube[/ame]
The Following 6 Users Say Thank You to NOHOME For This Useful Post:
Cole (08-14-2017), gtpvette (08-14-2017), Icecreamtruk (08-14-2017), ILLSMOQ (08-14-2017), Sportsguy83 (08-14-2017), tirespin782 (08-15-2017)
Old 08-14-2017, 10:17 PM   #132
gtpvette
OK,,,,, measured it tonight the diff is 1.2 degrees up
Old 08-14-2017, 11:01 PM   #133
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Whoah...good info, makes sense.
It's easy enough to measure the angle on a flat flange like the one of the diff...but how do you measure the angle on the back of the trans/yoke?
ILLSMOQ is offline   Reply With Quote
Old 08-14-2017, 11:18 PM   #134
gtpvette
Kind of the same way,,,, right off the flat yoke.
Old 08-14-2017, 11:29 PM   #135
all4spl
does suspension travel play a difference? Like compressed, full droop, or cruise height
Old 08-14-2017, 11:32 PM   #136
ILLSMOQ
Like the flat part/end of the output shaft?
Old 08-15-2017, 08:27 AM   #137
gtpvette
The rear end is fixed as it's an IRS,,, trans as well.
Old 08-15-2017, 08:30 AM   #138
gtpvette
This trans has a fixed yoke. I'll need to take off the rubber isolator then I can measure
Old 08-15-2017, 09:46 AM   #139
ILLSMOQ
I see that. T56 and others have a slip yoke. Any idea on how to get a good measurement?
Old 08-15-2017, 10:51 AM   #140
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Unless you're running solid differential bushings, you'll still need a tiny amount of angle offset so the joints are in phase when the diff rotates a bit under load. You always dial in a bit less angle on solid axle cars, especially with leaf springs. I imagine an IRS setup would require less, but there's still going to be some movement..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Should I have just got a new motor? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 12 07-31-2017 08:51 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
K2 Motor? Ronin Sascha Engine, Exhaust, Transmission 8 08-16-2014 07:51 PM
Does every motor say #1 sosick Engine, Exhaust, Transmission 21 05-05-2014 10:28 AM
MOTOR UNION David Southern California 0 06-22-2013 02:32 PM
